Global coordinate system and rotation-axis origin |
October 10, 2011, 02:22 |
Norger
Rep Power: 15 |
Dear CFD-forum members,
I have a problem with a rotating part and I work with ANSYS 13.0. I got a CAD-file and I have to simulate a rotation with it in ANSYS FLUENT. I know that I must set the wall to a moving wall and the water in it to a standing fluid but I do not know where my rotation-axis origin is. It should be in the middle of my part but it is not there. My question is: How can I see where the global coordinate system is or how can I put it to another place, e.g. to the middle of my rotating part? I also use ICEM CFD and Autodesk Inventor 2009 if someone knows the answer in these programs. Thank you in advance for your answers Norger |
October 10, 2011, 10:28 |
Norger
Rep Power: 15 |
Does nobody has an answer for my problem?
October 11, 2011, 01:59 |
You should be very sure about your rotating axis before coming to the solver. In Fluent solver there is no such option to trace axis of rotation. So go back to your CAD (Inventor) file and locate 2 points which lie in axis of rotation. Then specify co-ordinates of these 2 points as origin and direction vector in Fluent. Regards Sabin Mathew |
October 11, 2011, 04:01 |
Norger
Rep Power: 15 |
Hey,
thank you for your answer. I have an example to know whether I rightly understood you. If the origin of the coordinate system is in the middle of my rotating part and the y-axis should be the rotating axis, the rotating-axis origin is (0;0;0) and the rotating-axis direction is (0;0;1). Is it right? Best regards |
October 11, 2011, 04:48 |
with small correction, rotating axis direction is (0, 1, 0) Keep going...
October 11, 2011, 09:28 |
Norger
Rep Power: 15 |
Thank you very much!
Your answer solved my problem. |
December 13, 2016, 10:38 |
Paul
Rep Power: 10 |
I want to give the rotation of the drill at a speed of 8000[rev/min^-1] in Z axis but when I defining the speed and the rotation axis shows me of the message:
In Analysis 'Flow Analysis 1' - Domain 'Air: If a solid has motion set and it is connected to a stationary fluid domain, a moving wall velocity boundary condition must be specified on the fluid solid interface. I do not know what's going on, any ideas? I send screenshots of the program: https://drive.google.com/drive/folde...UU?usp=sharing |
December 13, 2016, 14:39 |
#8 | |
Rep Power: 18 |
January 18, 2018, 21:10 |
Display global coordinate system fitted to the body
#9 |
Rep Power: 10 |
Can some of you please tell me how to display the global coordinate system in ICEM CFD fitted with the body? Thanks. |
Accumulating Dust on a Filter Cartridge | WalterW | CFX | 21 | May 26, 2020 07:23 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Implementation of system rotation | Hagen | OpenFOAM Programming & Development | 0 | January 19, 2011 19:24 |
plz rply urgent regrding vof model for my system | garima chaudhary | FLUENT | 1 | July 20, 2007 09:37 |
coordinate system | raffap | Siemens | 0 | February 7, 2007 07:39 |
