Grid Interfaces
Like Tree1Likes
  • 1 Post By -mAx-
Old   January 11, 2010, 01:15
Default Grid Interfaces
soggy316 is on a distinguished road
I am solving a case where a flow is past a vibrating cylinder. After much heartburn, I have got the dynamic mesh working for a small rectangular neighborhood around the cylinder, the rest of the domain being stationary. As a result, I have to define interfaces between the two zones.
Now when I create a grid interface FLUENT creates a wall at that location. and I do not require that as the the two zones are the same fluid.
Is there a way to prevent the creation of those walls?
soggy316 is offline   Reply With Quote
Old   January 11, 2010, 02:20
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you should create your interfaces in Gambit (2 superposed interfaces set as 2 separated interfaces --> interface_1 and interface_2)
Then in Fluent, go and define interface as one set, say interface_A, and choose interface_1 and interface_2.
6863523 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 11, 2010, 03:51
herntan's Avatar
YH Tan
herntan is on a distinguished road
cannot understand what u trying to do. Please post picture and describe more detail.
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   January 11, 2010, 05:33
Here is a screenshot of my problem domain
I create 2 mesh files
The yellow box around the circle is the boundary between the two mesh files
The common boundaries of both meshes are set to "interface" boundary condition.
the grid is assembled using tmerge
Now I bring the entire mesh into fluent, and assign grid interfaces as left, right, top, bottom, using the overlapping interface boundaries of both meshes
Now, when I do this , it creates a number of walls at the interface location, which totally screws up the flow solution.
My question is - how do I create the grid interface such that either no walls are created, or how do I delete/deactivate these walls that have been created automatically
Old   January 11, 2010, 05:57
herntan's Avatar
YH Tan
soggy,
Grid interface will only useful on 2 touching surface (not common one) and after create grid interface, this 2 surface will allow fluid flow through each other.
For your case , if its a common surface, change it to "interior" then the flow can pass through each other already.
If u want to have movement of the yellow box, u need to create 2 surface touching like i said in order for the touching surface sliding on each other.
hope this helps.
Herntan,
Old   January 11, 2010, 06:05
^ so as I understand it, you are saying that I cannot have an interface between two fluid zones in fluent.
The issue that I am facing is that the circle moves up and down inside the yellow box, the mesh in the yellow box is thus deforming, but the surrounding mesh is stationary, so at the border , the mesh will be non-conformal, so I went for grid interfaces.
If fluid-fluid interfaces cannot be created, then does anyone have any idea on how to get the remeshing option to work in dynamic meshes?
Old   January 11, 2010, 13:32
-mAx-'s Avatar
Maxime Perelli
what you are trying to do seem to be ok from my side.
If your motion is a translation, I would let move your box (and the fluid domain inside, as rigid body), and use remeshing option (--> no need interfaces).
But your model should work (you set up 4 interfaces pair).
Can you provide the .dbs file (from Gambit)
Why are the outter edges of the big domain yellow?
Old   January 14, 2010, 21:36
herntan's Avatar
YH Tan
soggy,
i guess you have to post more picture on what u trying to do with pointer pointing out how u set it.
i agree with -Max- comment on having ur box as rigid body.
another method is setup interface pair. u need to change ur gambit model and break up the common surface then create interface out of it.
Herntan,
Old   January 14, 2010, 23:24
sorry for the delayed response...
The flow simulation is working with the setup that I have created (with four interface pairs) I was getting confused because Fluent-Post was screwing up the streamline plot, the vector plot confirms that the fluid is able to flow through the interface without problems.
Thanks for your help - herntan and -max-
Old   February 2, 2010, 21:53
fanbin
alex-fan is on a distinguished road
your job is great can you email a example of dynamic mesh thank you verymuch
alex-fan is offline   Reply With Quote
Old   March 10, 2010, 12:44
Herman
enry is on a distinguished road
Hi Soggy,
I also use interface between 2 portion of fluid: moving and stationary fluid.
I also noted that FLUENT creates 2 new wall, that is mentioned in User manual, but I don't understand if I have to change the boundary conditions that FLUENT assign to the new walls. Flow go through the interface, so I realized that everything is correct, but I would like to know why FLUENT create that walls.
Thanks.
enry is offline   Reply With Quote
Old   May 4, 2012, 02:40
Default Moving mesh inside another mesh
  #12
Zhi Wei Sok
zwsok is on a distinguished road
Hi all,
I just saw this suggestion on the forum and would like to consult people on the following problem:
I am currently working on a moving airfoil (translational and rotational). Since I need resolution near the airfoil as I want to observe vortex shedding, I would like the mesh around it to be structured and preferably fixed. The motions will be accommodated by the unstructured mesh outside the structured one, with smoothing and remeshing applied to it.
I am working on Fluent and the Design Modeler and Mesher from ANSYS workbench. Should I build 2 meshes or one? And how do I make one move and have the other one respond accordingly?
Your help will be so very much appreciated. Thanks!
Regards,
Sok
zwsok is offline   Reply With Quote
Old   May 17, 2012, 06:17
Samuele Z
samiam1000 is on a distinguished road
Dear Friends,
I read very carefully this thread and I have found it very useful.
I have some questions for you: first of all, I would like to know which solvers can be used to threat a moving mesh. I would need a multi-region domain solver, is it possible?
Also, one more point: is it possible - instead using moveDynamicMesh - to create 10 different meshes (with the fluent mesher) and then to perform a simulation on those meshes? If so, how can I pass the solution at time n as initial guess at time (n+1)? This could be a challenging point, since the meshes are differet at each time step.
I think that's all for now. Thanks for the help you will provide.
Samuele
samiam1000 is offline   Reply With Quote
grid interfaces kiko FLUENT 0 February 13, 2007 11:28
Grid interfaces in Fluent Omar Qazi FLUENT 1 January 28, 2006 19:55
Non-Conformal Grid Interfaces Sridhar FLUENT 0 May 3, 2002 04:04
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 23:26
