September 22, 2010, 03:12 |
create own mixture gas data base
CJ
Rep Power: 17 |
Dear every one,
I want to create my own mixture gas, let's say co and air, there are 2 options: 1. either choose species transport model (this is easy), solving mass fraction equation 2, deselect the option above, create my own mixture gas, solving my own UDS equation with UDF(coz i have own way of defining normalized mass fraction), but here is the thing, I cannot create mixture gas, when i go to define/materials, there are no mixture species, only co and air, how to make them mixted 3. if i use this example. and I still cannot see mixture as a material type if I don;t choose "species transport model" elect material database define/materials/data-base/database-type ;Available Types: (fluent-database user-defined) ;Database Type [fluent-database] user-defined ;Database File [""] mixturegas.scm any suggestions?? Thanks a lot! Last edited by solefire; September 22, 2010 at 03:41. |
September 22, 2010, 03:46 |
CJ
Rep Power: 17 |
actually the clue is still using "species transport model" method, but I want to have my own mass fraction definition, which is kind of mass fraction normalization, and hereby sum(Yi) is not equal to 1 any more, that is why!
September 22, 2010, 04:23 |
CJ
Rep Power: 17 |
or is it possible to edit species transport model? seems it is not easy! ...any ideas? thanks!
September 22, 2010, 12:54 |
srr
Rep Power: 16 |
Go to material, create-edit, choose fluid on material type, select and copy co and air from fluent data base, then in the create-edit materials panel select mixture as type and choose mixture-template as FLUENT mixture materials, change its name if you want, and then go to species (in the same panel), clic on edit and there you can choose the species that will be on your mixture.
Hope this helps regards |
September 25, 2010, 04:40 |
#5 | |
CJ
Rep Power: 17 |
Thanks a lot! This is useful! I guess i need to learn a bit more how to add usd with udf! do u have some good examples about the describing the steps how to do this? |
September 25, 2010, 13:45 |
srr
Rep Power: 16 |
no, about this I don't know.
regards |
September 25, 2010, 15:29 |
CJ
Rep Power: 17 |
November 6, 2017, 01:58 |
How to write UDF for mixture gas
Sourav ghosh
I have started combustion simulation for the first time.Please give me one udf file that mentioned how to write UDF for mixture gas creation.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Real gas equation of state for gas mixture | ahourri | FLUENT | 0 | April 30, 2008 11:23 |
Real Gas Mixture With Reactions | Jake Cannon | Main CFD Forum | 0 | January 16, 2007 11:46 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
