Unsteady DPM with steady solver
Like Tree1Likes
  • 1 Post By juste
Old   January 28, 2011, 11:39
Default Unsteady DPM with steady solver
elobb is on a distinguished road
I believe from the user guide that it is possible to run unsteady tracking of a discrete phase with the steady flow solver.
I can track particles with steady tracking and the steady solution. However, when I change to unsteady particle tracking, set a particle time step size, number of steps and start and stop time (both zero for one injection) there seems to be no particles injected.
Can anybody help with this? I do not want to activate interaction with the continuous phase.
elobb is offline   Reply With Quote
Old   May 23, 2011, 05:41
john
johnwinter is on a distinguished road
did you find solution to your query?
johnwinter is offline   Reply With Quote
Old   May 24, 2011, 14:01
alighaffari
alighaffari is on a distinguished road
stop time for injection shoud be other than zero if you want to have injection!!
alighaffari is offline   Reply With Quote
Old   May 31, 2015, 05:11
Default solution: use non-zero mass flow rate in injection dialog box
Juste
juste is on a distinguished road
i can see that it has been more than 4 years since u asked this, but I am still going to answer it, in case anyone else too has the same query...
i was also facing this same problem, but now i just found the solution, so thought of sharing it...
in steady DPM u can do the analysis with flow rate = 0 in the injection dialog box, but not in unsteady DPM.
when u use unsteady DPM u need to specify the flowrate..the formula for flowrate is
number of particles in a parcel * (mass of each particle / time step).
that's it.
and u can use start time and end time both zero. in this case particle will be injected only once, if that is what you want.
for more details, refer
http://www.arc.vt.edu/ansys_help/flu..._unsteady.html
tbraun84 likes this.
juste is offline   Reply With Quote
Old   December 16, 2021, 04:54
fatma
fatma123 is on a distinguished road
How to do repetition for DPM injection (surface type)
fatma123 is offline   Reply With Quote
particle tracking, steady
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 09:33
steady to unsteady wlt_1985 FLUENT 6 December 4, 2010 17:17
On Setring Step Size in unsteady Solver of FLUENT lzgwhy FLUENT 0 August 19, 2009 23:44
DPM Steady formulation with collisions kulwinder FLUENT 0 May 22, 2004 19:44
Difference results between Steady and Unsteady? Giang T Vu FLUENT 6 May 22, 2004 07:37
