How can I calculate Swirl number at different heights in a column |
October 11, 2011, 12:10 |
Rep Power: 15 |
I have a cylindrical column with swirling flow. I want to calculate swirl number at different positions along the height of the column. How can I calculate it using Fluent12.1 can any one help please?
Thank you. |
October 18, 2011, 08:51 |
anonym
Rep Power: 17 |
I think the swirl nr is not a default value in Fluent. So first go to Define/Custom Field Functions
Than, you should creat planes and in the Report menu, you can check at each plane. |
November 4, 2011, 12:18 |
Rep Power: 15 |
December 3, 2012, 11:16 |
Rep Power: 14 |
mali28: how did you define your swirl number? I mean did you use custom field function? if so what is your equation? Please let me know.
Thanks. |
December 3, 2012, 16:08 |
Rep Power: 14 |
mali28:
Thank you for your prompt rely. I went to that link but there is no pdf file there. Could you check again. Thanks again. |
swirl number |
heat transfer | woiwie | OpenFOAM | 0 | October 11, 2011 10:17 |
How to calculate swirl velocity | hamoudi | CFX | 3 | June 15, 2009 08:19 |
How to calculate inlet swirl number in Post? | CFXPostuser | CFX | 8 | April 29, 2009 14:50 |
how to calculate Nusselt number? | prayskyer | Main CFD Forum | 0 | June 17, 2006 21:57 |
how calculate the density in low mach number? | Juhee Lee | Main CFD Forum | 1 | July 31, 1999 16:26 |
