Local Nusselt Number Around Circular Cylinder!
Like Tree1Likes
  • 1 Post By mskamran
Old   November 9, 2010, 10:09
Default Local Nusselt Number Around Circular Cylinder!
sajid
mskamran is on a distinguished road
Hello guys,
I am working on 'Flow & Heat Transfer over a circular cylinder''. I am using c-mesh and constant flux (isoflux) boundary condition at the cylinder surface.
Can anybody please tell me how to calcualte 'Local and Average Nusselt Number' at cylinder surface using FLUENT?
I tried to calculate local Nu but it is not in agreement with the experimental results.
I would really appreciate your help. Thanks!!!!
Kamran
elham-u likes this.
mskamran is offline   Reply With Quote
Old   May 8, 2013, 05:35
Laura
laura_c is on a distinguished road
I have the same problem... how did you solve it please?
laura_c is offline   Reply With Quote
Old   May 9, 2013, 10:12
Default Nusselt number
sajid
Hi there,
I just used
xy plots > wall fluxes > nusselt number
select the boundary on which u want to plot.
make sure u put the right length in the reference values section.
e.g. if u hv a cylinder of diameter 2 m, set this as 'length' in the reference values.
thanks
average nu, contant flux cylinder, fluent, local nusselt number
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
Circular Cylinder at low Reynold number mesh and non orthogonal corrections kassiotis OpenFOAM Running, Solving & CFD 6 May 15, 2008 07:07
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
Nusselt number tod Phoenics 0 October 18, 2002 10:56
