[DPM problem] infinite particles loop in domain (twin cyclone - double cyclone))
Like Tree1Likes
  • 1 Post By ghost82
Old   November 12, 2011, 14:04
Default [DPM problem] infinite particles loop in domain (twin cyclone - double cyclone))
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Good morning all,
I'm simulating a double cyclone system (twin cyclone), to separate a stream of particles (ash) from a fluegas.
The model consists of about 2.300.000 cells. Model is steady k-epsilon RNG with swirl dominated flow, no energy equation, incompressible gas. After about 4.000 iterations I stopped the simulations, residuals were all constant and under 10^-3 except continuity which was around 1*10^-2; however inlet and outlet mass flows were identical, and velocity and pressure profiles seem to be ok.
After that I enabled the DPM model to track my particles (steady) and to see the global efficiency.
So I set up multiple surface injections (at inlet) (I didn't use the Rosin-Rammler distribution) for each size of particles (I tried 5 - 15 - 82 and 2500 microns) and set the number of steps to an initial value of 200.000.
Outlet was setup as an escape boundary, dust collector (below cyclones) was setup as a trap boundary, all the other walls were setup as reflect (reflection condition --> normal -->constant=0,8, tangent-->constant=0,8).
However I saw a 100% incomplete path for all the injected sizes (except the 5 microns size), as you can see in the attached pictures (in picture I changed the injection type from surface to point).
I increased the number of steps till 5.000.000 but the results are the same: particles recirculate in the domain, without exiting or being trapped.
Pictures with tracked particles are all calculated with 1.000.000 steps.
What does this mean?It cannot be real an infinite loop of the particles.
Thank you for any replies
Daniele
ghost82 is offline   Reply With Quote
Old   November 14, 2011, 08:48
ghost82's Avatar
Rick
Found my answer in article "NUMERICAL STUDY OF GAS-SOLID FLOW IN A CYCLONE SEPARATOR"
The particles with diameters of 2×10-6m and 7×10-6m can spin down to the conical section of cyclone and then should be collected while the bigger particles with diameter of 3×10-5m and 1×10-4m spin downward first and then keep spinning near the wall at a certain horizontal level.
There is therefore a critical value to distinguish the flow pattern of particles of different diameters. If the particle diameter is larger than the critical value, the particle will keep a circular motion in the cone of cyclone. In contrast, if the particle diameter is less than this critical value, the particles will be collected directly or escape from the cyclone.[...]
In the real industry, these bigger particles will be eventually collected due to their interactions with other particles.
Old   December 28, 2015, 10:09
elham
emka is on a distinguished road
Hi Daniele
I am simulating a cement cyclone and faced with the same problem as you mentioned, that particles with diameter more than 50 micron keep spinning at a level of cyclone.
how can I reach a realistic result as the real cyclone in factory has 83 percent efficiency factor, but mine is less than 10% because most of the particles remain in cyclone.
Thanks for any reply and consideration.
emka is offline   Reply With Quote
Old   December 28, 2015, 10:13
ghost82's Avatar
Rick
consider incomplete particles as trapped particles: as I wrote that particles will interact with other particles and they will probably spin down and collected.
Google is your friend and the same for the search button!
Old   December 28, 2015, 10:27
elham
thanks for reply
I got your note,but there is 200 pascal difference in droplet pressure of real cyclone and stimulated one that I guess is due to the thing I mentioned, How can I valid my stimulation?
Old   December 28, 2015, 10:33
ghost82's Avatar
Rick
I think this is more related to turbulence model; if you didn't do it, simulate with reynolds stress model (better), or k-epsilon RNG with swirl activated.
emka likes this.
Old   May 19, 2020, 15:19
mohamad ali mirzaei
mohamadalimirzaei1994 is on a distinguished road
Originally Posted by emka View Post
Hi Daniele
Hi Elham,
I am facing the same problem (particles remaining at a certain level), could you overcome this? How?
Thanks
mohamadalimirzaei1994 is offline   Reply With Quote
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 04:34
New densitybased solver AeroFoam giulio_romanelli OpenFOAM Running, Solving & CFD 48 January 15, 2016 09:20
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 11:38
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
