Error: GENERAL-CAR-CDR: invalid argument [1]: improper list
Like Tree3Likes
  • 1 Post By Studen1
  • 1 Post By lukasf
  • 1 Post By Martin_Sz
Old   March 25, 2011, 08:07
Default Error: GENERAL-CAR-CDR: invalid argument [1]: improper list
Diane Davies
ddavies is on a distinguished road
I'm currently trying to run a 1mil cell mesh but everytime I load it I get the following error
Setting Post Processing and Surfaces information ...
Error Object: #f
I will also get an error stating "material air not available" but this one only appears some times. I have tried re-defining my material from the Fluent database but that doesn't work.
The above errors are preventing me from using my Parameter Set in workbench which would be very helpful to use as I have a bunch of design points I need to run. I can run my cases by manually clicking Calculate.
If it helps at all this is the error workbench gives me when I try to run a parameter set:
Error Occured during handling message in WorkBench: An error occured in FLUENT when applying cx state information.
The cortex state and surfaces could not be updated
Any help is much appreciated!!
ddavies is offline   Reply With Quote
Old   June 21, 2011, 05:55
Dan Humphreys
danhumphreys is on a distinguished road
Hi ddavies
I am having the exact same problem at the moment. Just thought I would see if you managed to find a solution?
Many thanks
Dan
danhumphreys is offline   Reply With Quote
Old   December 30, 2011, 03:47
zayzan
zayzan is on a distinguished road
Hi all, I have the same problem right now and I have been stuck to it for a while. Can you please let me know what was the problem for you guys?
Thanks
zayzan is offline   Reply With Quote
Old   January 8, 2012, 07:40
molixu is on a distinguished road
Hi,I have the same problem. Have you solved that?
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: ()
Thanks
molixu is offline   Reply With Quote
Old   January 9, 2012, 11:00
zayzan
it is a corrupted file.
Old   July 3, 2012, 10:16
Paul
pmdelgado2 is on a distinguished road
I'm using an older version of FLUENT (V6), and I am using a very large mesh as well. I get a similar error saying:
Error Object: #f
Any help would be greatly appreciated
pmdelgado2 is offline   Reply With Quote
Old   July 3, 2012, 10:17
Paul
If the mesh passes the gridcheck, how can it possibly be a corrupted file?
Old   October 1, 2012, 07:49
Clément
clauuudy is on a distinguished road
Did anyone find a solution to this problem? I'm facing the same one...
clauuudy is offline   Reply With Quote
Old   October 24, 2014, 04:35
Default solution
Studen1 is on a distinguished road
Sorry, guys, for reanimating this old post, but I found the reason. The solution is described here. Shortly, you can mark all bodies "fluid" in the DM or Meshing.
ParsaMohammadi likes this.
Studen1 is offline   Reply With Quote
Old   October 31, 2022, 09:07
Lukas Fischer
lukasf is on a distinguished road
In general CAR-CDR means a setting is missing that is needed or is wrongly set up.
Check every set-up-entry in your panels, if there are entries, which make no sense.
In my case I could not switch from transient mode to steady state. I removed one input parameter and afterwards it was working (after testing all other settings...).
lukasf is offline   Reply With Quote
Old   August 21, 2023, 09:51
Luis Paredes Yataco
Turboheld is on a distinguished road
Hi Lukas I am facing the same problem right now.
Please could you tell me which input parameter did you have to remove?
I am using fluent 2022 R2: Besides the case where I am working, I opened another case that had a steady state set up: I just changed it to transient (nothing else was modified) then I tried to go back to steady and the same error popped up:
Error Object: #f
Thanks in advance
Turboheld is offline   Reply With Quote
Old   August 24, 2023, 02:43
Lukas Fischer
in Ansys Fluent there is a section where you can define "input parameters". E.g. a variable X with a certain value.
I used an input variable to define a velocity at the inlet patch of my domain. After removing this input parameter and setting a manual value for the velocity, the Error disappeared.
Again, this was the issue in my case. You may have to find something else. If nothing works, rebuild your case from the beginning.
Turboheld likes this.
Old   August 24, 2023, 03:05
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
you can try these tips
https://howtooansys.blogspot.com/202...ar-cdr-in.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
Martin_Sz is offline   Reply With Quote
argument, error, invalid, material
Error: CDR: invalid argument [1]: wrong type [not a pair];Error Object: #f Perseu FLUENT 36 May 1, 2023 10:37
Error: invalid argument [1]: improper list Ralf Schmidt FLUENT 7 May 29, 2017 06:26
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
error: CDR: invalid argument [1]: wrong type Marc FLUENT 0 July 24, 2006 06:59
