High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) |
February 28, 2010, 08:33 |
Rep Power: 17 |
I am modelling the 2D vertical axis wind turbine (VAWT). The turbulence model is k-epsilon with std wall function. I simulate 4 angular velocities: 5, 10, 15 and 20 rad/s. Wind velocity is 11 m/s. Model is using U-RANS with sliding mesh. Problem is that I obtain excessively high torque calculated from the Cm (4 to 5 times larger than it should be). Cm is obtained from Fluent, torque calculated with the Cm definition(Cm=T/(0.5 x rho x v^2 x A x R). Time step: tried both time steps corresponding to 1 degree and 1/8th degree. Results perfectly match so the 1deg step is fine enough. I would be very grateful to the one who can spot if and/or where I am making a mistake and can contribute to making this simulation happen the best way. Thanks All the best TonyMac Last edited by tony00; March 17, 2010 at 06:25. Reason: wrote seconds instead of degrees to define the angular step increment |
March 16, 2010, 17:34 |
benoit paillard
Rep Power: 16 |
that might sound - and actually be - silly but check that you actually divided the torque by the appropriate value, to get a reduced coefficient instead of a Nm torque. That happened here not too long ago.
March 19, 2010, 09:26 |
Rep Power: 17 |
Hello Benoit,
all solved and getting pretty good results now. As you suggested it was indeed a problem with the constants entered in report-> reference values. Thanks Tony |
March 22, 2010, 23:43 |
Change fluent reference values
Haris Hameed
Rep Power: 17 |
compute velocity form inlet and change reference area to swept area your cm will change hope this work |
April 1, 2010, 01:59 |
#5 | |
SHIVA
Rep Power: 16 |
I m also facing the same problem. still i m not able to reasolve the fluent case. please give some idea to predict the Torgue and Co efficient of the performance (Cp) of the wind Turbine. With Regards S.SIVAKUMAR |
June 11, 2010, 06:15 |
Rep Power: 16 |
Hi tony, maybe I'm affected by the same problem you solved.
I hope you will share with me your solution. Thanks |
February 21, 2014, 01:07 |
Doubt
dynamic
Rep Power: 13 |
In the Cm definition, what is A(area)?
March 25, 2014, 02:56 |
June 2, 2014, 03:25 |
high value of Cm
#9 | |
Aalisha
Rep Power: 12 |
-Aalisha |
January 9, 2015, 23:27 |
#10 |
For a 2D case should I take the area = 1, and in this case what should be the depth.
March 27, 2017, 02:51 |
CM coefficient
#11 |
nima seyfi
Rep Power: 9 |
hi
can anybody help me please what is A and L in equation of CM blow: cm=M/0.5*RHO*U^2*A*I my case is a vertical axis wind turbine archimedes spiral wind turbine blade |
July 23, 2018, 07:13 |
#12 |
UTTAR PRADESH
VAWT Wind Turbine | Tom Smith | FLUENT | 11 | August 27, 2011 02:38 |
my VAWT Darreius coefficient of performance high above Betz efficiency | radix | FLUENT | 0 | August 27, 2009 01:51 |
Moment coefficient of vertical axis wind rotor | Agni | Main CFD Forum | 0 | August 28, 2008 07:07 |
help to find torque of a wind turbine using fluent | athiyaman.p | FLUENT | 1 | March 10, 2006 11:49 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
