Fluent: Mesh Adaption based on Gradient
Like Tree1Likes
  • 1 Post By enigma
Old   July 7, 2010, 06:33
Default Fluent: Mesh Adaption based on Gradient
enigma is on a distinguished road
G'day Everyone,
I'm having a little difficulty with Fluent and its gradient mesh adaption tool. I have an unstructured mesh, based on quads, 3-dimensional which I adapt and refine in Fluent. The problem is, that Fluent would not let the cells be less than one quarter the size of the surrounding cells, no matter how many times I refine the mesh, it would always not only refine the cells with the high gradients, but also the surrounding cells. It somehow would not allow cells to be too different in their size.
One can see that in the attached example, cells are smaller where the gradient is high (pressure gradient in this case), however, 4 of those small cells are always the same size than 1 large cell. If I force Fluent to refine the mesh, it would qualitatively be the same ratio.
Does Anyone have some experience with this?
Can anyone help?
Thank you very much in advance!
enigma is offline   Reply With Quote
Old   July 10, 2010, 06:47
Mistake found - ANSYS RESULTS does not refresh the mesh data when I import a new case and dat file from Fluent. Fluent actually does refine properly. All fine now.
Old   July 14, 2010, 18:54
Smile
Mohammad Ghazvini
mahmohammad is on a distinguished road
That's good that your problem is solved.
I have two questions: First of all, how can I increase the grid size? I tried coarsening but it doesn't work! I just want to increase the grid size.
And second: as it is obvious in the picture you attached, When I try to refine the mesh, Fluent divides each cell into four. How can I do it different? I mean how can i divide each cell into two or three cells?
Thanks a lot
Mahmohammad
mahmohammad is offline   Reply With Quote
Old   July 14, 2010, 21:26
Fluent can't coarsen beyond the original mesh size. It can only coarsen where it has previously refined. Unfortunately, there's no way (I'm aware of) that you can modify the algorithm so that 1 cell is replaced by less than 8 cells (in 3D).
Mazze[ITA] likes this.
Old   July 15, 2010, 18:36
Mohammad Ghazvini
Ok!
that was not good news but thanks for responding!!
Mohammad
[ICEM] export hexa mesh to fluent Wieland ANSYS Meshing & Geometry 37 January 23, 2013 04:27
Mesh Adaption in CFX. Kushagra Mittal CFX 1 August 31, 2011 09:17
Fluent not displaying mesh Witchking782 FLUENT 5 February 11, 2010 03:19
mesh for fluent 12 hsn ANSYS Meshing & Geometry 4 September 17, 2009 15:54
Mdlin UAV Help req, Mesh size + Error in FLUENT whats_in_a_name FLUENT 0 February 5, 2007 03:34
