February 18, 2011, 05:07 |
Fluent RPvar list for molar-weight
Pierre-Louis Schmitt
Rep Power: 15 |
I'm now making a UDF on which I have to use the molar-weight of some species. Does anyone know the name of the corresponding Rpvar like in the sequences RP_Get_Real("operating-pressure") or is there a list of all the accessible variables in Fluent Thanks a lot. Pilou |
February 18, 2011, 08:02 |
Martin Knob
Rep Power: 15 |
...this is for Fluent 6.3:
(sizing-function/max-resolution 30) (sizing-function/resolution 1) (dynamesh/collapse/skew-max 0.9) (smooth-mesh/min-skew 0.8) (adapt/coarsen/marker/visible? #t) (adapt/coarsen/cell/visible? #f) (adapt/coarsen/cell/filled? #f) (adapt/refine/marker/visible? #t) (adapt/refine/cell/visible? #f) (adapt/refine/cell/filled? #f) (histogram/scaling-method "") (histogram/use-scaling? #f) (fluent-case-version 63) (user-wet-steam? #f) (udws/libname "") (wetsteam/b_max 0.1) (wsr/patch 0) (wsb/patch 0) (wsn/patch 0) (wsf/default 0) (wsr/default 0) (wsb/default 0) (wsn/default 0) (wetsteam/amg-stabilization 0) (wetsteam/scheme 0) (wetsteam/amg-method 0) (wetsteam/cycle-type 0) (wetsteam/amg-beta 0.7) (wetsteam/amg-alpha 0.1) (wetsteam/relax 0.1) (wetsteam/solve? #t) (mixing-plane/reduce-backflow? #f) (mixing-plane/ave-method 0) (mixing-plane/verbos-t-enthalpy? #f) (mixing-plane/conserve-t-enthalpy? #f) (mixing-plane/verbos-swirl? #f) (mixing-plane/conserve-swirl? #f) (mixing-plane/fix-pressure-level? #f) (mixing-plane/omega 1) (mixing-planes ()) (mfinlet/allow-reverse-flow? #t) (pinlet/use-extrapolated-pressure? #f) (pinlet/enhanced-backflow? #f) (non-reflecting/verbosity 1) (non-reflecting/recon? #t) (non-reflecting/omega 0.75) (non-reflecting-bcs? #f) (target-mfr-mach 0.98) (target-mfr-pmin 1) (target-mfr-pmax 5000000) (target-mfr-urf 0.05) (target-mfr-method 1) (target-mfr-verbos? #f) (target-mfr? #t) (poutlet/p-split-back? #t) (poutlet/p-split-ausm? #t) (poutlet/ignore-back-swirl? #f) (ignition/octane-exp-gen 1) (ignition/equiv-exp-gen 1) (ignition/rpm-exp-gen 1) (ignition/temp-exp-gen 1) (ignition/press-exp-gen 1) (ignition/activate-gen 20080) (ignition/octane-gen 90) (ignition/pre-exp-gen 0.0405) (ignition/press-exp-de -1.7) (ignition/activate-de 3800) (ignition/octane-exp-de 3.402) (ignition/octane-de 90) (ignition/pre-exp-de 0.01768) (ignition/press-exp-hh 0.63) (ignition/activate-hh 618840) (ignition/cetane-hh 25) (ignition/pre-exp-hh 0.36) (ignition/dt-multiplier 3) (ignition/knock-act-temp -1507.8) (ignition/knock-pre-exp 8.6e+11) (ignition/ignite-sp-cut 0.5) (ignition/prod-fuel-cut 0.99) (ignition/burning-cutoff 1) (ignition/ignite-sp-max 5) (ignition/stoich-a-f-ratio 14.7) (ignition/fuel-species "") (ignition/amg-stabilization 0) (ignition/default 0) (ignition/patch 0) (ignition/amg-method 0) (ignition/cycle-type 0) (ignition/amg-beta 0.7) (ignition/amg-alpha 0.1) (ignition/scheme 0) (ignition/relax 0.7) (ignition/general? #f) (ignition/douaud? #f) (ignition/hardenburg? #f) (ignition/delay? #f) (ignition/knock? #f) (ignition/solve? #t) (ignition/off? #t) (spark/burn-init-fuel? #f) (spark/diffusion-time 1e-05) (spark/max-temp 2500) (spark/energy 0.1) (spark/duration 0.001) (spark/start-ca 0) (spark/start-time 0) (spark/time-exponent 0.333333) (spark/time-dep-geom? #f) (spark/fixed-geom? #f) (spark/fixed-box? #t) (spark/fixed-cylinder? #f) (spark/fixed-sphere? #f) (spark/shape "hexahedron") (spark/z-height 0.002) (spark/y-height 0.002) (spark/x-height 0.002) (spark/radius-final 0.005) (spark/radius 0.002) (spark/z-loc 0) (spark/y-loc 0) (spark/x-loc 0) (spark/off? #t) (crevice/threads ()) (crevice/unit-roundoff 1e-06) (crevice/relax 0.8) (crevice/exit-pressure 101325) (crevice/mid-gap-cd 0.7) (crevice/pressures (101325 101325 101325 101325 101325)) (crevice/bot-ring-gap (1e-05 1e-05 1e-05)) (crevice/mid-ring-gap (4e-06 4e-06 4e-06)) (crevice/top-ring-gap (1e-05 1e-05 1e-05)) (crevice/land-length (0.00391 0.00391 0.00391)) (crevice/ring-spacing (0.00391 0.00391 0.00391)) (crevice/ring-mass (0.00375 0.00375 0.00375)) (crevice/ring-thickness (0.002 0.002 0.002)) (crevice/ring-width (0.00375 0.00375 0.00375)) (crevice/piston-bore-clearance 5.08e-05) (crevice/sector-angle 360) (crevice/piston-temperature 400) (crevice/output-file "crev.out") (crevice/bore 0.1016) (crevice/n-rings 3) (crevice/ring-dynamics? #f) (crevice/write? #f) (crevice/solve? #f) (crevice/enabled? #f) (acoustics/cylindrical-export? #f) (acoustics/auto-prune? #t) (acoustics/interior-list ()) (acoustics/write-only? #f) (acoustics/write? #f) (acoustics/source-files ()) (acoustics/thread-types ()) (acoustics/required-filenames ()) (acoustics/writable-threads ()) (acoustics/required-threads ()) (acoustics/receivers ()) (acoustics/file-lines 500) (acoustics/read-and-compute? #f) (acoustics/on-the-fly? #f) (acoustics/index-filename "") (acoustics/source-filename "") (acoustics/base-filename "") (acoustics/frequency 1) (models/timer-cutoff 0.1) (charge-density/enabled? #f) (magnetic-permeability/enabled? #f) (electric-conductivity/only-const-enabled? #f) (electric-conductivity/enabled? #f) (em/model-enabled? #f) (save-cell-residuals? #f) (domains (((1 geom-domain mixture) (children) (material . air)))) (md/verbosity 1) (target/sv-list ()) (target/domain-list ()) (target/thread-list ()) (hide-cell/auto-hide? #f) (hide-cell/max-skewness 0.98) (hide-cell/thread-pairs ()) (virtual-cells ()) (turbo-vector? #f) (turbo-projection/method (0)) (turbo-search/method (1)) (turbo-grid/method (0)) (turbo/current-topology -1) (turbo/topology-count 0) (turbo/machine-type 0) (turbo/zones/blade ()) (turbo/zones/outlet ()) (turbo/zones/inlet ()) (turbo/zones/theta-periodic ()) (turbo/zones/theta-max ()) (turbo/zones/theta-min ()) (turbo/zones/shroud ()) (turbo/zones/hub ()) (turbo/topology-list ()) (turbo? #f) (network/history-file "") (save-network-history? #f) (oned/library-case "") (oned/library-name "none") (glass-model? #f) (shell/ignore-partition-check? #f) (in-plane/zero-dir (0 1 0)) (heatxc/inlet-temp/urf 0.8) (heatxc/cross-flow? #t) (heatxc/groups ()) (heatxc/geom ()) (heatxc/ntu-approach? #t) (heatxc/sv-ratio 1) (heatxc/verbosity 0) (heatxc/models (("default-model" (0.8 0.3 0.08 6 0.2 8 -0.5) ((1 1 0.67))))) (heatxc/on? #f) (case-file-units "si") (airpak-specific? #f) (temperature/split-source-by-ratio? #f) (atm-ht-v5? #f) (planar-conduction? #f) (init-fans? #f) (icepak? #f) (monitor/commands ()) (monitor/volume ()) (monitor/surfaces/windows ()) (monitor/surfaces ()) (statistics/window -1) (statistics/plot? #f) (statistics/print? #f) (statistics/monitors #f) (fmon/cm/rvz 0) (fmon/cm/rvy 0) (fmon/cm/rvx 0) (fmon/cm/about-axis "Z-Axis") (fmon/cm/window -1) (fmon/cm/per-zone? #f) (fmon/cm/plot? #f) (fmon/cm/file-name "cm-history") (fmon/cm/write? #f) (fmon/cm/print? #f) (fmon/cm/data? #f) (fmon/cm/thread-list ()) (fmon/cl/fvz 0) (fmon/cl/fvy 1) (fmon/cl/fvx 0) (fmon/cl/window -1) (fmon/cl/per-zone? #f) (fmon/cl/plot? #f) (fmon/cl/file-name "cl-history") (fmon/cl/write? #f) (fmon/cl/print? #f) (fmon/cl/data? #f) (fmon/cl/thread-list ()) (fmon/cd/window -1) (fmon/cd/fvz 0) (fmon/cd/fvy 0) (fmon/cd/fvx 1) (fmon/cd/per-zone? #f) (fmon/cd/plot? #f) (fmon/cd/file-name "cd-history") (fmon/cd/write? #f) (fmon/cd/print? #f) (fmon/cd/data? #f) (fmon/cd/thread-list ()) (file-write/particle-vars ()) (file-write/frequency 1) (autosave/file-decimal-digits 6) (autosave/file-suffix-type "time-step") (autosave/overwrite? #f) (autosave/filename "") (autosave/numfiles 0) (autosave/frequency/data 0) (autosave/frequency/case 0) (soot/inlet-diffusion? #t) (soot/two-magnus 4) (soot/two-beta 8e-14) (soot/two-alpha 100000) (soot/two-activ-energ 90000) (soot/two-exp 2.32e+17) (soot/two-linear 1e-15) (soot/two-branch 100) (soot/two-limit 1e-10) (soot/one-magnus 4) (soot/one-activ-energ 20000) (soot/one-equi-max 3) (soot/one-equi-min 1.67) (soot/one-equi-exp 3) (soot/one-cf 1.5) (soot/oxid-soot "") (soot/fuel-soot "") (soot/fuel-stoich 3.6363) (soot/soot-stoich 2.6667) (soot/soot-mean-dens 2000) (soot/soot-mean-diam 2.2e-08) (soot/radio-soot-general? #f) (soot/radio-soot-none? #t) (soot/two-step? #f) (soot/one-step? #f) (sox/h-oh-f (2.2e+10 -2 0)) (sox/so-o-r (1.90546e+14 0 124404)) (sox/so-o-f (8.70965e+09 -1.8 0)) (sox/sh-h-r (8.66961e+14 0 91247)) (sox/sh-h-f (1096.48 0 0)) (sox/so-o2-r (1663410 0 18189)) (sox/so-o2-f (446683 0 6458)) (sox/h2s-o-r (9.88553e+08 0 14420)) (sox/h2s-o-f (4365.16 0 3298)) (sox/sh-o-r (2.98539e+09 0 40484)) (sox/sh-o-f (3.54814e+08 0 642)) (sox/so-oh-r (7.6913e+09 0 28358)) (sox/so-oh-f (1.62181e+08 0 613)) (sox/h2s-oh-r (31045600 0 29111)) (sox/h2s-oh-f (138.039 0 894)) (sox/h2s-h-r (9375620 0 14940)) (sox/h2s-h-f (18197000 0 1788)) (sox/so3-o-r (100 0 9500)) (sox/so3-o-f (1200000 0 9500)) (sox/so2-o-r (7.41e+14 -1 82689)) (sox/so2-o-f (363 0 -1000)) (sox/h2-h-ratio 1) (sox/h-o-ratio 0.5) (sox/product-intermed? #f) (sox/product-so3? #f) (sox/fuel-chars-h2s-frac 0) (sox/fuel-chars-so2-frac 1) (sox/fuel-chars-convfrac 1) (sox/fuel-volts-h2s-frac 1) (sox/fuel-volts-so2-frac 0) (sox/fuel-volts-convfrac 1) (sox/fuel-fuels-h2s-frac 1) (sox/fuel-fuels-so2-frac 0) (sox/fuel-fuels-convfrac 1) (sox/fuel-char-s-to 0) (sox/fuel-s-intermediate 0) (sox/fuel-ys-char 0) (sox/fuel-ys-volatile 0) (sox/fuel-ys-fuel 0) (sox/fuel-species "") (sox/fuel-type 1) (sox/oh-mode 1) (sox/o-mode 0) (sox/turbulent-pdf-hot #f) (sox/turbulent-nint 10) (sox/turbulent-spe1 "") (sox/turbulent-mode 0) (sox/turbulent? #f) (sox/inlet-diffusion? #t) (sox/user-replace? #f) (sox/user-sox? #f) (nox/sncr-urea-n2o-m-f (6.9e+17 -2.5 64760)) (nox/sncr-urea-n2o-oh-f (2000000 0 10000)) (nox/sncr-urea-nco-oh-f (10000000 0 0)) (nox/sncr-urea-nco-no-f (10000000 0 -390)) (nox/sncr-urea-hnco-m-f (2.4e+08 0.85 68000)) (nox/sncr-urea-decomp-2 (61300 0 20980)) (nox/sncr-urea-decomp-1 (12700 0 15540)) (nox/sncr-nh3-no-f2 (0.35 7.65 125300)) (nox/sncr-nh3-n2-f2 (424 5.3 83600)) (nox/sncr-nh3-no-f (2.21e+14 0 38160)) (nox/sncr-nh3-n2-f (2.45e+14 0 29400)) (nox/reburn-oh-h2-r (452000 1.6 80815)) (nox/reburn-oh-h2-f (102000 1.6 13802)) (nox/reburn-ch1-peq-ch0 (580000 -2.64 -77077)) (nox/reburn-ch1-peq-ch1 (63000000 -3.33 15090)) (nox/reburn-ch1-peq-ch2 (0 0 0)) (nox/reburn-ch2-peq-ch0 (1.3e+08 -2.64 -77077)) (nox/reburn-ch2-peq-ch1 (1.4e+10 -3.33 15090)) (nox/reburn-ch2-peq-ch2 (2300000 -1.54 27977)) (nox/reburn-ch3-peq-ch0 (2.1e+10 -2.64 -77077)) (nox/reburn-ch3-peq-ch1 (2.3e+12 -3.33 15090)) (nox/reburn-ch3-peq-ch2 (3.7e+08 -1.54 27977)) (nox/reburn-ch4-peq-ch0 (3.06e+11 -2.64 -77077)) (nox/reburn-ch4-peq-ch1 (3.31e+13 -3.33 15090)) (nox/reburn-ch4-peq-ch2 (5.3e+09 -1.54 27977)) (nox/reburn-ch3-no (200000 0 0)) (nox/reburn-ch2-no (1400000 0 550)) (nox/reburn-ch1-no (1e+08 0 0)) (nox/n2opath-n2o-no1-r (1.45e-29 9.259 11651)) (nox/n2opath-n2o-no1-f (29000000 0 11651)) (nox/n2opath-n2-n2o-r (4e+08 0 28234)) (nox/n2opath-n2-n2o-f (4.44e+32 -8.358 28234)) (nox/fuel-char-no (230 0 34100)) (nox/fuel-nh3-no-r (1.8e+08 0 27000)) (nox/fuel-nh3-no-f (4000000 0 32000)) (nox/fuel-hcn-no-r (3e+12 0 60000)) (nox/fuel-hcn-no-f (1e+10 0 67000)) (nox/prompt-no (6400000 0 72500)) (nox/thermal-oh-pe (212.9 -0.57 4595)) (nox/thermal-o-fe (397000 -0.5 31090)) (nox/thermal-o-pe (36.64 0.5 27123)) (nox/thermal-z3-r (1.7e+08 0 24560)) (nox/thermal-z3-f (71000000 0 450)) (nox/thermal-z2-r (3810 1 20820)) (nox/thermal-z2-f (18000 1 4680)) (nox/thermal-z1-r (38000000 0 425)) (nox/thermal-z1-f (1.8e+08 0 38370)) (nox/urea-to-hnco-frac 0.45) (nox/urea-to-nh3-frac 0.55) (nox/urea-decomp-model 0) (nox/sncr-co-shift-const (17.5 68)) (nox/sncr-co-shift? #f) (nox/sncr-o2vf-limit 0) (nox/sncr-temp-max 1373) (nox/sncr-temp-min 1073) (nox/sncr-chem-model 1) (nox/sncr-pdf-f-reagent 1) (nox/sncr-pdf-stream-id 1) (nox/sncr-species "") (nox/sncr-injection-type 0) (nox/reburn-modhcn-rate 0.0004) (nox/reburn-modno-rate 0.0004) (nox/reburn-fuel-species-list ()) (nox/reburn-fuel-species "") (nox/reburn-fuel-type 0) (nox/reburn-model 0) (nox/n2opath-oh-mode 0) (nox/n2opath-o-mode 0) (nox/n2opath-n2o-model 0) (nox/fuel-nh3-switch 1) (nox/fuel-charn-nh3-frac 0) (nox/fuel-charn-hcn-frac 0) (nox/fuel-charn-nox-frac 1) (nox/fuel-charn-convfrac 1) (nox/fuel-char-n-to 3) (nox/fuel-bet-area 25000) (nox/fuel-yn-char 0) (nox/fuel-yn-volatile 0) (nox/fuel-yn-fuel 0) (nox/fuel-voltn-nh3-frac 0) (nox/fuel-voltn-hcn-frac 1) (nox/fuel-voltn-nox-frac 0) (nox/fuel-voltn-convfrac 1) (nox/fuel-fueln-nh3-frac 0) (nox/fuel-fueln-hcn-frac 1) (nox/fuel-fueln-nox-frac 0) (nox/fuel-fueln-convfrac 1) (nox/fuel-n-intermediate 2) (nox/fuel-fuel-species "") (nox/fuel-type 0) (nox/prompt-equivalence-ratio 1) (nox/prompt-carbon-number 1) (nox/prompt-fuel-species-list ()) (nox/prompt-fuel-species "") (nox/thermal-limit-switch 0) (nox/thermal-oh-mode 0) (nox/thermal-o-mode 0) (nox/turbulent-pdf-hot #f) (nox/turbulent-nint 10) (nox/turbulent-spe1 "") (nox/turbulent-mode 0) (nox/turbulent? #f) (nox/inlet-diffusion? #t) (nox/sncr-udf-replace? #f) (nox/n2opath-udf-replace? #f) (nox/fuel-udf-replace? #f) (nox/prompt-udf-replace? #f) (nox/thermal-udf-replace? #f) (nox/user-nox? #f) (nox/sncr-nox? #f) (nox/reburn-nox? #f) (nox/n2opath-nox? #f) (nox/fuel-nox? #f) (nox/prompt-nox? #f) (nox/thermal-nox? #f) (nox/max-rbfuel-spec 5) (nox/max-fuel-spec 10) (pollut_soot/eq_start 12) (pollut_sox/eq_start 7) (pollut_nuclei/patch 0) (pollut_soot/patch 0) (pollut_so/patch 0) (pollut_sh/patch 0) (pollut_so3/patch 0) (pollut_h2s/patch 0) (pollut_so2/patch 0) (pollut_nco/patch 0) (pollut_hnco/patch 0) (pollut_urea/patch 0) (pollut_n2o/patch 0) (pollut_nh3/patch 0) (pollut_hcn/patch 0) (pollut_no/patch 0) (pollutant/patch (0 0 0 0 0 0 0 0 0 0 0 0 0 0)) (pollutant/default (0 0 0 0 0 0 0 0 0 0 0 0 0 0)) (pollutant/amg-stabilization (0 0 0 0 0 0 0 0 0 0 0 0 0 0)) (pollutant/amg-method (0 0 0 0 0 0 0 0 0 0 0 0 0 0)) (pollutant/cycle-type (0 0 0 0 0 0 0 0 0 0 0 0 0 0)) (pollutant/amg-beta (0.7 0.7 0.7 0.7 0.7 0.7 0.7 0.7 0.7 0.7 0.7 0.7 0.7 0.7)) (pollutant/amg-alpha (0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1)) (pollutant/scheme (0 0 0 0 0 0 0 0 0 0 0 0 0 0)) (pollutant/relax (0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9)) (pollutant/solve? (#f #f #f #f #f #f #f #f #f #f #f #f #f #f)) (pollutant/active? (#f #f #f #f #f #f #f #f #f #f #f #f #f #f)) (dpm/latent-heat-at-boiling? #t) (dpm/absolute-pressure? #t) (dpm/raoult? #f) (dpm/multicomponent-boiling? #t) (dpm/cp-correction? #t) (dpm/rkmulticomponent? #t) (dpm/gauss-random 0.5) (dpm/random-gauss? #t) (dpm/uniform-random 0.5) (dpm/random-uniform? #t) (dpm/tracking-order-randomizations 0) (dpm/rkvaporization? #f) (dpm/minimum-vapor-fraction 0.01) (dpm/virtual-mass-factor 0.5) (dpm/pressure-force-explicit? #f) (dpm/flush-sources-at-timestep? #t) (dpm/fluid-flow-time-stepping? #t) (dpm/create-particles-with-particle-time-step? #f) (dpm/last-time-step 0) (dpm/n-time-steps 1) (dpm/time-step 0) (dpm/physical-time-step 0.001) (dpm/flow-time 0) (dpm/short-wave-airblast? #f) (dpm/stagger-factor 1) (dpm/stagger_radius_standard_inj 0) (dpm/stagger-temporally? #f) (dpm/stagger_atomizer_inj? #t) (dpm/stagger_standard_inj? #f) (dpm/wall-film-expert? #f) (dpm/film-splash-angle-slope 0.266) (dpm/film-splash-angle 65.4) (dpm/film-min-dsplash-param 0.02) (dpm/film-max-face-dist 1e-05) (dpm/film-m-imp-interaction 0) (dpm/film-p-imp-interaction 0) (dpm/film-mean-interaction 0) (dpm/film-gas-interaction #t) (dpm/film-visc-interaction #t) (dpm/film-separation-height 1e-05) (dpm/film-separation-angle 90) (dpm/pathlines-single-id -1) (dpm/pathlines-low-order? #f) (dpm/pathlines-relative? #t) (dpm/pathline-face-intersection-algorithm 0) (dpm/particle-repartition-algorithm 1) (dpm/face-intersection-algorithm 5) (dpm/display-steps 1) (dpm/lowest-mass 5.236e-25) (dpm/lowest-diameter 1e-08) (dpm/number-of-cells-to-cross 1) (dpm/acceleration-to-faces-for-rk? #t) (dpm/auto-max-step-size-refinements 20) (dpm/auto-max-error 1e-05) (dpm/auto-tracking-scheme-selection? #t) (dpm/limit-min-time-step? #t) (dpm/tracking-scheme-high 1) (dpm/tracking-scheme-low 0) (dpm/auto-step-size-control? #t) (dpm/tracking-scheme 0) (dpm/max-find-cell-depth 2000) (dpm/debug-output-level 0) (dpm/variable-interpolation? #t) (dpm/search-before-iteration? #f) (dpm/closest-face-search? #t) (dpm/pre-write-particle-check? #f) (dpm/use-face-v-with-b-injection? #t) (dpm/disallow-aborted-particles? #t) (dpm/closest-cell-search? #t) (dpm/full-pointwise-search? #f) (dpm/nd-point-search? #t) (dpm/collect-sample? #f) (dpm/sources-max-part-ap 0.1) (dpm/sources-as-in-v61? #f) (dpm/sources-delta-implicit? #t) (dpm/sources-implicit? #t) (dpm/sources-every-flow-iteration? #f) (dpm/implicit-momentum-coupling? #t) (dpm/steady-spray-cfl 5) (dpm/levich-breakup-constant 14.9) (dpm/levich-breakup-type 0) (dpm/spray-suite-consts (8 5 0.5 0.33333333 3.3333333 1 0.188 1.73 0.61 0 14.9 0.5 0.1)) (dpm/wave-mass-cutoff 0.05) (dpm/atomizer-spread-param 3.5) (dpm/tab-spread-parameter 3.5) (dpm/lower-tab-diameter-ratio 0) (dpm/number-tab-diameters 2) (dpm/random-tab-diam? #t) |
February 18, 2011, 08:03 |
Martin Knob
Rep Power: 15 |
(dpm/spray-suite-khrt? #f)
(dpm/spray-suite-wave-rayleigh-growth? #t) (dpm/spray-suite-wave-collide? #t) (dpm/spray-suite-wave? #f) (dpm/spray-suite-tab? #f) (dpm/spray-suite-break-up? #f) (dpm/spray-suite-coalescence? #t) (dpm/spray-suite-collide? #f) (dpm/pdf-tran-unsteady-rho-limit 0.1) (dpm/pdf-tran-inc-time-avg 0) (dpm/pdf-tran-num-time-avg 50) (dpm/pdf-tran-num-fv-steps 1) (dpm/pdf-tran-num-pdf-steps 1) (dpm/pdf-tran-time-step 1) (dpm/pdf-tran-freq-num 0.5) (dpm/pdf-tran-fourier-num 0.5) (dpm/pdf-tran-cfl-num 0.5) (dpm/pdf-tran-local-time-step? #t) (dpm/pdf-tran-ppc-d 0.1) (dpm/pdf-tran-ppc-c 0.1) (dpm/pdf-tran-ppc-b 0.1) (dpm/pdf-tran-ppc-a 0.1) (dpm/pdf-tran-position-correct? #f) (dpm/pdf-tran-number-control? #t) (dpm/pdf-tran-cphi 2) (dpm/pdf-tran-mixing-model 2) (dpm/pdf-tran-ta-counter 0) (dpm/pdf-tran-num-part-per-cell 20) (pdf-transport-expert? #f) (pdf-transport/solve? #t) (dpm/surface-injection-delta 1e-05) (dpm/higher-order? #t) (dpm/coupled-update? #f) (dpm/report-sig-fig 5) (dpm/track-in-absolute-frame? #f) (dpm/write-particle-history? #f) (dpm/summary ()) (dpm/turb-coupling? #f) (dpm/saffman-lift? #f) (dpm/cunningham-correction 1) (dpm/brownian-motion? #f) (dpm/drag-law "spherical") (dpm/shape-factor 1) (dpm/minimum-parcel-number 0.001) (dpm/minimum-parcel-mass 1e-15) (dpm/wall-jet-interact? #f) (dpm/particle-temperature-limiter? #f) (dpm/accumulate-rates? #f) (dpm/erosion-accretion? #f) (dpm/sort-file-append? #f) (dpm/reallocate-unsteady-coupled? #t) (dpm/unsteady-stop 0) (dpm/unsteady-start 0) (dpm/unsteady-in-domain? #f) (dpm/unsteady-tracking? #f) (dpm/thermophoretic? #f) (dpm/radiation-p #f) (dpm/ensemble-average? #t) (dpm/correlation-func 1) (dpm/max-steps 500) (dpm/length-scale 0.01) (dpm/step-length-factor 5) (dpm/use-length-scale? #f) (dpm/injections-list ()) (dpm/relax 0.5) (dpm/niter 10) (dpm/is-dpm-on #f) (dpm/particle-cache-size 0) (dpm/source-cache-size 0) (dpm/random-pool-size 0) (dpm/cache-size 1) (dpm/write-particle-data-method 1) (dpm/parallel/crossover-tolerance 0.02) (dpm/parallel/max-level-report 5) (dpm/parallel/print-verbosity 0) (dpm/parallel/lb-chunk-size 0) (dpm/parallel/max-recursion-depth 100) (dpm/parallel/homogeneous-net? #f) (dpm/distributed-memory-parallel? #t) (periodic/flood-fill-face-pairs #f) (periodic/bulk-temperature 300) (periodic/niter 2) (periodic/relax 0.5) (periodic/flow-dir-z 0) (periodic/flow-dir-y 0) (periodic/flow-dir-x 1) (periodic/pressure-derivative 0) (periodic/mass-flow 0) (periodic/specify-mass-flow? #f) (coupled-explicit/user-specified-time-interval 0) (variable-time-step/verbosity 0) (variable-time-step/undo-time-step? #f) (convergence-criteria/available? #t) (solution/converged? #f) (predict-next-time? #f) (variable-time-step? #f) (numb-fix-timesteps 1) (dt-max 10) (dt-min 1e-05) (dt-factor-max 5) (dt-factor-min 0.5) (time-end 1000) (time-err-toler 0.01) (mg/coarsen-interval 1) (mg/max-cluster-print 16) (mg/verbosity 1) (mg/print-level 0) (mg/sequence-level 0) (mg/grid-levels 0) (mg/smooth 0.5) (mg/relax 0.6) (mg/cfl-factor 0.9) (mg/iter/interp 0) (mg/iter/fine 1) (fmg-init/reorder? #t) (fmg-init/cfl 0.75) (fmg-init/conv-limit-on-level (0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001)) (fmg-init/max-fas-iterations-on-level (1 10 50 100 500 500 500 500 500 500 500 500)) (fmg-init/enable? #f) (fmg-init/verbose? #f) (fas-c/amg-stabilization 1) (fas-c/amg-method 1) (fas-c/cycle-type 1) (fas-c/amg-beta 0.7) (fas-c/amg-alpha 0.1) (amg-c/cfl-reduction-factor 0.1) (amg-c/amg-stabilization 0) (amg-c/amg-method 0) (amg-c/cycle-type 3) (amg-c/amg-beta 0.7) (amg-c/amg-alpha 0.1) (amg-c/scheme 1) (coupled-flux-method 0) (amg-coupled/max-global-cycles 20) (amg-coupled/group-size-3d 8) (amg-coupled/group-size-2d 4) (amg-coupled/max-coarse-levels 20) (amg-coupled/max-cycles 30) (amg-coupled/post-relaxations 3) (amg-coupled/pre-relaxations 0) (amg-coupled/relaxation-method "ilu") (solver/precondition/max-cycles 1) (solver/precondition/verbosity 0) (solver/precondition/scale-corrections? #f) (solver/precondition/alpha 0.3) (solver/precondition? #t) (amg/max-global-cycles 20) (amg/check-global-solution 100) (amg/memory-chunk-size 10485760) (amg/memory-chunk-use 1) (amg/malloc-oversize-percent 0) (amg/ilu-method-relax 1) (amg/ilu-cpld-relax 0.9) (amg/ilu-seg-relax 1) (amg/stabilization 0) (amg/method 0) (amg/mpi_messenger -1) (amg/v5? #f) (amg/reuse-fine-level? #t) (amg/save-temps? #t) (amg/ignore-slow-communication? #f) (amg/ignore-slow-communication-interval 1) (amg/force-slow-communication-optimization? #f) (amg/global-solve-type 1) (amg/global-solve? #t) (amg/sweep-exchange -1) (amg/schwarz? #f) (amg/tolerance 5e-06) (amg/divergence-epsilon 1000) (amg/neighbor-optimization-level 1) (amg/scale-list ()) (amg/ignore-scale-filter? #t) (amg/scale-filter? #t) (amg/scale-corrections? #t) (amg/parallel/merge-level -1) (amg/parallel/sync-interval 1) (amg/parallel/method 0) (amg/group-within-cluster? #t) (amg/relax-sweeps 2) (amg/clustering-direction 0) (amg/coordinate-clustering? #f) (amg/freeze-coarse-levels? #f) (amg/fixed-cycles -1) (amg/max-cycles 30) (amg/max-coarse-relaxations 50) (amg/max-fine-relaxations 30) (amg/group-method 0) (amg/group-size 2) (amg/max-coarse-levels 20) (amg/post-relaxations 1) (amg/pre-relaxations 0) (amg/verbosity 0) (relaxation-method "gauss-seidel") (use-operating-density? #f) (operating-density 1.225) (operating-temperature 288.16) (body-force/relax 1) (implicit-bf? #f) (z-pull-velocity/patch 0) (y-pull-velocity/patch 0) (x-pull-velocity/patch 0) (pull/niter 1) (pull/max-iter 5) (pull/explicit-relax 1) (pull/residual-tolerance 0.0001) (pull/iter-tolerance 0.05) (pull/amg-stabilization 0) (pull/amg-method 0) (pull/cycle-type 1) (pull/amg-beta 0.7) (pull/amg-alpha 0.0001) (pull/scheme 10) (pull/solve? #f) (melt/u-us-term? #f) (melt/mushy-zone-constant 100000) (delh/patch 0) (delh/n-sweeps 5) (delh/default 0) (delh/relax 0.9) (premixc/explicit-relax 1) (premixc/residual-tolerance 0.0001) (premixc/iter-tolerance 0.05) (premixc/max-iter 5) (premixc/default 1) (premixc/patch 0) (premixc/amg-stabilization 0) (premixc/amg-method 0) (premixc/cycle-type 0) (premixc/amg-beta 0.7) (premixc/amg-alpha 0.1) (premixc/scheme 0) (premixc/relax 0.9) (premixed/solve? #t) (ufla-y/default 0) (ufla-y/patch 0) (ufla-y/amg-stabilization 0) (ufla-y/amg-method 0) (ufla-y/cycle-type 0) (ufla-y/amg-beta 0.7) (ufla-y/amg-alpha 0.1) (ufla-y/scheme 0) (ufla-y/relax 1) (ufla-y/solve? #t) (vd-fvar/default 0) (vd-fvar/patch 0) (vd-fvar/amg-stabilization 0) (vd-fvar/amg-method 0) (vd-fvar/cycle-type 0) (vd-fvar/amg-beta 0.7) (vd-fvar/amg-alpha 0.1) (vd-fvar/scheme 0) (vd-fvar/relax 0.9) (vc-fvar/default 0) (vc-fvar/patch 0) (vc-fvar/amg-stabilization 0) (vc-fvar/amg-method 0) (vc-fvar/cycle-type 0) (vc-fvar/amg-beta 0.7) (vc-fvar/amg-alpha 0.1) (vc-fvar/scheme 0) (vc-fvar/relax 0.9) (ic-fvar/default 0) (ic-fvar/patch 0) (ic-fvar/amg-stabilization 0) (ic-fvar/amg-method 0) (ic-fvar/cycle-type 0) (ic-fvar/amg-beta 0.7) (ic-fvar/amg-alpha 0.1) (ic-fvar/scheme 0) (ic-fvar/relax 0.9) (micro-mix/real-consts (2 1.86 0.058 0.303 17050)) (species/micro-mixing? #f) (fvar2/explicit-relax 1) (fvar2/residual-tolerance 0.0001) (fvar2/iter-tolerance 0.05) (fvar2/max-iter 5) (fvar2/default 0) (fvar2/patch 0) (fvar2/amg-stabilization 0) (fvar2/amg-method 0) (fvar2/cycle-type 0) (fvar2/amg-beta 0.7) (fvar2/amg-alpha 0.1) (fvar2/scheme 0) (fvar2/relax 0.9) (fvar/explicit-relax 1) (fvar/residual-tolerance 0.0001) (fvar/iter-tolerance 0.05) (fvar/max-iter 5) (fvar/default 0) (fvar/patch 0) (fvar/amg-stabilization 0) (fvar/amg-method 0) (fvar/cycle-type 0) (fvar/amg-beta 0.7) (fvar/amg-alpha 0.1) (fvar/scheme 0) (fvar/relax 0.9) (fmean2/explicit-relax 1) (fmean2/residual-tolerance 0.0001) (fmean2/iter-tolerance 0.05) (fmean2/max-iter 5) (fmean2/default 0) (fmean2/patch 0) (fmean2/amg-stabilization 0) (fmean2/amg-method 0) (fmean2/cycle-type 0) (fmean2/amg-beta 0.7) (fmean2/amg-alpha 0.1) (fmean2/scheme 0) (fmean2/relax 1) (fmean/explicit-relax 1) (fmean/residual-tolerance 0.0001) (fmean/iter-tolerance 0.05) (fmean/max-iter 5) (fmean/default 0) (fmean/patch 0) (fmean/amg-stabilization 0) (fmean/amg-method 0) (fmean/cycle-type 0) (fmean/amg-beta 0.7) (fmean/amg-alpha 0.1) (fmean/scheme 0) (fmean/relax 1) (prepdf/nfb2 21) (pdf/multi-tabulation? #f) (prepdf/compress-op-pres 101325) (chemkin-import-name-editable? #t) (prepdf/empirical-secondary-mw 0) (prepdf/empirical-fuel-mw 0) (prepdf/liquid-fsto 0.5) (prepdf/ufla-cfl 1) (prepdf/ufla-max-scal-diss 30) (prepdf/ufla-f-init-hi 1) (prepdf/ufla-f-init 0.1) (prepdf/ufla-h-relax 0.01) (prepdf/ufla-frac-heat-loss-pts 0.75) (prepdf/ufla-num-h-pts 10) (prepdf/ufla-y-slow "no") (prepdf/ufla-num-y-slow-pts 20) (prepdf/ufla-x0 10) (prepdf/ufla-res-time 1) (prepdf/ufla? #f) (prepdf/unsteady-flamelet? #f) (prepdf/default-thermo-db-fname "") (prepdf/mf-method 0) (prepdf/frozen-boundaries 1) (prepdf/max-species 20) (prepdf/nne 41) (prepdf/nfl 21) (prepdf/nfb 31) (prepdf/calculate? #f) (prepdf/function-type 1) (prepdf/type 3) (prepdf/stoich (1 2 -1 -2)) (prepdf/include-equil-flamelet? #t) (prepdf/flamelet-generate? #f) (prepdf/flamelet-bool-params (#t #t)) (prepdf/flamelet-real-params (0.01 5 1 2 1e-10 1e-14 1e-05 1000)) (prepdf/flamelet-int-params (10 32)) (prepdf/expert-real-params (1 0.667 0.25 0.99)) (prepdf/equil-real-params (0.1 0.1 50000000 1000 50000000 1000 298)) (prepdf/flags (#t #f #f #f)) (prepdf/bc ((300 300 300) (#t) ((o2 0 0.233 0) (n2 0 0.767 0)))) (prepdf/equil-exclude-species ("no" "no2" "n2o" "h2o<l>" "c<s>" "n" "nh" "nh2" "nh3" "nnh" "hcn" "hno" "cn" "h2cn" "hcnn" "hcno" "hocn" "hnco")) (prepdf/equil-include-species ()) (prepdf/bc-species ("ch4" "h2" "jet-a<g>" "n2" "o2")) (pdf/bounded-interp #f) (pdf/dynamic-fvar? #t) (pdf/solve-les-variance-eqn? #f) (pdf/warnings #f) (pdf/flamexpert #f) (pdf/fvarlim 0.001) (pdf/flampar 1) (pdf/flammult 3) (pdf/flamtype 0) (pdf/sct 0.85) (pdf/compressible? #f) (pdf/function-type 1) (pdf/n-iter-flam 5) (pdf/n-iter 10) (flamelet/filename "") (pdf/filename "") (pdf/solve? #t) (cdvar 2) (cgvar 2.86) (rfg/limit-length-scale #f) (rfg/limit-wave-number #t) (rfg/number-of-fourier-modes 100) (sngr/number-of-realizations 200) (sngr/number-of-fourier-modes 50) (acoustics/sliding-mesh-time-ref -1) (acoustics/number-of-revolutions 2) (acoustics/time-steps-per-revolution 360) (acoustics-sample-duration 0) (acoustics-no-of-samples 0) (far-field-sound-speed 340) (far-field-pressure 0) (far-field-density 1.225) (reference-acoustic-intensity 1e-12) (reference-acoustic-power 1e-12) (reference-acoustic-pressure 2e-05) (acoustics/2d-nfaces 40) (acoustics/2d-correl-length 1) (source-location/z 0) (source-location/y 0) (source-location/x 0) (receiver-location/z 0) (receiver-location/y 1) (receiver-location/x 1) (acoustics/compute-sound? #t) (acoustics/export-fluid-zones 0) (acoustics/write-source? #f) (acoustics/on? #f) (wf/vwplus-max 0.6) (wf/vwplus-min -0.04) (wf/gamma-max 1) (wf/gamma-min 0.005) (wf/beta-max 0.01) (wf/beta-min -0.02) (wf/yp-prg 60) (wf/cmp-effects-excluded? #f) (wf/ht-effects-excluded? #f) (wf/heat-transfer-effects? #f) (wf/pressure-gradient-effects? #f) (uw-stress/patch 0) (vw-stress/patch 0) (uv-stress/patch 0) (ww-stress/patch 1) (vv-stress/patch 1) (uu-stress/patch 1) (drsm/coupling-alt-average? #f) (drsm/amg-stabilization 0) (drsm/amg-method 0) (drsm/cycle-type 0) (drsm/amg-beta 0.7) (drsm/amg-alpha 0.1) (drsm/max-iter 5) (drsm/residual-tolerance 0.0001) (drsm/iter-tolerance 0.05) (drsm/explicit-relax 1) (drsm/scheme 0) (drsm/relax 0.5) (drsm/solve? #t) (drsm/secondary-gradient? #f) (omega/default 1) (omega/patch 1) (omega/amg-stabilization 0) (omega/amg-method 0) (omega/cycle-type 0) (omega/amg-beta 0.7) (omega/amg-alpha 0.1) (omega/scheme 0) (omega/max-iter 5) (omega/residual-tolerance 0.0001) (omega/iter-tolerance 0.05) (omega/explicit-relax 1) (omega/relax 0.8) (omega/min-limit 1e-20) (kw/solve? #t) (lowre-ke-index 0) (ke-low-re? #f) (kl/default 1e-06) (kl/patch 1e-06) (kl/amg-stabilization 0) (kl/amg-method 0) (kl/cycle-type 0) (kl/amg-beta 0.7) (kl/amg-alpha 0.1) (kl/scheme 0) (kl/max-iter 5) (kl/residual-tolerance 0.0001) (kl/iter-tolerance 0.05) (kl/explicit-relax 1) (kl/relax 0.8) (kl/min-limit 1e-14) (f/default 1) (f/patch 1) (f/amg-stabilization 0) (f/amg-method 0) (f/cycle-type 0) (f/amg-beta 0.7) (f/amg-alpha 0.1) (f/scheme 0) (f/max-iter 5) (f/residual-tolerance 0.0001) (f/iter-tolerance 0.05) (f/explicit-relax 1) (f/relax 0.8) (v2/default 0.666667) (v2/patch 1) (v2/amg-stabilization 0) (v2/amg-method 0) (v2/cycle-type 0) (v2/amg-beta 0.7) (v2/amg-alpha 0.1) (v2/max-iter 5) (v2/residual-tolerance 0.0001) (v2/iter-tolerance 0.05) (v2/explicit-relax 1) (v2/scheme 0) (v2/relax 0.8) (v2f-f/min-limit 1e-07) (v2f-v2/min-limit 1e-07) (v2f-epsilon/min-limit 1e-07) (v2f-k/min-limit 1e-07) (epsilon/default 1) (epsilon/patch 1) (epsilon/amg-stabilization 0) (epsilon/amg-method 0) (epsilon/cycle-type 0) (epsilon/amg-beta 0.7) (epsilon/amg-alpha 0.1) (epsilon/scheme 0) (epsilon/max-iter 5) (epsilon/residual-tolerance 0.0001) (epsilon/iter-tolerance 0.05) (epsilon/explicit-relax 1) (epsilon/relax 0.8) (epsilon/min-limit 1e-20) (k/default 1) (k/patch 1) (k/amg-stabilization 0) (k/amg-method 0) (k/cycle-type 0) (k/amg-beta 0.7) (k/amg-alpha 0.1) (k/scheme 0) (k/max-iter 5) (k/residual-tolerance 0.0001) (k/iter-tolerance 0.05) (k/explicit-relax 1) (k/relax 0.8) (k/min-limit 1e-14) (ke/compr-effects-for-vof? #f) (ke/buoyancy-production? #f) (ke/solve? #t) (ke/secondary-gradient? #f) (nut/default 0.1) (nut/patch 0.1) (nut/amg-stabilization 0) (nut/amg-method 0) (nut/cycle-type 0) (nut/amg-beta 0.7) (nut/amg-alpha 0.1) (nut/scheme 0) (nut/max-iter 5) (nut/residual-tolerance 0.0001) (nut/iter-tolerance 0.05) (nut/explicit-relax 1) (nut/relax 0.8) (nut/wall-value? #t) (nut/damping? #t) (nut/solve? #t) (nut/secondary-gradient? #f) (sgske/default 0.01) (sgske/patch 0.01) (turb-viscosity/max-limit 100000) (turb-viscosity/relax 1) (turb/hyd-dia-factor 0.07) (w-swirl/amg-stabilization 0) (w-swirl/amg-method 0) (w-swirl/cycle-type 0) (w-swirl/amg-beta 0.7) (w-swirl/amg-alpha 0.1) (w-swirl/scheme 0) (w-swirl/max-iter 5) (w-swirl/residual-tolerance 0.0001) (w-swirl/iter-tolerance 0.05) (w-swirl/explicit-relax 1) (w-swirl/relax 0.9) (w-swirl/solve? #t) |
February 18, 2011, 08:04 |
Martin Knob
Rep Power: 15 |
(pb-smm/kv 0.52359878)
(pb-smm/default (0)) (pb-smm/patch (0)) (pb-smm/amg-stabilization (0)) (pb-smm/cycle-type (0)) (pb-smm/amg-method (0)) (pb-smm/amg-beta (0.7)) (pb-smm/amg-alpha (0.1)) (pb-smm/scheme (0)) (pb-smm/relax (1)) (pb-smm/solve? (#t)) (pb-smm/n-pb-smm 2) (pb-qmom/kv 0.52359878) (pb-qmom/ka 3.1415926) (pb-qmom/default (0)) (pb-qmom/patch (0)) (pb-qmom/amg-stabilization (0)) (pb-qmom/cycle-type (0)) (pb-qmom/amg-method (0)) (pb-qmom/amg-beta (0.7)) (pb-qmom/amg-alpha (0.1)) (pb-qmom/scheme (0)) (pb-qmom/relax (1)) (pb-qmom/solve? (#t)) (pb-qmom/n-pb-qmom 6) (pb-disc/kv 0.52359878) (pb-disc/ka 3.1415926) (pb-disc/bin-size-inp-type 0) (pb-disc/bin-sizes (0.01 0.01259921)) (pb-disc/default (0)) (pb-disc/patch (0)) (pb-disc/amg-stabilization (0)) (pb-disc/cycle-type (0)) (pb-disc/amg-method (0)) (pb-disc/amg-beta (0.7)) (pb-disc/amg-alpha (0.1)) (pb-disc/scheme (0)) (pb-disc/relax (1)) (pb-disc/solve? (#t)) (pb-disc/n-pb-disc 2) (pb/sg-pb-smm? #f) (pb/sg-pb-qmom? #f) (pb/sg-pb-disc? #f) (pb/coalescence-rate 0) (pb/growth-rate 0) (pb/nucleation-rate 0) (pb/phenomenon (#f #f #f #f #f)) (pb/domain-id 3) (mp/population-b? #f) (density/scheme 0) (density/relax 1) (mp/multi-domain? #t) (granular-temperature/secondary-gradient? #f) (granular-temperature/syam-algebraic? #t) (granular-temperature/amg-stabilization 0) (granular-temperature/amg-method 0) (granular-temperature/cycle-type 0) (granular-temperature/amg-beta 0.7) (granular-temperature/amg-alpha 0.1) (granular-temperature/scheme 0) (granular-temperature/relax 0.2) (granular-temperature/solve? #t) (granular/pde? #f) (granular-pressure/pp? #f) (mp-rsm-type 0) (mp-sig-v 0.75) (mp-kec3 1.3) (mp-ke-type 0) (drift/relax 0.1) (drift/solve? #t) (mp/cvt/n-bubbles 10000) (mp/cvt/vapor-p 2367.8) (mp/cvt/cav-p-coeff-v62 1) (mp/cvt/cav_p_coeff 1) (mp/cvt/surface-tension 0.0717) (mp/cvt/con-coeff-mspe 1) (mp/cvt/con-coeff 0.01) (mp/cvt/evap-coeff 0.02) (mp/cvt/ncg-molecular-weight 29) (mp/cvt/ncgs-mspe 1.5e-05) (mp/cvt/non-condensable-gas 1.5e-05) (mp/cvt/operating-temperature 300) (cvt/total-gas-vof? #t) (cvt/gui-new? #t) (cvt/model-new? #t) (cvt/rho-mixture? #f) (cvt/model-v5? #f) (cvt/relax-par 1) (cvt/relax 1) (mp/mt/udf/linearized? #f) (mp/rc-flux-solids-p? #t) (mp/htrxn/heat-transfer? #t) (mp/htrxn/mom-transfer? #t) (mp/mt/heat-transfer? #t) (mp/mt/mom-transfer? #t) (mp/mass-trans-type 0) (mp/terminal-velocity 0) (mp/cn-scheme-alpha 0.55) (mp/cn-scheme? #f) (mp/extrap-p? #f) (mp/amg-stabilization 0) (mp/amg-method 0) (mp/cycle-type 0) (mp/amg-beta 0.7) (mp/amg-alpha 0.1) (mp/scheme 0) (mp/max-iter 5) (mp/residual-tolerance 0.0001) (mp/iter-tolerance 0.05) (mp/explicit-relax 1) (mp/relax 0.2) (mp/courant-number 0.25) (mp/scheme-type 1) (mp/every-iter? #f) (mp/solve? #t) (mp/min-phase-number 2) (mp/n-materials 1) (mp/frozen-flux? #f) (sg-vflux? #f) (mxt-drift-dispersion? #f) (mp-drift-source-ke? #f) (mp-drift-source-mom? #f) (mp/face-pressure? #t) (mp/ref 0) (mp/fpi 1) (oc-po-list ()) (oc-mfi-list ()) (oc-pi-list ()) (vof/ntime-froud-update 1) (vof/niter-froud-update 50) (vof/open-channel? #f) (vof/node-alloc-oc? #f) (vof/smoothing-factor 1) (vof/smoothing-num 1) (vof/node-based-gradients? #t) (vof/node-based-deriv? #f) (piso/pboundary/update-flux? #f) (face-pressure/scheme 0) (piso/scheme 0) (pressure/node-based-pp-grad 1) (pressure/skew-relax 1) (piso/coupling? #t) (piso/neighbor-iter 1) (frstep/skew-iter 0) (simplec/skew-iter 0) (piso/skew-iter 1) (flow/scheme 20) (udm/n-udm 0) (udm/patch ()) (uds/variables ()) (uds/diffusion-long? #f) (uds/inlet-diffusion? #t) (uds/default (0)) (uds/patch (0)) (uds/amg-stabilization (0)) (uds/amg-method (0)) (uds/cycle-type (0)) (uds/amg-beta (0.7)) (uds/amg-alpha (0.1)) (uds/scheme (0)) (uds/relax (1)) (uds/solve? (#t)) (uds/n-uds 0) (stiff-chem-seg-dt 0.1) (stiff-chem-seg? #f) (stiff-solver/temp-time-redux 0.25) (stiff-solver/chem-time-ratio 0.9) (stiff-solver? #f) (species/surf-react-apfac 0) (species/save-gradients? #f) (species/kinetics/trans-file? #f) (species/kinetics/cell-monitor-list ()) (species/kinetics/arbit-value 0) (species/kinetics/arbit-string "") (species/kinetics/aux-file "") (species/kinetics/cons-noneg-mf 1) (species/kinetics/small-plus 1e-12) (species/kinetics/min-surf-mf -0.0001) (species/kinetics/max-surf-mf 1.1) (species/kinetics/min-gas-mf -1e-12) (species/kinetics/max-gas-mf 1.01) (species/kinetics/steady-max-attempts 1) (species/kinetics/init-time-step 0) (species/kinetics/min-time-step 1e-10) (species/kinetics/max-time-step 0.01) (species/kinetics/steady-time-step 0.0001) (species/kinetics/steady-time-marching 1) (species/kinetics/surf-rel-tol 0.0001) (species/kinetics/surf-abs-tol 1e-08) (species/kinetics/gas-rel-tol 0.0001) (species/kinetics/gas-abs-tol 1e-08) (species/kinetics/print-level 0) (species/carm 0) (species/chem-step-ensemble? #f) (species/kinetics? #f) (species/chemical-equilibrium? #f) (chemkin-names ("chemkin-import" "" "" "" "")) (species/isat-file "/home/knob/Saport/Hyhlik/tom") (species/isat-dtref 0.001) (species/isat-verbosity 0) (species/isat-stomby 100) (species/isat-errtol 0.001) (species/isat-ntree 1) (species/isat? #t) (species/ode-rtol 1e-09) (species/ode-atol 1e-08) (species/edc-apmax-fac 0) (species/edc-reactor-type 1) (species/edc-niter 1) (species/edc-c2 0.40825) (species/edc-c1 2.1377) (species/edc? #f) (species/thermal-diffusion? #f) (species/multicomponent-diffusion? #f) (species/inlet-diffusion? #t) (species/surface-heat-react? #t) (species/sct 0.7) (reactions/relax 1) (reactions/solve? #t) (species/reaction-model "finite-rate") (species/default (0)) (species/patch (0)) (species/amg-stabilization (0)) (species/amg-method (0)) (species/cycle-type (0)) (species/amg-beta (0.7)) (species/amg-alpha (0.1)) (species/max-iter (5)) (species/residual-tolerance (0.0001)) (species/iter-tolerance (0.05)) (species/explicit-relax (1)) (species/scheme (0)) (species/relax (1)) (species/solve? (#t)) (enthalpy/default 0) (enthalpy/patch 0) (enthalpy/amg-stabilization 0) (enthalpy/amg-method 0) (enthalpy/cycle-type 0) (enthalpy/amg-beta 0.7) (enthalpy/amg-alpha 0.1) (enthalpy/max-iter 5) (enthalpy/residual-tolerance 0.0001) (enthalpy/iter-tolerance 0.05) (enthalpy/explicit-relax 1) (enthalpy/scheme 0) (enthalpy/relax 1) (enthalpy/solve? #t) (solar/filename "") (solar/binary? #t) (solar/frequency-data 0) (sol/apply-do-bc? #f) (sol/load-on-fluid? #f) (sol/iterations 10) (sol/max_level 7) (sol/initial-time? #f) (sol/method-trans 0) (sol/nrel? #f) (sol/cx 0.2) (sol/sin_altitude 0.2) (sol/rho_g 0.2) (sol/sunshine_frac 1) (sol/scat_frac 1) (sol/diffuse-entry-angle? #f) (sol/diff_angle 1.0471974) (sol/method-diff_int ()) (sol/method-intensity ()) (sol/diff_int 200) (sol/intensity 1423) (sol/dir-from-calc #t) (sol/sun_z 1) (sol/sun_y 0) (sol/sun_x 0) (sol/split 0.5) (solpos/longitude -1.4770719) (solpos/latitude 0.23823741) (solpos/timezone -5) (solpos/minute 0) (solpos/hour 13) (solpos/month 6) (solpos/day 21) (sol/east_z 0) (sol/east_y 0) (sol/east_x 1) (sol/north_z 0) (sol/north_y 1) (sol/north_x 0) (solar/solve? #f) (disco/normal-collimated-beam? #f) (disco/solar? #f) (disco/coupled-verbosity 0) (hybrid/do-rosseland? #f) (disco/amg-tolerance 1e-06) (disco/bands ()) (disco/inner-iterations 2) (disco/reduced-storage? #f) (disco/pixel/nphi 1) (disco/pixel/ntheta 1) (disco/interior-pixels? #f) (disco/nphi 2) (disco/ntheta 2) (disco/type "finite-volume") (disco/blending-factor 1) (disco/scheme 0) (disco/amg-min-cycles 2) (disco/amg-stabilization 0) (disco/amg-method 0) (disco/cycle-type 0) (disco/amg-beta 0.7) (disco/amg-alpha 0.1) (disco/relax 1) (disco/solve-method 0) (disco/partially-specular-method 1) (disco/partially-specular? #f) (disco/partial-solve? #f) (disco/full-solve? #t) (disco/coupled-fine-iter 5) (disco/coupled? #f) (disco/solve? #t) (g/default 0) (g/patch 0) (p1/amg-stabilization 0) (p1/amg-method 0) (p1/cycle-type 0) (p1/amg-beta 0.7) (p1/amg-alpha 0.1) (p1/relax 0.8) (p1/solve? #t) (mpcci-update-interval 1) (s2s/partial-enclosure-emissivity 1) (s2s/partial-enclosure-t 300) (s2s/dual? #t) (s2s/fast-parallel? #t) (s2s/new-algo? #t) (s2s/viewfactor-crf? #t) (s2s/viewfactor-compression? #t) (s2s/partial-enclosure? #f) (s2s/vf-loadbalance -1) (s2s/vf-use-bsp 0) (s2s/vf-sampling-method 0) (s2s/vf-partial-asink 1) (s2s/vf-partial-enclosure 0) (s2s/vf-simple-enclosure 0) (s2s/vf-hemi-separation 5) (s2s/vf-hemi-subdivide 10) (s2s/vf-hemi-resolution 10) (s2s/vf-smoothing-tol 1e-06) (s2s/vf-smoothing-iter 100) (s2s/vf-smoothing 0) (s2s/vf-method 1) (s2s/vf-type 1) (s2s/glob-file "") (s2s/split-angle 20) (s2s/glob-expert? #f) (s2s/flow-face-glob-size 1) (s2s/glob-size 1) (s2s/tol 0.001) (s2s/n-sweeps 5) (s2s/n-iter 10) (vfr/partial-enclosure-emissivity 1) (vfr/partial-enclosure-t 300) (vfr/partial-enclosure? #f) (dtrm/solve? #f) (dtrm/rays-file "") (dtrm/face-glob-size 1) (dtrm/glob-size 1) (dtrm/tol 0.001) (dtrm/n-sweeps 1) (dtrm/n-iter 10) (enable-beta-rad-features? #f) (temperature/explicit-relax? #f) (temperature/shell-secondary-gradient? #t) (temperature/secondary-gradient? #t) (temperature/skew-grid? #f) (temperature/max-limit 5000) (temperature/min-limit 1) (temperature/default 300) (temperature/patch 0) (temperature/amg-stabilization 0) (temperature/amg-method 0) (temperature/cycle-type 0) (temperature/amg-beta 0.7) (temperature/amg-alpha 0.1) (temperature/max-iter 5) (temperature/residual-tolerance 0.0001) (temperature/iter-tolerance 0.05) (temperature/explicit-relax 1) (temperature/scheme 0) (temperature/relax 1) (temperature/solve? #t) (energy/inlet-diffusion? #t) (energy/user-definable-cp? #f) (energy/kinetic? #f) (energy/pressure-work? #f) (energy/conservative-form? #t) (energy/species-diffusion? #t) (low-pressure-slip? #f) (viscous-energy-dissipation? #f) (continuity/surf-spe-source? #f) (time_factor_site 1) (porous/physical-velocity-form? #f) (sigma-sbc 5.669e-08) (pressure/convert-nci-flux? #f) (pressure/porous-jump-old? #f) (pressure/conv-relax? #f) (pressure/unsteady-rc 1) (pressure/mp-dissipation? #t) (pressure/rc-dissipation-new? #t) (pressure/dissipation? #f) (pressure/enthalpy-correct? #f) (pressure/frozen-flux? #f) (pressure/unsteady? #t) (pressure/isotrop-rc? #f) (pressure/ho-rc-disable? #f) (pressure/ho-rc 2) (pressure/presto-low-order? #f) (pressure/extrapolate-inlet? #t) (pressure/extrapolate-all? #f) (pressure-coupled/implicit-dissipation-bndr? #t) (pressure-coupled/implicit-dissipation? #t) (pressure-coupled/update-pgrad? #t) (pressure-coupled/update-deriv? #t) (pressure-coupled/pressure/explicit-relax 0.75) (pressure-coupled/mom/explicit-relax 0.75) (pressure-coupled/courant-number 200) (pressure-coupled/restart? #f) (pressure-coupled/omega 1) (pressure-coupled/amg-stabilization 0) (pressure-coupled/amg-method 0) (pressure-coupled/cycle-type 3) (pressure-coupled/amg-beta 0.7) (pressure-coupled/amg-alpha 0.1) (pressure/coupled-nonlinear? #f) (pressure/coupled-pressure-delta-form? #t) (pressure/coupled-velocity-delta-form? #t) (pressure/coupled-dissipation 0) (pressure/coupled-available? #f) (pressure/max-iter 10) (pressure/residual-tolerance 0.0001) (pressure/iter-tolerance 0.25) (pressure/max-limit 5e+10) (pressure/min-limit 1) (pressure/default 0) (pressure/patch 0) (pressure/amg-stabilization 0) (pressure/amg-method 0) (pressure/cycle-type 1) (pressure/amg-beta 0.7) (pressure/amg-alpha 0.1) (cavitation/pressure-bc? #t) (cavitation/enhancement? #t) (compress-p/relax? #f) (pressure-correction/relax-enhance 0.1) (pressure-correction/relax-drdp 1) (pressure-correction/relax 0.7) (pressure/explicit-relax 1) (pressure/relax 0.3) (pressure/scheme 10) (2nd-order-time/blend-factor 1.5) (2nd-order-time/bounded? #t) (z-velocity/default 0) (y-velocity/default 0) (x-velocity/default 0) (z-velocity/patch 0) (y-velocity/patch 0) (x-velocity/patch 0) (z-mom/amg-stabilization 0) (z-mom/amg-method 0) (z-mom/cycle-type 0) (z-mom/amg-beta 0.7) (z-mom/amg-alpha 0.1) (y-mom/amg-stabilization 0) (y-mom/amg-method 0) (y-mom/cycle-type 0) (y-mom/amg-beta 0.7) (y-mom/amg-alpha 0.1) (x-mom/amg-stabilization 0) (x-mom/amg-method 0) (x-mom/cycle-type 0) (x-mom/amg-beta 0.7) (x-mom/amg-alpha 0.1) (mom/extrapolate-outflow? #f) (mom/rot-cyclic-explicit? #t) (mom/from-flux? #t) (mom/nita/update-derivatives? #t) (mom/nita-flux-update? #t) (mom/update-flux-subiter? #f) (mom/max-iter 5) (mom/residual-tolerance 0.0001) (mom/iter-tolerance 0.05) (mom/scheme 0) (mom/explicit-relax 1) (mom/relax 0.7) (explicit-relaxation? #f) (implicit-relaxation? #t) (noniterative-max-iter 1) (noniterative-time-advance? #f) (old-unsteady-flux? #t) (roe-dissipation? #f) (solve-absolute-velocities? #t) (correct-velocity? #t) (flow/solve? #t) (residuals/convergence-criterion-type 0) (residuals/scale? #t) (residuals/normalize? #f) (residuals/debug? #f) (residuals/n-display 1000) (residuals/n-save 1000) (residuals/window -1) (residuals/plot? #f) (residuals/print? #t) (residuals/n-maximize-norms 5) (residuals/settings #f) (vof/remove-small-bubbles? #f) (vof/redistribute-lost-volume? #t) (vof/use-polyhedra? #t) (vof/improved-wall-treatment? #t) (vof/courant-calculation-method 1) (vof/courant-based-time-step? #f) (vof/global-courant-number 2) (vof/update-method 4) (patch/m1-m2? #t) (patch/vof? #f) (patch-relative? #t) (init-relative? #t) (profile/morphing? #f) (profile/update-interval 1) (udrg/libname "") (real-gas/mixturefilename "") (real-gas/datafiles-list ()) (real-gas/datanames-list ()) (real-gas/dataname "") (real-gas/datadir "") (real-gas/libdir "") (user-real-gas-multi-component? #f) (user-real-gas? #f) (real-gas-multi-component? #f) (real-gas? #f) (udf/pb-coalescence-rate-name "Luo Model") (udf/pb-break-up-rate-name "Luo Model") (udf/pb-growth-rate-name "constant") (udf/pb-nucleation-rate-name "constant") (udf/deltat-fcn "none") (udf/solar-trans "none") (udf/dom/specular-reflectivity "none") (udf/dom/diffuse-reflectivity "none") (udf/dom/bc-adjust "none") (udf/dom/source-fcn "none") (udf/viscous/wall-law-fcn "none") (udf/viscous/prt-t-wall-fcn "none") (udf/viscous/prt-t-fcn "none") (udf/viscous/prt-o-fcn "none") (udf/viscous/prt-d-fcn "none") (udf/viscous/prt-k-fcn "none") (udf/viscous/mu-t-fcn "none") (udf/cphi-fcn "none") (udf/chem-step-fcn "none") (udf/cav-rate-fcn "none") (udf/sox-rate-fcn "none") (udf/nox-rate-fcn "none") (udf/execute-at-exit-fcns ()) (udf/write-data-fcns ()) (udf/read-data-fcns ()) (udf/write-case-fcns ()) (udf/read-case-fcns ()) (udf/drift-diam-fcn "constant") (udf/dpm/n-reals 0) (udf/dpm/timestep-fcn "none") (udf/dpm/spray-collide-fcn "none") (udf/dpm/scalar-fcn "none") (udf/dpm/erosion-fcn "none") (udf/dpm/output-fcn "none") (udf/dpm/source-fcn "none") (udf/dpm/body-force-fcn "none") (udf/dpm/drag-fcn "none") (udf/heat-flux-fcn "none") (udf/trb-prmx-src-fcn "none") (udf/pr-rate-fcn "none") (udf/sr-rate-fcn "none") (udf/vr-rate-fcn "none") (udf/net-reaction-rate-fcn "none") (udf/execute-at-end-fcns ()) (udf/adjust-fcns ()) (udf/init-fcns ()) (udf/libname ()) (udf/listing? #f) (udf/stack-size 10000) (udf/cpp-command "cpp") (udf/use-contrib-cpp? #f) (udf/filename "") (user-fan/program-name "fan-model") (user-fan/update-interval 10) (user-fan/profile-points 20) (user-fan/fan-zones ()) (title "") |
February 18, 2011, 08:05 |
Martin Knob
Rep Power: 15 |
(mesh/use-tweaked-centroids? #f)
(polyhedra/verbosity 0) (polyhedra/skewness/max-cell-skew 0.9) (polyhedra/minimize-node-storage? #t) (polyhedra/fast-io-migration/threshold 500000) (polyhedra/fast-io-migration/tmp-file-location "") (polyhedra/fast-io-migration? #t) (polyhedra/smoothing/squish-threshold 0.8) (polyhedra/smoothing/relax-bad 0.05) (polyhedra/smoothing/no-iter-bad 200) (polyhedra/smoothing/relax-all 0.1) (polyhedra/smoothing/no-iter-all 4) (polyhedra/dual/detect-gaps? #t) (polyhedra/dual/skew-threshold -1) (polyhedra/modified-dual-on-faces? #f) (polyhedra/modified-dual-alpha 1) (polyhedra/modified-dual-threshold -1) (polyhedra/preserve-boundary-faces? #f) (polyhedra/conversion-feature-angle -1) (dynamesh/ic3m/import? #f) (dynamesh/ic3m/length-scaling 0.001) (dynamesh/ic3m/last-event 0) (dynamesh/ic3m/max-number-of-nodes 0) (dynamesh/timing/output 0) (dynamesh/timing? #f) (dynamesh/motion-history/basename "/home/knob/Saport/Hyhlik/tom") (dynamesh/motion-history? #f) (dynamesh/in-cyn/delta-angle 0.5) (dynamesh/in-cyn/event-list ()) (dynamesh/in-cyn/piston-data (0 0)) (dynamesh/in-cyn/minimum-stroke 0) (dynamesh/in-cyn/minimum-lift 0) (dynamesh/in-cyn/crank-period 720) (dynamesh/in-cyn/crank-start-angle 0) (dynamesh/in-cyn/crank-rpm 2000) (dynamesh/in-cyn/crank-angle 0) (dynamesh/models/ic3m? #f) (dynamesh/models/sdof? #f) (dynamesh/models/pump2.5d? #f) (dynamesh/models/in-cylinder? #f) (dynamesh/method/remesh? #f) (dynamesh/method/layering? #f) (dynamesh/method/spring? #t) (dynamesh/motion/mark-adjacent-zones #t) (dynamesh/fix-swept-volume? #f) (dynamesh/improved-interpolation? #f) (dynamesh/local-conserve-bits 0) (dynamesh/global-conserve-bits 65535) (dynamesh/correct-dvolume-dt? #f) (dynamesh/dynamic-zones ()) (dynamesh/steady/optional-remesh-after-moving? #f) (dynamesh/steady/n-iter 0) (dynamesh/steady/pseudo-time-step 1) (dynamesh/adapt/readapt-after-remeshing? #t) (dynamesh/adapt/move-adapted-cells? #t) (dynamesh/remesh/repartition-interface-threshold 0) (dynamesh/remesh/repartition-load-threshold 20) (dynamesh/remesh/repartition-interval -1) (dynamesh/remesh/repartition-auto? #t) (dynamesh/remesh/verbosity 0) (dynamesh/remesh/remesh-size-interval 10) (dynamesh/remesh/sizing-function? #f) (dynamesh/remesh/surfer-improve-method 0) (dynamesh/remesh/init-add-nodes? #t) (dynamesh/remesh/circumsphere-tolerance 1e-07) (dynamesh/remesh/sliver-size 1e-18) (dynamesh/remesh/remesh-sweep 5) (dynamesh/remesh/remesh-scheme 4) (dynamesh/remesh/agglomeration-scheme 1) (dynamesh/remesh/perturb-cavity-nodes? #f) (dynamesh/remesh/face-loop-correction? #t) (dynamesh/remesh/face-v6.1? #f) (dynamesh/remesh/face-on-demand? #f) (dynamesh/remesh/swap-iteration 4) (dynamesh/remesh/swap-angle 100) (dynamesh/remesh/height-relax-factor 0.4) (dynamesh/remesh/must-improve-skewness? #t) (dynamesh/remesh/max-thread-skew -1) (dynamesh/remesh/max-face-skew 0.7) (dynamesh/remesh/max-length-scale 1000) (dynamesh/remesh/min-length-scale 0) (dynamesh/refine/vol-max -1000) (dynamesh/collapse/vol-min -1000) (dynamesh/boundary/project-deforming-nodes-twice? #f) (dynamesh/boundary/project-deforming-nodes? #t) (dynamesh/boundary/node-relax 1) (dynamesh/spring/face-node-skewness 0.6) (dynamesh/spring/all-element-type? #f) (dynamesh/spring/boundary-stiffness 1) (dynamesh/grid/epsilon 0.001) (dynamesh/grid/itermax 20) (dynamesh/grid/relax 1) (dynamesh/layering/v6.1? #f) (dynamesh/layering/constant-height #t) (dynamesh/layering/omega-col 0.04) (dynamesh/layering/omega 0.4) (dynamesh/omega 0) (dynamesh/node-grids ()) (sizing-function/post-processing-thread -1) (sizing-function/zonal-edge-size-limits ()) (sizing-function/boundary-threshold 0.1) (sizing-function/variation-rate -2) (sizing-function/smoothing? #t) (centrifugal/density-ratio 0) (centrifugal/exit-radius 0) (centrifugal-init? #f) (max-iterations-per-step 20) (gen-nrbc/sig2 5) (gen-nrbc/sig 0.15) (gen-nrbc/on? #f) (bc/convection-z-velocity 0) (bc/convection-y-velocity 0) (bc/convection-x-velocity 1) (bc/convective-outflow? #f) (nonconformal/coupled-fluid-zones ()) (nonconformal/auto-detect-interface-type? #f) (nonconformal/new-proximity-algo? #f) (nonconformal/smallest-polygon-size 1e-10) (nonconformal/fast-intersection-lookup? #f) (nonconformal/ignore-proximity-test? #f) (nonconformal/verbosity 0) (nonconformal/correct-virtpoly-face-handedness? #f) (nonconformal/virtual-polygons? #t) (nonconformal/mixed-faces 0) (nonconformal/sm-node-match-tol 0.05) (nonconformal/sm-bound-match-tol 0.05) (nonconformal/sm-match-tol 0.05) (nonconformal/allow-interface-at-periodic-boundary 1) (nonconformal/force-bound-tol 0.4) (nonconformal/force-shared-nodes-to-boundary 1) (nonconformal/check-bound-match 1) (nonconformal/common-edges 0) (nonconformal/cell-faces 0) (nonconformal/feature-angle 100) (nonconformal/proj-move-node-tol 0.1) (nonconformal/boundary-move-node-tol 0.1) (nonconformal/move-node-tol 0.1) (nonconformal/max-surface-distance-tol 0.3) (sliding-interfaces ()) (user-defined-db-name "") (user-defined-database? #f) (materials ((air fluid (chemical-formula . #f) (density (constant . 1.225)) (specific-heat (constant . 1006.43) (polynomial piecewise-polynomial (100 1000 1161.4821 -2.3688189 0.014855111 -5.0349093e-05 9.9285696e-08 -1.1110966e-10 6.540196e-14 -1.5735877e-17) (1000 3000 -7069.8141 33.706051 -0.058127595 5.4216153e-05 -2.9366789e-08 9.2375332e-12 -1.5655534e-15 1.1123349e-19))) (thermal-conductivity (constant . 0.0242)) (viscosity (constant . 1.7894e-05) (sutherland 1.716e-05 273.11 110.56) (power-law 1.716e-05 273.11 0.666)) (molecular-weight (constant . 28.966)) (lennard-jones-length (constant . 3.711)) (lennard-jones-energy (constant . 78.6)) (thermal-accom-coefficient (constant . 0.9137)) (velocity-accom-coefficient (constant . 0.9137)) (therm-exp-coeff (constant . 0)) (degrees-of-freedom (constant . 0)) (speed-of-sound (none . #f))) (aluminum solid (chemical-formula . al) (density (constant . 2719)) (specific-heat (constant . 871)) (thermal-conductivity (constant . 202.4)) (formation-entropy (constant . 164448.08)) (electric-conductivity (constant . 35410000)) (magnetic-permeability (constant . 1.257e-06))))) (proximity/threads ()) (proximity/faces-per-twig 50) (partition/particle-weight 0) (partition/minimum-elements-for-parallel-sort 0) (partition/auto/force? #f) (partition/auto/load-vector ()) (partition/auto/across-zones? #t) (partition/auto/pre-test? #f) (partition/counter-last-partition 0) (partition/total-interface-percentage 0) (partition/auto/use-default? #t) (partition/auto/method "Principal Axes") (partition/zonal-methods ()) (partition/stored/method "Principal Axes") (partition/active/method "Principal Axes") (partition/reorder? #f) (partition/metis-agglomerate? #t) (partition/encapsulate-node-pairs? #t) (partition/load-vector ()) (partition/across-zones? #t) (partition/interface-owner -1) (partition/encapsulate-si? #f) (partition/encapsulate-owner -1) (partition/encapsulate-shell-level -1) (partition/encapsulate-si-level -1) (partition/recompute-si-flux? #f) (partition/require-encapsulation? #f) (partition/restrict-children? #t) (partition/verbosity 1) (partition/origin/z 0) (partition/origin/y 0) (partition/origin/x 0) (partition/pre-test? #f) (partition/smooth-iter 3) (partition/smooth? #t) (partition/merge-iter 3) (partition/merge? #f) (partition/expert? #f) (partition/cell-function "") (parallel/comm-type 1) (parallel/dump-face-send-buffer-size 8) (parallel/encapsulate-shell? #f) (parallel/new-err-handle #t) (parallel/remote-shell-cmd "default") (parallel/remote-shell 0) (parallel/remote-arch "auto") (parallel/migrate-si-after-adaption? #t) (parallel/claim-host-not-filled? #f) (parallel/mpi-io? #f) (parallel/data-read-write-in-chunks? #t) (parallel/fast-read-section? #t) (parallel/fast-read-case? #t) (parallel/fast-io? #f) (parallel/lam-shutdown-before-exit? #f) (parallel/init-io-buffers-before-read? #t) (parallel/case-read-use-pack? #t) (parallel/debug-case? #f) (parallel/auto-set-affinity? #t) (parallel/auto-spawn? #t) (parallel/rc-failed? #f) (parallel/balance-adaption? #t) (parallel/niter-balance-auto 25) (parallel/niter-balance 0) (parallel/balance-on-kill #t) (parallel/enable-balance #f) (parallel/trace-level 0) (parallel/read-mesh? #t) (parallel/gprof? #f) (parallel/max-spawn 8) (parallel/time-out 50) (parallel/nprocs_string "") (parallel/ruser "") (parallel/rhost "") (parallel/path "") (parallel/function "") (parallel/sync-interval 10) (parallel/print-verbosity 1) (parallel/max-messages 16) (parallel/mask ()) (parallel/hostsfile "") (parallel/machines ()) (case/save-id? #f) (checkpoint/time-step? #f) (checkpoint/exit? #f) (checkpoint/write-case? #t) (checkpoint/restart-filename "") (checkpoint/filename "") (case-config ((rp-seg? . #t) (rp-acoustics? . #f) (rp-atm? . #f) (rp-axi? . #f) (rp-des? . #f) (rp-dpm-cache? . #f) (rp-unsteady? . #f) (rp-dual-time? . #f) (rp-amg? . #f) (rf-energy? . #f) (rp-hvac? . #f) (rp-inviscid? . #f) (rp-ke? . #f) (rp-kklw? . #f) (rp-kw? . #f) (rp-lam? . #t) (rp-les? . #f) (rp-lsf? . #f) (rp-net? . #f) (rp-react? . #f) (rp-sa? . #f) (rp-sge? . #f) (rp-spe? . #f) (rp-spe-part? . #f) (rp-spe-site? . #f) (rp-spe-surf? . #f) (rp-trb-scl? . #f) (rp-turb? . #f) (rp-absorbing-media? . #f) (rp-visc? . #t) (rp-v2f? . #f) (sg-cylindrical? . #f) (sg-disco? . #f) (sg-bee-gees? . #f) (sg-crev? . #f) (sg-dpm? . #f) (sg-dtrm? . #f) (sg-dynmesh? . #f) (sg-ignite? . #f) (sg-network? . #f) (sg-noniterative? . #f) (sg-nox? . #f) (sg-melt? . #f) (sg-micro-mix? . #f) (sg-mphase? . #f) (sg-p1? . #f) (sg-par-premix? . #f) (sg-pb? . #f) (sg-pdf? . #f) (sg-pdf-transport? . #f) (sg-premixed? . #f) (sg-pull? . #f) (sg-rosseland? . #f) (sg-rsm? . #f) (sg-s2s? . #f) (sg-soot? . #f) (sg-sox? . #f) (sg-spark? . #f) (sg-swirl? . #f) (sg-udm? . #f) (sg-uds? . #f) (sg-vfr? . #f) (sg-solar? . #f) (sg-wetsteam? . #f) (sg-moistair? . #f) (rp-3d? . #t) (rp-double? . #f) (rp-graphics? . #t) (rp-host? . #f) (rp-thread? . #t) (dpm-cache? . #t))) (sampling-chunk 1) (iteration-chunk 1) (reference-thread -1) (reference-gamma 1.4) (reference-viscosity 1.7894e-05) (reference-velocity 1) (reference-temperature 288.16) (reference-pressure 0) (reference-length 1) (reference-enthalpy 0) (reference-density 1.225) (reference-depth 1) (reference-area 1) (reorder/across-zone? #f) (reorder/boundary-thread-ids ()) (reorder-expert? #f) (reorder/method "reverse-cuthill-mckee") (reorder/reordered 0) (pressure-reference/z 0) (pressure-reference/y 0) (pressure-reference/x 0) (gravity/z 0) (gravity/y 0) (gravity/x 0) (gravity? #f) (operating-pressure 101325) (initial-operating-pressure 101325) (floating-operating-pressure? #f) (positivity-limit 0.2) (boundary-values? #t) (separate-thread-id-list ()) (deativated-original-state ()) (deactivated-dynamic-zones ()) (append-rp-list ()) (scanned-thread-list ()) (geom-thread-id/name ()) (reading-surface-mesh? #f) (grid-appending? #f) (grid/partitions? #f) (grid/level 0) (streamf/nit 8) (allow-expert-dis-schemes? #f) (flowf-expert? #f) (node/level 0) (adapt/reconstruct-geometry? #f) (adapt/yp/min 50) (adapt/yp/max 500) (adapt/yp/type 0) (refine/maxv 1) (adapt/max-passes 10) (adapt/region/shape "hexahedron") (adapt/region/inside? #t) (adapt/region/radius 0) (adapt/region/zmax 0) (adapt/region/zmin 0) (adapt/region/ymax 0) (adapt/region/ymin 0) (adapt/region/xmax 0) (adapt/region/xmin 0) (adapt/boundary/volume-decay 1) (adapt/boundary/volume-target 1) (adapt/boundary/distance-threshold 0) (adapt/boundary/number-of-cells 1) (adapt/coarsen/volume-threshold 0) (adapt/coarsen/all-cells-marked? #t) (adapt/coarsen/nodes/refn/remove-periodic? #t) (adapt/coarsen/nodes/refn/remove-boundary? #t) (adapt/coarsen/nodes/refn/remove-internal? #t) (adapt/coarsen/nodes/orig/remove-periodic? #f) (adapt/coarsen/nodes/orig/remove-boundary? #f) (adapt/coarsen/nodes/orig/remove-internal? #f) (adapt/coarsen/marker/color "cyan") (adapt/coarsen/marker/size 0.1) (adapt/coarsen/marker/symbol "@") (adapt/coarsen/bit 1) (adapt/coarsen? #f) (adapt/refine/marker/color "red") (adapt/refine/marker/size 0.1) (adapt/refine/marker/symbol "@") (adapt/refine/bit 0) (adapt/refine? #t) (adapt/hanging-node? #t) (adapt/dynamic/print-memory-usage? #f) (adapt/dynamic/security-layer-thickness 1) (adapt/dynamic/interval 20) (adapt/dynamic/list-functions ("Pressure..." "Static Pressure")) (adapt/dynamic/function "pressure") (adapt/dynamic? #f) (adapt/gradient/volume-weight 1) (adapt/gradient/normalize-per-zone? #f) (adapt/gradient/normalization 0) (adapt/gradient/method "curvature") (adapt/max-refine-level 2) (adapt/maxc 0) (adapt/minc 0) (adapt/minv 0) (adapt/threshold/volume-change 2.5) (adapt/threshold/coarsen 0) (adapt/threshold/refine 1e+10) (adapt/propogate-edge-split? #t) (adapt/threads ()) (interp-method 0) (distance/crit 1.5) (prmx-adiabatic? #t) (prmxmu 0.26) (prmxa 0.52) (prmxcd 0.37) (hvac-species/sct 1) (hvac-keprt 0.9) (hvac-const 0.039) (drsm-kw-zeta-star 0.5) (drsm-kw-r-w 6.2) (drsm-kw-r-k 12) (drsm-kw-r-beta 12) (drsm-kw-alpha-0 0.105) (drsm-c2-omega 0.52) (drsm-c1-omega 1.8) (drsm-c5-ssg 0.4) (drsm-c4-ssg 1.25) (drsm-c3s-ssg 1.3) (drsm-c3-ssg 0.8) (drsm-c2-ssg 4.2) (drsm-c1s-ssg 1.8) (drsm-c1-ssg 3.4) (drsm-c2-wall 0.3) (drsm-c1-wall 0.5) (drsm-c2 0.6) (drsm-c1 1.8) (drsm-omega-wilcox? #t) (drsm-omega-based? #f) (drsm-ssg-ps? #f) (drsm-linear-ps? #t) (drsm-wall-factor-clip? #t) (drsm-ps-wall? #t) (drsm-lowre-epsilon? #f) (drsm-tke-solve? #t) (sst-pk-factor 10) (sst-v61? #f) (sst-kappa 0.41) (sst-beta-i2 0.0828) (sst-beta-i1 0.075) (sst-a1 0.31) (sst-sig-w2 1.168) (sst-sig-w1 2) (sst-sig-k2 1) (sst-sig-k1 1.176) (kw-sig-w 2) (kw-sig-k 2) (kw-beta-i 0.072) (kw-mt0 0.25) (kw-zeta-star 1.5) (kw-r-w 2.95) (kw-r-k 6) (kw-r-beta 8) (kw-beta-star-inf 0.09) (kw-alpha-0 0.11111) (kw-alpha-inf 0.52) (kw-alpha-star-inf 1) (kw-vorticity-pk? #f) (kw-set-wall-w? #f) (kw-shear-mod? #t) (kw-compress-mod? #t) (kw-low-re-mod? #f) (kw-sst-strain? #f) (kw-sst-on? #f) (kw-std-on? #t) (des-omega/min-limit 1e-12) (des-epsilon/min-limit 1e-07) (des-k/min-limit 1e-07) (des-limiter-option 3) (des-sst-on? #f) (des-rke-on? #f) (des-sa-on? #t) (p-func-jaya-on? #t) (trans-kw-ctaul 4360) (trans-kw-calpha-teta 0.035) (trans-kw-cw3 0.3) (trans-kw-cw1 0.44) (trans-kw-cint 0.75) (trans-kw-anu 6.75) (trans-kw-sig-w 1.17) (trans-kw-sig-k 1) (trans-kw-crnat 0.04) (trans-kw-ctscrit 1000) (trans-kw-cnatcrit 440) (trans-kw-ats 200) (trans-kw-anat 60) (trans-kw-c12 1e-09) (trans-kw-c11 3.4e-06) (trans-kw-cr 0.08) (trans-kw-cbpcrit 12) (trans-kw-abp 3) (trans-kw-clam 2.495) (v2f-alpha 0.6) (v2f-cl 0.23) (v2f-ceta 70) (v2f-c2 0.3) (v2f-c1 1.4) (v2f-enn 6) (v2f-kec2 1.9) (v2f-kec1 1.4) (v2f-kecmu 0.22) (turb-pk-compress? #f) (turb-non-newton-lb? #f) (turb-non-newton? #f) (wall-distance/verbosity 0) (wall-distance/quad-correction-aspect-ratio 500) (wall-distance/quad-correction? #f) (wall-distance-alternative? #f) (ke-yplus-udf 11.224708) (ke-elog-udf 9.793) (ke-rotation-model? #f) (ke-time-scale-clip-const? 0.6) (ke-time-scale-clip? #f) (kato-launder-on? #f) (rng-swirl-const 0.07) (rng-swirl-on? #f) (rng-kec2 1.68) (rng-kec1 1.42) (rng-kecmu 0.0845) (rng-visc-mod-on? #f) (rng-ke-on? #f) (ke-time-marching? #t) (ke-uncoupled? #t) (ke-prod-mod #f) (ke-source-mod #t) (realizable-epsilon? #f) (ke-realizability-on? #f) (ke-compress-const 1) (rsm-ssg-kec2 1.83) (rke-cmu-rotation? #f) (rke-kesige 1.2) (rke-kec2 1.9) (wallprt 0.85) (keprt 0.85) (kesige 1.3) (kesigk 1) (kec2 1.92) (kec1 1.44) (kecmu 0.09) (ke-two-layer-c-l-mu 0.33) (ke-two-layer-a-mu-norris 50.5) (ke-two-layer-a-mu 70) (ke-two-layer-option 1) (ke-two-layer-delta 40) (ke-two-layer-rey-c 200) (ke-udf-wall? #f) (ke-enh-wall? #f) (ke-non-eqm #f) (ke-std-wall? #t) (sa-des-inlet-turb-i 0) (sa-des-all-lengths-modified? #t) (sa-des-maxedge? #t) (rke-des-cdes 0.61) (sst-des-cdes 0.61) (sa-des-cdes 0.65) (nut-imp-diff? #t) (nut-prod-const 2) (nut-prod-modify? #f) (nut-kappa 0.41) (nut-cw3 2) (nut-cw2 0.3) (nut-prt 0.667) (nut-cv1 7.1) (nut-cb2 0.622) (nut-cb1 0.1355) (vm-grid-scale 1.5) (vm-ls-constant? #f) (vm-n-travel 50) (delta-time-sampled-wall 0) (delta-time-sampled-heat-flux 0) (delta-time-sampled-shear 0) (delta-time-sampled 0) (number-of-samples 0) (save-time-statistics-species ()) (save-time-statistics-wall? #t) (save-time-statistics-heat-flux? #t) (save-time-statistics-shear? #t) (save-time-statistics? #f) (les-inlet-random? #f) (les-utau-newton-iter? #t) (les-enh-wall-fn? #t) (les-ww-wall? #f) (les-mixed-sgs-on? #f) (les-dynamic-const-max 0.23) (les-dynamic-const-clip? #t) (les-dynamic-species-on? #f) (les-dynamic-energy-on? #f) (les-dynamic-smag-on? #f) (les-dynamic-sgske-on? #f) (les-sgske-on? #f) (les-wale-sgs-on? #f) (les-rng-sgs-on? #f) (les-fvar-const 0.5) (les-sgske-ceps 1) (les-sgske-prt 1) (les-sgske-visc-const 0.05) (les-wale-const 0.325) (les-rng-const 0.157) (les-smag-const 0.1) (les-2d? #f) (les-cpld-diss-coeff 0.2) (test-low-diffusion-inviscid-flux? #f) (omega/nk 1) (omega/nj 0) (omega/ni 0) (omega 0) (residual-smoothing/iterations 0) (residual-smoothing/factor 0.5) (precon/n-update-uref2 10) (mg/relax-spe 1) (solid/relax 1) (recon/bc-minmax-id 1) (first-to-second-order-blending 1) (cpld/consistent-viscous-linearization? #t) (cpld/rdq 1) (enable-beta-dbns-features? #f) (cpld/aratio-cutoff 20) (cpld/enable-newtimestep? #f) (cpld/inlet-diffusion? #t) (recon/lim/sigp 0.05) (recon/lim/allneighbors? #f) (recon/lim/method 6) (recon/lim/newimpl? #f) (cpld-lsq-ncycles 5) (recon/cycle-vel-limit? #f) (recon/lim/list-sort? #t) (recon/lim/type 0) (recon/enthalpy? #t) (recon/density? #t) (recon/cpld-use-lsq-deriv? #t) (recon/node-grad-diffusion? #f) (recon/node-boundary-lsq? #t) (recon/node-scale-id 2) (recon/node-cell-weight? #t) (recon/node-weight-clip? #t) (recon/node-all-lsq? #f) (recon/node-gradient-lsq? #f) (recon/density-node-lsq? #t) (recon/pressure-node-based? #f) (recon/pressure-node-lsq? #f) (recon/cell-lsq/wf 2) (recon/cell-lsq/cortype 1) (recon/cell-lsq? #f) (recon/node-lsq? #f) (recon/length-based? #f) (recon/limit/epsilon 0.01) (recon/limit? #t) (recon/k-exact? #f) (recon/freeze? #f) (recon/off? #f) (export/icecore-hdf5/chunk-size 16328) (export/icecore-hdf5/chunked-data? #t) (export/icecore-hdf5/ziplevel -1) (export/fieldview/filetype 3) (export/abaqus/structural? #t) (export/write-thermal-load? #f) (export/vki-verbose? #f) (export/write-structural-load? #t) (export/ensight/functions ()) (export/ensight/filename "") (export/ensight/phase 1) (export/ensight/gold_binary? #t) (export/ensight/transient/separate-file? #f) (export/ensight/last-iter-no 0) (export/ensight/transient? #f) (export/ensight/fl-start-num 1) (export/ensight/frequency 1) (export/ensight/particle-time-values ()) (export/ensight/time-values ()) (export/functions ()) (export/filetype "CGNS") (export/fem-map? #f) (export/write-surfaces-only? #t) (import/process-node-sets? #f) (import/cfx-merge-tolerance 1e-08) (visual-kinematics? #t) (export/time-average-htc? #f) (export/marked-cells? #f) (fem-map/thread-id-list ()) (ms-levels/viscous-ta (#t #t #t #t)) (ms-levels/dissipation-ta (#t #t #t #t)) (ms-coefficients-ta (0.25 0.333333 0.5 1)) (ms-levels/viscous (#t #t #t #t #t)) (ms-levels/dissipation (#t #t #t #t #t)) (ms-coefficients (0.2075 0.5915 1)) (inviscid-flux-new? #f) (dual-time/use-transient-scaling? #t) (dual-time/use-prec? #t) (residual-verbosity 0) (flow-warnings? #t) (limiter-warnings? #t) (precondition? #t) (time-step 0) (physical-time-step 1) (courant-number/implicit 5) (courant-number/explicit 1) (matching-tolerance 0.05) (max-flow-time -1) (flow-time 0) (smooth-mesh/boundary-nodes? #f) (smooth-mesh/method "skewness") (smooth-mesh/only-marked-cells? #f) (smooth-mesh/skew-max 0.9) (smooth-mesh/relax 0.1) (smooth-mesh/niter 4) (draw/domain/list ()))) |
February 18, 2011, 09:37 |
Pierre-Louis Schmitt
Rep Power: 15 |
Thank you for the answer. As far as I understand this part concern the fluid material :
(materials ((air fluid (chemical-formula . #f) (density (constant . 1.225)) (specific-heat (constant . 1006.43) (polynomial piecewise-polynomial (100 1000 1161.4821 -2.3688189 0.014855111 -5.0349093e-05 9.9285696e-08 -1.1110966e-10 6.540196e-14 -1.5735877e-17) (1000 3000 -7069.8141 33.706051 -0.058127595 5.4216153e-05 -2.9366789e-08 9.2375332e-12 -1.5655534e-15 1.1123349e-19))) (thermal-conductivity (constant . 0.0242)) (viscosity (constant . 1.7894e-05) (sutherland 1.716e-05 273.11 110.56) (power-law 1.716e-05 273.11 0.666)) (molecular-weight (constant . 28.966)) (lennard-jones-length (constant . 3.711)) (lennard-jones-energy (constant . 78.6)) (thermal-accom-coefficient (constant . 0.9137)) (velocity-accom-coefficient (constant . 0.9137)) (therm-exp-coeff (constant . 0)) (degrees-of-freedom (constant . 0)) (speed-of-sound (none . #f))) (aluminum solid (chemical-formula . al) (density (constant . 2719)) (specific-heat (constant . 871)) (thermal-conductivity (constant . 202.4)) (formation-entropy (constant . 164448.08)) (electric-conductivity (constant . 35410000)) (magnetic-permeability (constant . 1.257e-06))))) Do you have an idea of the command to extract the molecular weight in a UDF. Thanks Pilou |
February 21, 2011, 04:08 |
Martin Knob
Rep Power: 15 |
Sorry, gave you the list of all accessible rpvars;-)
For molecular weights I recommend you a #define directive- if you want the same data as in Fluent, you find them e.g. in fluent_directory//cpropep/data/thermo.dat;-) |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 03:44 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 12:33 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
