Setting an external B0_x field in MHD module
Like Tree8Likes
  • 2 Post By fferroni
  • 5 Post By fferroni
  • 1 Post By gbrajtm
Old   November 29, 2011, 14:18
Default Setting an external B0_x field in MHD module
fferroni is on a distinguished road
Hello.
I'm trying to do a simple simulation of pipe flow flowing through a transverse applied external magnetic field.
I've followed religiously the Manual provided by Ansys but I think it's not doing the job I'm wanting it to do.
In the Problem Set-Up/MHD Model/ I have a DC Field with B0_x Mean (Tesla) as 10 Tesla. I have applied the external field. In the boundary conditions I have a conducting wall.
In the Boundary Conditions section, I have a "Velocity-Inlet", "Pressure-Outlet", "Symmetry", and "Wall". There are UDS tabs for the inlet, outlet and wall zones. I have these all set to udf mhd_bc_conduct::mhd.
I'm not too sure what these UDS BV actually do... so if someone would want to elucidate?
I then initialize the problem etc. and the solution turns up exactly like there was no external applied magnetic field! During solving iterations, it also prints out residuals for uds-0, uds-1, uds-2.. and these are all zero, so I'm guessing it's not considering the huge magnetic field that I'm applying?!
For the record, in the Results section, when I display the Contour for Symmetry of "User Define Memory" / B0_x I get a pretty homogeneous 10 Tesla!
I know for a fact that the liquid (fast flowing molten metal) changes it's behaviour but it appears like it's not considering the applied external magnetic field?!
Please help!
Thank you,
Kind Regards,
Francesco
ambrish4u and Marya like this.
fferroni is offline   Reply With Quote
Old   November 30, 2011, 14:36
Default solution
Hello everyone.
Fortunately I figured this out myself.
The reason is that you have to click "Apply" for the external magnetic field in the problem set-up AFTER initializing the solution... i believe that by initializing the solution in general it cancels the application of the external magnetic field done by the MHD module. The MHD manual is a bit counter-intuitive in this regard!
Thanks
Francesco
meoiotu, ambrish4u, Marya and 2 others like this.
Old   July 30, 2012, 04:00
Ramnik Singh
Ramnik is on a distinguished road
Hello Mr Fferroni,
I was wondering if you could help me out with this problem related to MHD using Fluent.
I have been trying to implement conducting wall boundary condition for the MHD module using the Electric Potential Method. It requires to specify a fixed current or voltage.
I am trying to simulate turbulent flow in a square pipe and have not been able to figure out a way to calculate the required potential/voltage at the boundary.
Please comment if you have any ideas.
Thanks in advance.
Regards
Ramnik
Ramnik is offline   Reply With Quote
Old   October 5, 2012, 14:31
Heera Lal
Heera Lal is on a distinguished road
hi mr. fferroni,
i was facing the same the same the problem .But your suggestion worked. thanks a lot.
but i am not able to get the lorentz force contour and also i am not sure bout boundary condition for uds-0 and uds-1. If you have any idea then please tell me .
Thanks .
Heera lal
Heera Lal is offline   Reply With Quote
Old   February 25, 2013, 15:15
Nasser
nasser is on a distinguished road
hi friends
the total magnetic flux through a closed surface is equal to zero. if your surface is close you havnt any induce magnetic field b.
nasser is offline   Reply With Quote
Old   July 2, 2014, 04:21
Question Mhd module
meisammm is on a distinguished road
i want to model mhd ( by fluent mhd module) in a channel with sea water flowing in it.
B=15 tesla
i solve the problem with no problem (solution converges also uds-0 , ... all converge) but the existence of mhd and magnetic field has no effect of mass flow rate or velocity in outlet boundary!
Can anybody help me out?
Thank you
meisammm is offline   Reply With Quote
Old   July 13, 2015, 06:29
Default MHD simulation for Magnetorheological Fluids in annular gap
Dr Gurubasavaraju
gbrajtm is on a distinguished road
Hi all,
I was trying to simulate MHD for finding the velocity profile of flow in the gap under different magnetic field.
Pressure inlet- 500pa
outlet - 0 pa
material - MR fluid
visco = 0.09 pas
permeability= 0.0008 H/m
Density= 3180 Kg/mm3.
i did simulation for 3T magnetic flux. But the velocity profile looks abnormal, velocity not reducing in the magnetic region, reduces only are the terminals of the field. Could any body please help me to find the profile.
gbrajtm is offline   Reply With Quote
Old   November 18, 2017, 03:19
nazar
nazar1979 is on a distinguished road
hello every body
I simulate flow of blood in artery and add MHD there by use fluent ,but not any effect for MHD force on velocity profile, please if any body can help me ,i face big problem because that.
thanks
nazar1979 is offline   Reply With Quote
Old   November 24, 2017, 02:06
Default MHD external magnetic field
Anu
n9879005 is on a distinguished road
I have used MHD simulation for drug delivery in the lung but little bit confused the value of an external magnetic field. can anyone help me which value is appropriate for the magnetic field in drug delivery.
thanks in advance.....
n9879005 is offline   Reply With Quote
Old   November 24, 2017, 02:15
Dr Gurubasavaraju
Originally Posted by nazar1979 View Post
hello every body
thanks
Increase the magnetic field and simulate. Another way is create the hydrodynamic entry length to allow flow to reach fully developed state and simulate.
nazar1979 likes this.
Old   January 20, 2021, 17:53
Zese
zese is on a distinguished road
Originally Posted by Heera Lal View Post
hi mr. fferroni,
Thanks .
Heera lal
Hi dear friend. I am having the same problem, as well. can you help me through?
zese is offline   Reply With Quote
Old   August 1, 2022, 09:20
sina
sina_sls is on a distinguished road
Originally Posted by fferroni View Post
Hello everyone.
Thanks
Francesco
Hello
I want to set sinusoidal value of electric potential (MHD module) for a wall, first i try expression but i faced to error :
Error: wta(2nd) to string_eq
Error Object: __expr__
then i try Profile and UDF profile , but agian i faced to problem , when i use them it consider the wall to insulated.
Could you help me how can i set sinusoidal value for current density ( Electric Potential MHD) ?
Best Regards,
sina_sls is offline   Reply With Quote
mhd, udf issue
External magnetic field data Richard Lee FLUENT 7 January 11, 2019 05:43
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
computational MHD flows, boundary conditions packer Main CFD Forum 0 March 21, 2006 04:35
External flow field. Moon FLUENT 3 March 5, 2003 11:32
simulating a two-phase flow with an external field Yi Main CFD Forum 7 August 9, 2000 12:12
