Convergence issue- residuals of continuity
Like Tree2Likes
  • 1 Post By ehooi
  • 1 Post By red_lemon
Old   December 7, 2010, 01:20
Default Convergence issue- residuals of continuity
s.garg is on a distinguished road
Hello ,
I'm modeling a laminar coolant(water) flow through a circular tube of
Inner Diameter = 0.1 m
Inlet velocity of coolant = 0.02 m/s
Inlet temperature = 293 Kelvin
There is a uniform heat flux = 1000 W/m^2 applied to the outer surface(wall).
I modeled the inner tube as a fluid and applied a uniform heat flux to the wall. However , when I try to plot my residuals with the following solver settings
convergence criteria for continuity, x,y,z velocity = 1e-6
convergence criteria for energy equation = 1e-9
the residuals of the continuity equation do not converge. they seem to decrease initially and then keep bouncing around at 1e-3 .
I tried changing the under relaxation factors , but this ddint not help all that much.
I'm using a SIMPLE scheme , with 2nd order upwind discretization for momentum and energy
Any help or views on this would be greatly appreciated.
s.garg is offline   Reply With Quote
Old   January 18, 2011, 11:26
EH
ehooi is on a distinguished road
Are you solving it in steady state or time-dependent? Try time-dependent and see if it works. Try solving for a long period until values of velocity or temperature between two continuous time step does not change significantly.
Just a suggestion.
noaceshigh likes this.
ehooi is offline   Reply With Quote
Old   January 18, 2011, 19:10
red_lemon is on a distinguished road
obvious things but check
1) grid is scaled (Mesh>Scale)
2) bc's are all set correctly (inc materials and heat flux definition)
3) grid quality is good enough (with prisms for heat transfer ideally)
4) grid is refined enough to capture gradients (you could adapt), though if too refined you can pick up transience
display contours of residuals to see where it is struggling
red_lemon is offline   Reply With Quote
Old   February 7, 2016, 13:01
Ema40 is on a distinguished road
I have a similar problem, where in an open channel flow all the variable converge (residuals < 10^(-3)), whereas the continuity equation has residual constant around 10^(-1). The flow seems to not change any longer during iterations.
Thank you
Ema40 is offline   Reply With Quote
Old   November 7, 2016, 12:39
noaceshigh
noaceshigh is on a distinguished road
Thank you
Did you find any solution for this convergence issue?
I'm facing the same challenge.
Thanks!
noaceshigh is offline   Reply With Quote
continuity, convergence, residuals fluent, underrelaxation
Convergence issue with continuity equation Jake FLUENT 8 June 6, 2018 04:41
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
