Need help on perforated plate with less than 2% open area
Like Tree1Likes
  • 1 Post By -mAx-
Old   August 29, 2011, 00:22
Default Need help on perforated plate with less than 2% open area
Hongjin Wang
sosososo1114 is on a distinguished road
HI, dear all,
I have problems to decide the effect of perforated plate on the velocity component parallel to it and on elimination of turbulence.
recently I am working on a project requiring simulating the down stream air flow which flows cross the perforated plate with less than 2% open area. That is to say, the hole one the plate has a less than 2mm diameter while each hole space with each other at 2.54cm. I know that usually screen or thin perforated plate will be simulated as porous jump in FLUENT.
However, it seems porous jump seems not affect velocity component (v ) parallel with the plate obviously. As this perforated plate is installed in a diffusor with large turbulent up stream flow and its open area is rare, I quite doubt weather the down stream flow which flows in a rectangle chamber will have an obviously velocity in the direction which parallels with the plat as its upstream flow does. So would it work to simulate this plate as a porous jump? and Will this plate guide the flow into a verticle parallel flow ( the plate is located horizontally)?
Could you offer me any hints. I will appreciate them.
Best regards,
Hongjin
sosososo1114 is offline   Reply With Quote
Old   August 29, 2011, 02:56
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Why don't you simply import your perforated plate, mesh it, and compute it?
Alex Lee likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 29, 2011, 12:05
Hongjin Wang
Thanks Max, I would like to try. But I just have no idea on how to mesh the plate if I directly implant it into my model. the thickness of the plate is just 2mm while the height of the chamber where the plate is installed in is 0.8m, so what kind of mesh function should I use? Could you give me some suggestions on details? And how about the memory size and computation time? I will really appreciate it.
Old   August 29, 2011, 12:45
-mAx-'s Avatar
Maxime Perelli
I can help you if you are working with Gambit
Old   August 29, 2011, 13:19
Hongjin Wang
Yes, sir, Please. I am currently meshing with Gambit, but I am not quite sure what kind of interval size I should use and what the ratio of mesh size interval is appropriated for a quantitative analysis. I will really appreciate your help.
Old   August 29, 2011, 13:54
-mAx-'s Avatar
Maxime Perelli
is your perforated plate already modelised?
Post a picture to see how it looks like
Old   August 30, 2011, 00:30
Hongjin Wang
Yes, Max, thx , the picture below is the symmetric half of the model, and the points you see are in fact holes on the perforated plate
Old   August 30, 2011, 02:40
-mAx-'s Avatar
Maxime Perelli
ok you don't have so many holes, so it will be quite easy.
I assume you already extracted the fluid domain from your geometry.
For your plate, you only need to isolate the small cylinders with splits.
For this do following:
*create surface from top of cylinder with wireframe by picking the edge circle
*create surface from bottom of cylinder with wireframe by picking the edge circle
Now you can isolate your cylinder by splitting it with the 2 surfaces (split volume with surface >> select the 2 surfaces you just created).
If it is successful, you will be able to select the cylinder, and mesh it with hexa.
That's the goal for this stuff: isolating and meshing the orifices fine sufficient for getting flow rate inside each hole.
Then once all your holes are meshed, you may apply a size function from those volumes, and let grow your mesh from them.
If you pay attention to my picture you can see the hexa mesh inside the holes, and the growing mesh from them.
In my case I had some x-thousand holes, and you are quick limited from your hardware...
Old   August 31, 2011, 01:28
Hongjin Wang
Thanks Max, your suggestions help a lot on processing meshing, but still I get problems with meshing. The gambit says I have an entity unmeshed when I export mesh, but I used the filter found no unmeshed entity, so have you ever encountered such conditions?
Old   August 31, 2011, 02:33
-mAx-'s Avatar
Maxime Perelli
use filters and check unmeshed volumes, unmeshed faces and unmeshed edges
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
