urgent!!! please...about Premixed Combustion
Like Tree1Likes
  • 1 Post By t.krishnamohan
Old   October 20, 2009, 06:42
Angry urgent!!! please...about Premixed Combustion
Kharisma San
mesinUGM is on a distinguished road
hei guys...
i still confuse about premixed combustion model in fluent because i didn't have any tutorial about it...
i confused about mixture material...
how 2 to mix it??
if in non-premixed we used the Pre PDF...
what should i use in premixed combustion model???
and if among of you have the tutorial, please share to me...
send to my email...
(kharismasan@yahoo.com)
thx before..
respond please...
mesinUGM is offline   Reply With Quote
Old   October 26, 2009, 08:07
Krishna
t.krishnamohan is on a distinguished road
In premixed combustion, fuel and air are mixed to the molecular level. The reaction or flame is defined by a variable called progress variable. The value of the progress variable will define the reaction like for example when it is zero it means no reaction occured and if it is one complete reaction occured.
ashishvshelke likes this.
t.krishnamohan is offline   Reply With Quote
Old   October 30, 2009, 05:03
Kharisma San
Ok!!! Thank you so much krishna...
But in my project i used 70%butane n 30%propane with stoichiometric formula
(0,3 C3H8 + 0,7 C4H10) + 6,05 (O2 + 3,76N2) -----à 3,7 CO2 + 4,7 H2O + 22, 748 N2
How to define the mixture material in fluent??
Can i define it if i used premixed combustion model??
If u ever tried about premixed combustion model, would u like to share it to me??
Because i need example or tutorial about it to do n compare with my project...
How??
N my project is about internal combustion/explosion in closed space without inlet and outlet..
Can i simulate it with CFD fluent??
n how ro use the spark ignition model??
Thanks awfully...
Old   March 30, 2012, 00:36
tsram90 is on a distinguished road
How??
Thanks awfully...
I am trying teh combustion of Hydrogen in a closed space without any inlets or exhaust. I have done a dynamic meshing and also injection but I cannot get the combustion. I have similar doubts that you had. Can you provide some tutorials or files you used . If you have mesh and case files of your work please share it.
id is sankarram90@gmail.com
Thanks a lot in advance
tsram90 is offline   Reply With Quote
Old   March 30, 2012, 01:04
Default About spark igintiion
tirtha
tirtha is on a distinguished road
I suppose you can use PATCH to create a high temperature zone in your geometry for ignition purpose and try if it works. About tutorials i guess you use the reference tutorial from fluent and try to use.
tirtha is offline   Reply With Quote
Old   March 30, 2012, 01:19
I havn't tried patch option.. and I basically don't know anything about it.. Can you please explain something about it, How to do it etc?
Old   March 30, 2012, 10:22
tirtha
I have not used fluent for long time now, but you have to select a location(cells) in the geometry where you want to patch. This can be done in the MENU-ADAPT-REGION panel. There you have to give the dimensions of the location you want to patch. The do go SOLVE- INITIALIZE-PATCH and give the conditions for temperature. Which version of Fluent are you using ?
There you can give the conditions. Its like selecting a zone near the inlet, just as igniter where you will assign a high temperature. Try to find some tutorials how to patch. Patching can be done in fluent itself. In the fluent user manual also some idea about patching is there. For patching a zone you dont need any UDF in my knowledge. So try it and let me know
Tirtha.
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 11:40
premixed combustion? bob FLUENT 14 June 13, 2016 10:39
Premixed Combustion IS FLUENT 3 July 9, 2010 21:22
Non-adiabatic Premixed combustion through scriptin Mahesh Main CFD Forum 2 April 1, 2007 02:04
Non-adiabatic Premixed combustion through scriptin Mahesh FLUENT 0 March 31, 2007 09:19
