Particle Tracking CFD-Post Fluent
Like Tree7Likes
  • 2 Post By DLINSA
  • 3 Post By Deepblack
  • 1 Post By ildar
  • 1 Post By vasava
Old   December 31, 2010, 11:22
Default Particle Tracking CFD-Post Fluent
Chris
stitrack is on a distinguished road
Hi -
I am trying to view particle tracking data in CFD-Post; however, when I try to upload a particle tracking file, my only file extension option is a CFX-4 Particle Track File (.trk). I'm doing my CFD analysis in Fluent.
Two questions:
1. Can I generate a .trk file using Fluent?
2. When I write particle tracking data to a file in Fluent, the file extension is .his. Is there a way to convert that file?
Thanks -
Chris
stitrack is offline   Reply With Quote
Old   January 17, 2011, 10:44
Reine Granström
gravis is on a distinguished road
This is from CFX-Post 12.1 documentation, regarding reading Fluent files:
"The loading of particle tracks (either track data in the data file or separate track files) is not supported."
I do not remember seeing anything new in this area when I read the release notes for v13, but I am not entirely sure. I would also appreciate if anyone knows more about this, maybe there is some workaround?
Cheers,
Reine
gravis is offline   Reply With Quote
Old   January 18, 2011, 08:30
Federico
Friedmann is on a distinguished road
Originally Posted by stitrack View Post
Hi -
Two questions:
Thanks -
Chris
i'm trying also to display particle tracks in CDF-post and Fluent. In the CDF-Post user's guide it is stated that we need a " appropriate Fluent particle tracks XML file" to import in CFD-Post. To create this file, the ug says that we have to refer to the fluent user's guide. I've read many times through the displaying and writing of particle tracks files but there is nothing about this XML file. I also tried to import each format that Fluent writes about particle data. it doesn't work.
any hints or suggestions?
Friedmann is offline   Reply With Quote
Old   August 29, 2011, 13:17
Mario Tremblay
Mario is on a distinguished road
I have the same problem. Finally did you find how to import the particle track in CFD-post.
Mario
Mario is offline   Reply With Quote
Old   August 30, 2011, 10:14
lodie
DLINSA is on a distinguished road
Hello everybody!
I used the XML format for particles tracking on Ansys Workbench 13.
There is actually a new feature in the "Calculation Activities" menu, in the "Automatic Export" field. Click on "Create" and you should have " : "Particle History Data Export" then select the CFD-Post check box and set your exported variables as you want.
With this, the exported file is in .xml. My problem is that I found this format very heavy and when you have a lot of particles like I have (around 8000), and if you want to track each at every time step, the file size is increasing of about 2 MB/t_step ... So it's a problem for data treatment afterward but it is another subject.
Hope I've helped you!
Papes and sdm5553515 like this.
DLINSA is offline   Reply With Quote
Old   October 24, 2013, 03:14
Hem
hem233 is on a distinguished road
Can anyone suggest if I can track a particle after its formation in a reaction like precipitation.
hem233 is offline   Reply With Quote
Old   April 21, 2014, 12:22
Deepblack is on a distinguished road
Hey people,
here is how to read in a .xml particle file form Fluent into CFD-Post:
In CFD-Post you have to click at FILE->IMPORT->FLUENT HISTORY PARTICLE, then it will ask for xml.
Hope I could help you.
ZAB, Papes and Marmalade like this.
Deepblack is offline   Reply With Quote
Old   April 25, 2014, 11:49
Fots Taboula
malcom is on a distinguished road
Hi deep black
Hi Deepblack,
Can you explain me with more details how I could read de .xml file? In CFD-Post I can click on
File -> Import import->fluent particles track file
''Fluent history particle'' like you wrote is not enable in CFD post
Dank in advance
malcom is offline   Reply With Quote
Old   March 11, 2015, 05:01
Almakayev Ildar
ildar is on a distinguished road
Hi, colleagues! Can you explain me my problem.
At first, I save case & data files in Ansys Fluent 14.0, then I read this files and further I import the particle track file in CFD-Post.
And when I import the Fluent particle track file I get exception "Internal. Internal error detected: Unknown XML exception".
Please explain me what I should do?
Thanks!
jwells09 likes this.
ildar is offline   Reply With Quote
Old   March 13, 2015, 05:56
Paritosh Vasava
vasava will become famous soon enough
The particle summary report generated in Fluent is not supported by CFD-Post. Nothing that you do about it in Fluent will work with CFD-post.
ildar likes this.
vasava is offline   Reply With Quote
Old   April 21, 2016, 05:58
Default How to read .xml files for particle tracking other than cfd post.
  #11
Sadia Haider
Sadia Haider is on a distinguished road
How to read .xml files for particle tracking other than cfd post. i have a problem regarding reading .xml file . Kindly let me know if anyone of you can help me .
Sadia Haider is offline   Reply With Quote
Old   February 8, 2018, 12:28
Xin Liu
xinliu is on a distinguished road
you're quite right. One can not import .xml file through "particle track->geometry->file" cause it only support CFX-4 Tracks (.trk) file.
However, you can get the same particle track plot through "file->import->FLUENT particle track file" directly.
Xin
xinliu is offline   Reply With Quote
Old   February 19, 2019, 03:22
Default Import Multiple Fluent Particle Track files in CFD Post
  #13
Vignesh Lakshmanan
ViLaks is on a distinguished road
Hi All,
I am trying to create an animation of rain entering an air conditioner condensing unit in CFD Post.
Problem: Simulate rain falling on an air conditioner Condensing unit placed outside residential apartments and observe water drops / film formation on critical electronic components inside the condensing unit.
Models Used: DPM, Eulerian Wall Film
I am done with the simulations. I need to create an animation, wherein the rain drops fall and enter in to the condensing unit and hit the components inside. However, if I import particle tracks from Fluent into CFD post, how much I try, I am not able to get particles etering inside the condensing unit. BUt, in Fluent, in DPM tracking (Pulse Mode), I can observe it.
Is it possible to import multiple particle tracks file from FLuent into CFD post?
Thanks
ViLaks is offline   Reply With Quote
Old   May 12, 2022, 11:29
Default Ms
  #14
Ying Feng
Marmalade is on a distinguished road
Originally Posted by ViLaks View Post
Hi All,
Thanks
Hi, have you solved this problem? i want to get particle trajectory from fluent into the CFDpost.
Marmalade is offline   Reply With Quote
Old   May 18, 2022, 06:12
Vignesh Lakshmanan
Hi Marmalade,
It has been quite sometime, but ya, I have solved it. However, I did in another software, FieldView from Intelligent Light.
Regards
Vignesh
Old   May 18, 2022, 11:19
Ying Feng
Hi Marmalade,
Regards
Vignesh
Thank you for your reply and suggestion, and i will try it using your method.
Regards
Ying
Old   May 21, 2022, 01:58
Vignesh Lakshmanan
Regards
Ying
Dear Ying,
I guess the quality of the animation I required was the only deterrent I had in using CFD Post. But I guess, we can easily import particle data from fluent into CFD post for post processing
Regards
Vignesh
cfd-post, fluent, particle tracking
Non-spherical, inert particle tracking in FLUENT Mohsin FLUENT 2 October 21, 2013 17:41
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 01:51
Particle Tracking for ion Jun CFX 2 August 31, 2010 09:19
particle tracking in unsteady flow peterchen FLUENT 1 July 22, 2010 23:18
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
