Spatial vs Angular Discretization in DO radiation model |
June 1, 2009, 11:52 |
renaldi
Hi Everyone,
I am using Fluent to model radiation heat transfer inside a solar collector enclosure. The enclosure is filled with air (non participating). The surfaces include specular wall (a reflector), semi-transparent wall (cover) and spectral selective wall (so, non-gray radiation). The DO is the only model that can satisfy all these surfaces. I stumbled across a problem in determining the right pair of angular discretization (Ntheta & Nphi) and spatial discretization (mesh size). These are related to the inherent source of errors in DO, which are ray effects and false scattering. I have read from papers that "finer" is not always "better" in this particular case. Any suggestions on how to determine the "right" pair of angular and spatial discretization? I have an idea to do monte carlo ray tracing for my system and treat the result as the "exact" and then compare it against the Fluent results, but this seems a bit too much to attack this problem. Comments and/or suggestions are very much appreciated. Thank you |
February 16, 2024, 09:47 |
#2 | |
Milan
Rep Power: 13 |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 4, 2013 00:04 |
Help! P1 radiation model + multiphase | Aris | FLUENT | 0 | August 29, 2008 06:44 |
Radiation effects in model | Ken | Siemens | 8 | August 7, 2003 15:28 |
definition difficulty-->DO radiation model | Harry Qiu | FLUENT | 0 | March 29, 2001 10:19 |
RE: Radiation model | Ashutosh Joshi | FLUENT | 1 | January 30, 2001 11:50 |
