April 16, 2010, 16:08 |
How to turn off the reversed flow notice?
M H Z
Rep Power: 17 |
I am running a fluent case with flow field. The bottom text window is flooded with the reversed flow messages.
I understand this is good for warning purpose. I still prefer to know how to turn it off. Is there an option in fluent? Thank you, mhz |
April 17, 2010, 11:09 |
heidar jafarizadeh
Rep Power: 16 |
hi
no problem dont be worry about that it is about the flow nature. please see yr end result then make a dicision. bye |
April 19, 2010, 04:03 |
Max
Rep Power: 17 |
this text-command will do the trick:
type: solve/set/flow-warnings? and enter no if asked to enable flow warning messages cheers |
fluent reverse flow |
reversed flow | free | FLUENT | 4 | February 27, 2014 02:56 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 14:11 |
reversed flow | Sastry | FLUENT | 5 | March 22, 2007 09:05 |
reversed flow | mukkarum | FLUENT | 1 | April 13, 2004 12:17 |
Error Message: Reversed flow | Mnu & Luc | FLUENT | 3 | February 5, 2003 08:02 |
