SGE fluent job submission script
Like Tree1Likes
  • 1 Post By stuart23
Old   April 28, 2011, 02:28
Default SGE fluent job submission script
mj
mrji8011 is on a distinguished road
Dear Friends
I am trying to run parallel fluent by script on cluster. after running my batch file, I have faced with this problem:
Initializing SGE
Done.
Cleanup script file is /home/mj00/T2,3/cleanup-fluent-node10-9832.sh
Error: No GUI functions are available.
Error Object: ()
(cx-gui-do cx-activate-item "MenuBar*ReadSubMenu*Case...")
Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
> Halting due to end of file on input.
I appreciate if you would help me
mrji8011 is offline   Reply With Quote
Old   April 28, 2011, 03:33
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
You cant record a journal file in the GUI script and then run it in batch mode on a remote host. Because the GUI is not loaded, Fluent cannot interpret what these GUI recorded commands mean. You will have to write the script using TUI commands (the same ones you would usually type in the command window)
jzc likes this.
stuart23 is offline   Reply With Quote
Old   May 5, 2011, 21:59
mj
Thank you so much for your help. I am just stranger with TUI. I run my job and I set to save data file after every 100 iteration, but I does not work. I do not know I should write command for autosave in journal file or not. I appreciate you if you help me
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Hints for Job Interview with Fluent? Andy Main CFD Forum 4 August 15, 2005 10:46
How about FLUENT user's job prospect? CFDHunnter FLUENT 3 November 5, 2003 17:01
cfd job Dr. Don I anyanwu Main CFD Forum 20 May 17, 1999 16:13
