How to calculate Volatile Molecular Weight in Coal Combustion? |
Mosi Owa
Rep Power: 14 ![]() |
Hi All,
I am trying to model pure coal combustion in Fluent but I do not know how to calculate Volatile Molecular Weight (Kg/Kmol) using Proximate and Ultimate Analysis. I can calculate mass fraction of C, H, O and N in volatile but I do not know how to use them to get x,y,z and w in CxHyOzNw. Do you have any idea to help me out? Thanks |
Rep Power: 17 ![]() |
Molecular Weight of compound can be computed by multiplying the atomic weight (in atomic mass units) of each element in a chemical formula by the number of atoms of that element present in the formula, then adding all of these products together. |
Mosi Owa
Thanks, but the problem is that I do not know the chemical formula and I'm looking for a way to find it. Let me clarify my case: I have 35.61 gr of volatile which is composes of C, H, N, O and S. I know the fraction of each substance as 20.22 gr of C, 4.77 gr of H, 1.54 gr of N, 7.78 gr of O and 1.3 gr of S. Now, I want to know the molecular weight of my volatile or in other word the coefficients of CxHyNpOqSr. Any idea?
You may get hint from this link: https://www.sharcnet.ca/Software/Flu...oal_inputs_pdf Mehulkumar |
Emerson
Rep Power: 8 ![]() |
Old post but who knows right?
Take a look at this topic from this work, very good one. Alganash, Blaid Sasi Abozeid (2015) Numerical investigation of the combustion processes of various combustion regimes. PhD thesis. |
ASHRAF AHMED
Rep Power: 3 ![]() |
How can Method of simulating the combustion of wood solid fuels in thermal boilers?
ASHRAF AHMED
How can Method of simulating the combustion of wood solid fuels in thermal boilers in Ansys fluent flow?
coal combustion, volatile |
coal volatile composition | arnab | Main CFD Forum | 3 | August 28, 2024 02:44 |
Problem on EDC model for coal combustion | lei | FLUENT | 4 | September 3, 2015 09:39 |
Coal combustion and ash reaction kinetics | sega | Fluent UDF and Scheme Programming | 0 | January 21, 2010 08:05 |
Pressure and molecular weight ? | Jane | FLUENT | 0 | January 2, 2009 04:17 |
Coal combustion - volatile species | Venky | FLUENT | 4 | October 22, 2008 19:28 |
