UDF for time-dependent velocity polynomial using VOF model
Like Tree1Likes
  • 1 Post By rahaman
Old   October 26, 2009, 07:40
Default UDF for time-dependent velocity polynomial using VOF model
Rahaman Md. Mashiur
rahaman is on a distinguished road
For 2D water entry problem with VOF model I want to input the following inlet velocity polynomial
v(t)=2.436+3.82t+326.3t2-7255t3+39381t4
0.0<=t<=0.08
I worte the following UDF but it is not working , if possible please help me. I am beginner in writing UDF
#include"udf.h"
DEFINE_PROFILE(unsteady_velocity, thread, position)
face_t f;
real t=RP_Get_Real("flow-time")
begin_f_loop(f,thread)
F_PROFILE(f,thread,position)=2.436+3.82 *t+ 326.3*pow(t,2)-7255*pow(t,3)+39381*pow(t,4);
end_f_loop(f,thread)
Thank you very much
lazregenset likes this.
rahaman is offline   Reply With Quote
Old   October 26, 2009, 08:23
Krishna
t.krishnamohan is on a distinguished road
Can you tell about the error you are getting
t.krishnamohan is offline   Reply With Quote
Old   October 26, 2009, 10:14
Rahaman Md. Mashiur
thank you very much for your reply. actually it does not give any error when i compile it but i am not sure is it ok for my simulation case or not. Do u know what type of boundary condition to need to use for flow separation from sharp corner in case of inviscid model in FLUENT?
Thank you once again for your reply.
Old   July 17, 2014, 10:51
Default hi im soory .have guive mi your tim
lazreg
lazregenset is on a distinguished road
how to calcul A1.A2.A3....
http://jullio.pe.kr/fluent6.1/help/html/ug/node282.htm
im in th big pb .halp me soory and thanks
lazregenset is offline   Reply With Quote
Old   August 29, 2018, 08:56
Default How to write UDF for defining the fluid properties???
Devanarayanan
DevanK is on a distinguished road
I have set of polynomial equations which defines the water properties like density, thermal conductivity,dynamic viscosity, specific heat capacity and i want to write UDF for my research work. kindly explain me with example.
Linkhttps://syeilendrapramuditya.wordpre...ic-properties/)
DevanK is offline   Reply With Quote
Phase velocity in VOF model UDF baechtel Fluent UDF and Scheme Programming 2 August 4, 2019 12:17
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
help; UDF of VOF model Jay FLUENT 1 March 5, 2005 01:00
UDF for ellipse shape volume patch in VOF model nazeem FLUENT 1 October 8, 2004 12:22
