Automatically start new calculation after the one before is completed? (FLUENT 12.1)
Like Tree5Likes
  • 1 Post By mars21t
  • 1 Post By Amir
  • 1 Post By mars21t
  • 2 Post By Amir
Old   March 14, 2011, 03:26
Default Automatically start new calculation after the one before is completed? (FLUENT 12.1)
mars21t is on a distinguished road
I have already prepared some case-files. When one calculation is done, I want that fluent reads in the next case-file and starts the new calculation automatically. Can somebody help me with this problem?
I have already tried to use macros within the “Automatic Solution Initialization and Case Modification Dialog Box”. I was able to read in the next case-file automatically after calculating some time-steps, but after the case-file was red I got this massage: “Error: Update_Time_Level: invalid data”.
Maybe it’s better to use Ansys-Workbench to do this, but I’ve no idea how to do this.
I would be very happy if anybody could help me with this problem.
Thank you!
Tobias
souza.emer likes this.
mars21t is offline   Reply With Quote
Old   March 14, 2011, 08:50
Amir's Avatar
Amir
Amir is on a distinguished road
Hi Tobias,
you can implement a journal file to automate FLUENT. you can prepare your journal file with a simple FORTRAN code... .
Amir is offline   Reply With Quote
Old   March 14, 2011, 10:10
Hello Amir,
thank you for your quick answer.
Actually I‘ve just read about the batch mode in FLUENT and the options to create transcript and journal files. Unfortunately, I couldn't find any examples how to write my own journal file with the appropriate codes in a simple Editor. Can you maybe tell me where I can find some examples for a code which I have to write in my journal file? I've never used codes before, so I've no idea how to do this, yet.
But I thought maybe it's possible to let fluent create a journal file while I'm doing the steps which I want fluent to do automatically later. Then I thought of having a look on this journal file and copy the code in my editor to create my own journal file.
Is this possible or can you give me some suggestions how I can get the code I need to solve my problem?
Thank you very much for your help, I really appreciate it.
Tobias
Old   March 14, 2011, 11:54
Amir's Avatar
Amir
you are right, you can save your steps in a file and use that as a journal file but it uses a GUI syntax and I don't prefer(sometimes it's confusing).
the other way (better one) is to use a combination of aliases and/or TUI commands in your journal. here's a part of simple journal file that I created before:
rcd data-0001.cas
/file/a/c 0
/file/a/d 0
/file/int/read 0001.int
/solve/set/eq/u yes
/solve/set/eq/f no
/define/models/dm no
/solve/dti 1    15
/file/int/write 0001.int  yes no uds-0 ()
/grid/ro -6.283185307179586232 0 0 0 0 0 1
/file/int/write 0002.int no uds-0 ()
rcd data-0002.cas
yes
the commands start with / are TUI ones that you can implement yourself to check their validity.
regards,
Amir
AHF and souza.emer like this.
Old   March 27, 2011, 10:52
Hi Amir,
thank you very much.
I finally found the answer here in this forum: http://www.cfd-online.com/Wiki/Fluent_FAQ#How_do_I_run_multiple_cases_in_batch_mo de.3F
automatically, fluent 12.1, loop, macros
gambit with linux and fluent 12.1 kharnabnew FLUENT 0 October 5, 2010 10:33
Hardware for running ANSYS Fluent 12.1 ngj_22 Hardware 2 September 29, 2010 08:26
Fluent 12.1 on Linux x64 Architecture Issue fivos FLUENT 5 April 24, 2010 16:19
reversed flow in unsteady simulation with dynamic mesh (fluent 12.1) zhaoyu_001 FLUENT 0 April 7, 2010 01:24
Fluent License Manager Start Up Script Amadou Sowe FLUENT 1 August 7, 2004 15:09
