P_POS(p) undeclared variable
Like Tree2Likes
  • 1 Post By spring
  • 1 Post By mohammad1008
Old   July 22, 2010, 10:58
Default P_POS(p) undeclared variable
Sarah
spring is on a distinguished road
I have a problem with the variable P_POS(p). When interpreting my UDF (I don't understnad any of the errors when compiling my UDF) I always get this error:
P_POS: undeclared variable.
I don't have this problem with P_VEL(p), and there are no problems when I remove the line with P_POS. I have an ansys fluent version 12.1 running under linux and windows and I get the same error when interpreting my UDF in both operating systems. I looked into the dpm.h (windows) file and there P_POS was defined like this : #define P_POS(p)((p)->state.pos) but as I said, it still shows me an error. I don't know what else to do and I really hope that someone can help me.
Here is my code:
Thanks,
spring
mohammad1008 likes this.
spring is offline   Reply With Quote
Old   July 22, 2010, 16:51
Chris
Chris D is on a distinguished road
What errors do you get when you try to compile it?
Chris D is offline   Reply With Quote
Old   July 22, 2010, 18:04
Allan Walsh
Allan Walsh is on a distinguished road
I have used P_POS(p) without any problems in V12.1 of Windows Fluent.
As per one of the examples in the UDF tutorial, I have included the following in the variable declaration part of the code when interfacing particle and cell data:
cell_t c = RP_CELL(&p->cCell); /* Get Cell and Thread from */
Thread *t_cl = RP_THREAD(&p->cCell); /* Particle Structure */
Perhaps this might be needed in your implementation?
Allan Walsh is offline   Reply With Quote
Old   July 23, 2010, 06:07
Sarah
First of all thank you very much for trying to help me, I really appreciate that!
To be honest I only tryed to compile my UDF in linux, because I am working all the time in linux and I have 8 times more GB of RAM in linux than in windows. The compiler in linux is the standard GNU C/C++ compiler.
@ Allen
Ok I will try it your way.
best regards,
spring
Old   July 23, 2010, 14:40
Sarah
Hey,
after I copied udf.h into my working folder and compiled my UDF (only in linux) and there weren't any error messages .
And I also was able to hook my UDF in the right place. Does this mean that the compilation was succesful? I ask, because I get a FATAL ERROR :
Error: fluent.12.1.2 received a fatal signal (SEGMENTATION VIOLATION).
Error Object: #f
when I want to start the discrete particle model simulation. In the (long, that's why I wont post it) message it's said that the error is due to my UDF. Any ideas.
regards,
spring
Old   March 11, 2012, 02:01
mohammad taheri
mohammad1008 is on a distinguished road
Hi
I have the same problem. Did you find the solution?
I want to add a body forces fx=ax and fy=by to DPM model. The code I have written is:
/* UDF for computing the magnetic force on a charged particle */
# include "udf.h"
DEFINE_DPM_BODY_FORCE(particle_body_force,p,i)
double a=0.01;
double b=-0.001;
double x;
double y;
real source;
x=P_POS(p)[0];
y=P_POS(p)[1];
if(i==0) source =a*x;
else if(i==1) source =b*y;
/* an acceleration should be returned */
return (source/P_MASS(p));
and the error is:P_POS: undeclared variable
I would be grateful if you help me.
Originally Posted by spring View Post
Here is my code:
Thanks,
spring
mldmrz likes this.
mohammad1008 is offline   Reply With Quote
Old   March 8, 2014, 06:47
Select One
SSOHEIL is on a distinguished road
It may help if you declare P_POS as:
double P_POS[3];
3 for a 3D or 2 for a 2D case.
Regards
SSOHEIL is offline   Reply With Quote
undeclared variable ramintakhti Fluent UDF and Scheme Programming 5 March 16, 2011 19:37
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
UDF compilation problem -- "undeclared variable" Henrik Ström FLUENT 1 September 21, 2005 06:25
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
