Meshing stirred tank with gambit.
Like Tree1Likes
  • 1 Post By boh_tea
Old   July 18, 2010, 06:53
Default Meshing stirred tank with gambit.
Ming
boh_tea is on a distinguished road
Hi all,
I am a student and new to gambit and fluent.I am now working on the stirred tank with rushton impeller.In gambit,I have created 1 larger cylinder volume 1 and then the cylinder volume 2 as the rotating zone and impeller inside volume 2.I splitted volume 1 with volume 2 and substract the impeller from volume 2(I searched through the webs and read about people doing this way).So,is that the right way?
And come to the meshing part,I first meshed the volume 2 with tet tgrid with sizing function and copper mesh the volume 1.This gave me a lot of highly skewed mesh and inverted volume.And now I am stuck.
Can anyone provide me with some guidance to do this?
Thanks;
Ming
behruz likes this.
boh_tea is offline   Reply With Quote
Old   July 19, 2010, 02:14
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
go to examine mesh, and set the lower value to 0.9
Update and you will see the skewed cells with quality over 0.9.
It is a good indicator to know the reason for skewed cells.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 19, 2010, 05:06
Ming
Hi
Most of the skewed cells are in the impeller region.I think I did the wrong method in meshing the region.I just don't know where to start meshing even after reading the few gambit tutorials my lecturer gave me.
Thanks for replying
Old   July 19, 2010, 05:54
-mAx-'s Avatar
Maxime Perelli
you must start fixing skewed cells problem.
Check if you don't have small edges or small angles in this impeller region
Old   September 29, 2010, 09:57
Default Hello Mr Ming
Jawid
jawidnaik is on a distinguished road
Hi Mr Ming, I am a student and have to work on CFD simulations of Stirred Tank equiped with Rushton Turbine. I solved certain tutorials to start with.
Now, I want to make the geometry of the Tank and Rushton Turbine in Gambit and then mesh it.
Could you kindly suggest me how to make geometry of Rushton Turbine in Gambit and how to club Turbine geometry with Tank geometry.
Thanks and waiting for reply
Jawid Naik
jawidnaik is offline   Reply With Quote
Old   October 5, 2010, 02:03
Ming
Hi jawidnaik,
At the moment,I am using the tank meshes that are given by my lecturer,so i have no exact detail on how to construct and mesh it.If you found it please share with me too!Thanks!
Old   October 5, 2010, 03:17
Jawid
Thanks ming for reply. could you please send me some of tank meshes which your guide has given to you, so that i can get some idea.
Regards
jawid
Old   March 24, 2013, 16:47
behrooz
behruz is on a distinguished road
Originally Posted by boh_tea View Post
Hi all,
Thanks;
Ming
hi boh_tea. i have similar project to u.and i need mesh of rushton turbine that surrounding with a tank. i need rushton turbine that import to gambit and mesh it.can u give me this?
behruz is offline   Reply With Quote
Old   March 24, 2013, 16:56
Default mesh of rushton turbine
behrooz
hi all
now i am working on the stirred tank with rushton impeller similar to "boh_tea"
i need a rushton turbine file to import to gambit for meshing.
or provided mesh of (rushton turbine that surrounded with tank).?!!
thanks
Old   March 25, 2013, 03:47
Paritosh Vasava
vasava will become famous soon enough
In gambit there are ways to visualize the mesh quality. You can visualize the exact problem area and you can try to fix it by controlling the mesh size.
vasava is offline   Reply With Quote
Old   March 25, 2013, 15:02
behrooz
dear vasava i need rushton turbine with(solidwork or catia or turbo file) that gambit support it. do yo have this?rushton.JPG. i want to put a rushton turbine in a tank and run it in fluent.
thank.
Old   March 26, 2013, 02:48
Paritosh Vasava
Try this file.
Old   March 29, 2013, 12:26
behrooz
thanks dear vasava
i can not import this file that u attached in gambit!
Old   March 29, 2013, 14:29
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi
I recently simulated a stirred tank with a pitched blade turbine. As you said generating a neat mesh for stirred tank is not an easy thing and it requires somehow diligency. I just can advice you that do a proper splitting and try to use a structured mesh inside rotating part. You can do it by dividing your geometry in a appropriate way. Another strategy is to use unstructured mesh and refine it by using adaption tool in fluent. It's very effective. You can find more details in this regard in fluent user guide. Even there's a tutorial regarding a bend pipe. You can use it to get some insight if you don't know how to work with adaption tool. Hope it help.
Regard yours
A CFD free user is offline   Reply With Quote
Meshing of a stirred tank reactor Ajayi Olukayode FLUENT 8 October 3, 2012 03:24
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 02:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 06:04
CFX 5.5.1 stirred tank and LES problem Nishant CFX 2 September 13, 2002 08:11
