surface reaction rate with udf
Like Tree1Likes
  • 1 Post By yellow-stuff
Old   December 21, 2009, 08:26
Default surface reaction rate with udf
Gerhard Selle
yellow-stuff is on a distinguished road
hello everybody
i'm facing a problem getting the surface reaction rate after my simulations.
i wrote an udf for the reaction rate, but fluent is not able to compute the reaction rate. the output says zero everytime.
do anyone of you know how to get the surface reaction rate, so i can plot it?
thanks for your help
yellow-stuff is offline   Reply With Quote
Old   December 21, 2009, 19:24
Default Surface Reaction Rate
Krishna
t.krishnamohan is on a distinguished road
Please post the UDF that you have written.
Thanks
t.krishnamohan is offline   Reply With Quote
Old   December 22, 2009, 00:14
Gerhard Selle
oh this is the udf:
#include "udf.h"
#define R 83140000
#define p 1013250
#define pi 3.14159
DEFINE_SR_RATE(my_rate,f,t,r,mw,yi,rr)
Thread *t0 = t -> t0;
cell_t c0=F_C0(f,t);
real c3h8 = yi[0];
real o2 = yi[1];
real co2 = yi[2];
real h2o = yi[3];
real n2 = yi[4];
real rho_w = 1.0, sd = 2.49e-9, T_w;
real o_s,o_vac;
real xc3h8 = 1.0, xo2 = 1.0;
real tn,Tg,Ea3, Ea4, Ea5;
real rA3, rA4, rA5,rk3, rk4, rk5;
real ro,rate;
T_w = F_T(f,t);
rho_w = C_R(c0,t0)*C_T(c0,t0)/T_w;
c3h8 *= rho_w/mw[0];
o2 *= rho_w/mw[1];
co2 *= rho_w/mw[2];
h2o *= rho_w/mw[3];
n2 *= rho_w/mw[4];
/* Mole fraction of CH4 and O2 */
xc3h8 = c3h8/(c3h8+o2+co2 +h2o+n2);
xo2 = o2/(c3h8+o2+co2 +h2o+n2);
Tg = C_T(c0,t0);
tn = T_w/300;
/* Activation energies */
Ea3 = 0.0;
Ea4 = 0.126*tn*tn*tn*tn - 1.849*tn*tn*tn + 9.124*tn*tn - 13.253*tn + 23.903;
Ea5 = 4.0; //7.3 + 1.9*tn;
Ea3 *= 4184e7;
Ea4 *= 4184e7;
Ea5 *= 4184e7;
rA3 = (0.0542)*pow(tn,0.766);
rA4 = (8.41e12)*pow(tn,-0.796);
rA5 = (0.06)*pow(tn,0.154);
rk3 = (rA3/(sd*sd))*sqrt(R*T_w/(2*pi*mw[1]))*(p/(R*T_w));
rk4 = (rA4/sd)*exp(-Ea4/(R*T_w));
rk5 = (rA5/(sd*sd))*sqrt(R*T_w/(2*pi*mw[0]))*(p/(R*T_w))*exp(-Ea5/(R*T_w));
ro = sqrt(rk3*xo2/rk4);
o_s = ro/(1+ro);
o_vac = 1-o_s;
rate = rk5*xc3h8*(sd*sd)*pow(o_vac,2);
if (STREQ(r->name, "reaction-1"))
*rr = rate*pow(10,1)*1.7; // mol/cm2s --> kgmol/m2s * effectiveness
/* else if (STREQ(r->name, "reaction-2"))
*rr = -2*rate;
else if (STREQ(r->name, "reaction-3"))
*rr = rate;
else if (STREQ(r->name, "reaction-4"))
*rr = 2*rate; */
weilin likes this.
Old   December 26, 2009, 10:34
Gerhard Selle
does nobody has a solution or suggestions?
the udf is correct, but i can't display the surface reaction rate, although fluent is calculating it.
Old   January 29, 2010, 13:53
Default use "User Defined Memory"
Mi Hyun Kim
gkmih is on a distinguished road
It doesn't work to display the surface reaction rate in Contours panel under Reactions directly.
You can save the reaction rate in "User Defined Memory", then you can see the reaction rate in Contours panel under -> Contours of ->User Defined Memory -> User Memory #.
gkmih is offline   Reply With Quote
Help, UDF and define the surface reaction shuailin FLUENT 1 October 23, 2022 11:07
Referencing a Surface Monitor or Surface Integral in a UDF lanterbw Fluent UDF and Scheme Programming 4 January 28, 2013 16:31
problem about porous media and surface reaction Jeff Lee FLUENT 3 November 24, 2011 14:46
again on udf surface reaction jason FLUENT 0 November 7, 2003 11:45
User Defined Reaction Rate John McKelliget FLUENT 1 December 17, 1999 11:44
