October 26, 2010, 17:09 |
calculating drag and lift in fluent
Morteza
Rep Power: 16 |
hi i have modelled so many airfoils in fluent ...but the drag and lift coefficients are not exactly those in experimental results.
is there any other way to calculate drag and lift manually in fluent??? |
October 28, 2010, 09:19 |
#2 | |
Amir Khodabandeh
Rep Power: 16 |
Lift=0.5(density)(velocity^2)*(area) Note: Velocity is free stream velocity( Am I right) and also make sure u have correct values in reference values tab in fluent before taking report IF u still got error try to: make ur mesh finer By the way consider numerical errors too! I think (not sure again) up to 10% difference is fine! with normal meshes ! but if u use parallel computers and higher number of mesh it would be lower Also I am happy if someone correct me if I am wrong Movafagh bashi Regards, Amir |
March 9, 2012, 13:46 |
mohammed mahdi
Rep Power: 16 |
Reference area is wing plan-form area, and the reference length must be considered in calculating pitching, rolling and yawing moment, for cm (pitching) the reference length is Mean Aerodynamic Chord, but for rolling and yawing the reference length is wing Span.
the wing plan-form area is projected area on the top view of the wing |
March 9, 2012, 13:50 |
#4 | |
mohammed mahdi
Rep Power: 16 |
-Meshing Construction -Y+ -Boundary layer consideration -Turbulent modelling -Flow solver Residuals and covergence round-off errors -how user is good in solving problems and experience |
December 13, 2012, 16:34 |
area problem
Chaudhary
Rep Power: 14 |
i want to calculate area of circles which would be used in ansys fluent ....
it is 2d heat exchanger and i have problem how to calculate area of circle in front of flow or which area i have to put in reference value .. i have confusion whether i have to use area of 2 or 4 circles ??? kindly tell me how to calculate this area or which area i have to put in reference value ??? i have attached the jpeg. file of structure to further explain it ? waiting for answer...i will be very thankful to you. what Reference values should I used in fluent to find the area as defaults values are 1 for area,depth and length. Area=? Depth=? |
Lift and Drag Monitor Point Values Converging to Zero | Josh | CFX | 24 | May 9, 2011 11:38 |
Fluent Good Lift coefficient BAD drag coefficient | Rif | Main CFD Forum | 4 | March 9, 2010 11:52 |
how to caculate lift drag ratio in fluent | jouven | FLUENT | 2 | June 16, 2009 21:05 |
how to get the drag and lift coefficeint in fluent | vincent | FLUENT | 2 | September 24, 2007 06:16 |
Correct lift but wrong pressure drag - possible? | zx | Main CFD Forum | 4 | July 28, 2007 00:38 |
