How to start Fluent with Matlab??
Like Tree3Likes
  • 2 Post By Jay Hu
  • 1 Post By Sorin
Old   July 21, 2011, 22:24
Default How to start Fluent with Matlab??
Jay
Jay Hu is on a distinguished road
I am working on a problem that will need to start Fluent with Matlab. I am wondering if this is possible. If yes, how to do that?
What I want to do can be described as follow:
1. Run Matlab to obtain the B.C. for Fluent;
2. Start Fluent with Matlab (how to write this command in .m file?), use the calculated B.C. from previous step and run Fluent journal file;
3. Export calculated Fluent result;
4. Fluent results will be read by Matlab .m file;
5. Continute the following Matlab calculation; If necessary, run Fluent again.
UDF file may be needed.
How can I do that? It seems like we can do that.
Thanks
Jay
sumeetkotak and Richard Hu like this.
Jay Hu is offline   Reply With Quote
Old   March 30, 2012, 01:12
Default Loop Automation
Luca Gorasso
elcino is on a distinguished road
Send a message via Skype™ to elcino
so, is quiet easy, I do that every day, but depends on your version of the programs and if is a 3d or 2d problem. By the way, I do this:
1) You write the part of the *.m file which calculate the BC or any other parameter as you want.
2) The second part of the program write a *.txt file used as a journal file for Gambit (see the Matlab guide how to write *.txt files).
3) Launch Gambit in Batch mode with the command:
! C:\Gambit\ntbin\ntx86\gambit.exe -inp *.txt
4) With the same commands above write the Journal file for Fluent.
5) Launch Fluent in batch mode with the command:
! fluent fluent 3ddp -g -i "C:\Admin\Desktop\*.jou"
6) In the fluent journal provide the necessary commands to plot *.txt files of the results.
7) Read this results with Matlab (see the guide hot to do it).
8) And restart the loop or process them.
The Gambit and Fluent journal language is not easy to explain in a single post like this.
Best regards,
Luca, HIT (Harbin, China)
elcino is offline   Reply With Quote
Old   August 7, 2012, 16:25
Negin Nazarian
nenazarian is on a distinguished road
Hi
Im trying to do the same procedure in MATLAB
I have this function that writes the journal file and Im trying to open fluent in that function but the command "!fluent-3ddp" or even
! C:\Program files\ANSYS Inc\...\fluent.exe -3ddp
doesnt work.
The thing is when I dont add anything after the fluent path it works fine and the fluent window pops up, but as soon as I add "-3ddp" or "-i" or anything else it wont work anymore and give me this error
'C:\Program' is not recognized as an internal or external command,
operable program or batch file.
Do u have any suggestion?
I appreciate your help.
Cheers
Negin
nenazarian is offline   Reply With Quote
Old   August 8, 2012, 08:59
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi Negin,
Try to put the the path into a string "", such as "C:\Program files\ANSYS Inc\blablabla\fluent.exe -3ddp"
ghost82 is offline   Reply With Quote
Old   August 8, 2012, 15:17
Negin Nazarian
HI
thanks for your reply
I used "system" command and used " too
Cheers
Negin
Old   October 9, 2013, 15:20
Sorin Munteanu
Sorin is on a distinguished road
Hi Jay,
You can script Fluent directly from Matlab without having to create Fluent journal ,start Fluent in batch mode and then shutdown Fluent. The process of starting/shutting down Fluent can be quite expensive.
I will recommend the following steps
1.Start Matlab on Matlab machine
2.Start Fluent on Fluent machine in server mode (add -aas option)
3.Connect Matlab with Fluent
4. Compute B.C for Fluent in Matlab
5. Apply BC for Fluent in Matlab
6. Ask Fluent to perform CFD simulation from Matlab
7. Ask Fluent to provide calculated results from Matlab
8. Continue to follow Matlab calculation
9. Repeat steps 3 to 8 as needed to perform Fluent-Matlab simulation
10. Shutdown Fluent from Matlab when not needed.
This way you will have a remote Fluent-Matlab simulation, without having to start/shutdown Fluent and load/save Fluent cases or data.
Also your whole simulation logic will be in one place, in your Matlab code that will issue both Matlab and Fluent commands.
For more references about the technique follow the instructions in my following CFD-online post:
http://www.cfd-online.com/Forums/flu...ab-fluent.html
I hope this helps.
Sorin
Thanks
Jay
sumeetkotak likes this.
Sorin is offline   Reply With Quote
Old   November 10, 2018, 04:20
Sumeet kotak
sumeetkotak is on a distinguished road
Originally Posted by Sorin View Post
Hi Jay,
I hope this helps.
Sorin
Hi Sorin,
Can you help in regarding step no 3. "Connect Matlab with Fluent"
How to connect?
Thanks in Advance
Sumeet Kotak
sumeetkotak is offline   Reply With Quote
Old   November 9, 2022, 07:16
sina
sina_sls is on a distinguished road
Originally Posted by elcino View Post
Best regards,
I want to run fluent from matlab and i can't use AAS toolbox because i don't access to it, how can i run multiple times ?
i use it :
! "C:\Program Files\ANSYS Inc\v212\fluent\ntbin\win64\fluent.exe" 2ddp -i "C:\Users\SINA\Desktop\New_folder\15KArms.jou" '
but i want to run again this file by another journal file after finishing the first journal file i mean in following of first journal . How can i do it?
Best Regards,
sina_sls is offline   Reply With Quote
Old   November 9, 2022, 07:30
sina
Originally Posted by nenazarian View Post
Hi
doesnt work.
Cheers
Negin
i use it :
Best Regards,
How to link Fluent and MATLAB and exchange data? z701531118 FLUENT 3 October 9, 2013 15:26
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
Matlab programming for Fluent study case ASHLEY FLUENT 1 April 5, 2008 14:17
matlab for fluent punit FLUENT 0 February 9, 2006 13:09
