Fluent dynamic mesh-layering
Like Tree2Likes
  • 1 Post By coolengineer
  • 1 Post By wlt_1985
Old   April 9, 2009, 11:23
Default Fluent dynamic mesh-layering
Jack nedermans
coolengineer is on a distinguished road
I am solving the flow though a channel opened on a piston head which is moving inside a cylinder. Here, I am using layering type dynamic mesh. I can see the mesh moving without any problem in Fluent; however, when I were to iterate the solution it gives error as "Error: divergence detected in AMG solver: pressure correction
Error Object: ()"
When I work with ideal gas there is no problem. But when I am to work with a fluid, such a problem occurs. Can anyone advice me anything with that?
Thank you all. I am waiting from you.
coolengineer is offline   Reply With Quote
Old   April 9, 2009, 13:19
Default Maybe continuity
Jack nedermans
I think it is because of Continuity. When I use ideal gas as a fluid, Fluent goes on calculations without an error. However, when I chose a fluid, a kind of incompressible fluid, the continuity residual diverges. Would it be because of this?If so, how can I overcome this problem?
Master312 likes this.
Old   February 24, 2010, 21:58
Thumbs up Ask for help
Sina Fardisi
s_fardisi is on a distinguished road
Hi
I want to solve a similar problem and had troubles. Did you solve your issue, how?
I want to solve the fluid flow in a non circular culinder-piston configuration.
Originally, I would like to solve it 3D but let's discuss the 2D problem first. The cylinder walls have some curvature, for example each wall can be viewed as a 1/4 of a circle. The piston moves inside this curvilinear cylinder. My question is what is the best way to do it and how should I introduce the moving wall for the piston? Is there a good online help or a tutorial?
P.s.1 I think I have to use a mesh layering but I am not sure how I should account for the motion of the piston. I know Fluent has a pre-set situation for conventional cylinder piston problem in mesh layering but how can I expand it to non circular culinder-piston.
P.s.2 Do I have to use a moving wall? If yes do I have to write a UDF for it and in that case can I still use the mesh layering or I do I need re-meshing then?
Thanks in Advance
Sina
s_fardisi is offline   Reply With Quote
Old   August 18, 2011, 10:46
raymond
wlt_1985 is on a distinguished road
Originally Posted by coolengineer View Post
Error Object: ()"
I would like to have my model by having 'layering' scheme of dynamic mesh. Unfortunately, I am totally new in dynamic mesh and I might need your help in guiding me to have good dynamic mesh modeling which might similar with your case. My model is shown as the attachment. May I have your advise on how to do that. Pls help me. Thanks a lot.
eskandari likes this.
wlt_1985 is offline   Reply With Quote
Old   August 18, 2011, 16:18
raymond
Error Object: ()"
I would like to have my model as the attachment. I found that 'layering' scheme might be useful for my case which might have similarity with your case. Can please lead me to have proper way in setting the 'layering' scheme of dynamic mesh? Thanks for your help. It is urgent to me. Please help.
Old   September 20, 2011, 18:34
Daniel Jasiński
DanielJ is on a distinguished road
I know it's an old post but I have a question. What motion function do you use??
Do you use In-cylinder piston motion function??
DanielJ is offline   Reply With Quote
Old   March 10, 2022, 05:12
Post Dynamic mesh in Cylinder piston 2D
Amir
Master312 is on a distinguished road
I have 2D model Cylinder and piston. I've 3 interface. basically i set transient mode, ideal gas (for material), Spalart-Almaras turbulent mode.
Dynamic mesh is ON.
Test of "Preview mesh motion" is done.
Piston move and layering meshes done.
But, when i Run solver after 30 time step before the first sliding interface give an error:
"error at node 2: coalesce_rib_faces : can't interpolate data, zones of different type detected"
I need help.
of course i set "events" for interfaces as "create sliding interface", on time.
all sets of mesh checked in pictures.
Thanks.
Master312 is offline   Reply With Quote
Old   May 31, 2022, 11:01
Smile Answer
Amir
Dynamic mesh is ON.
I need help.
Thanks.
hello me
you must change your boundary condition of "walls to interface" in "direction" of your interface. in other words you must change all boundary conditions that slide through "motion wall" to interface and then define them in manual interface. in the last you have all boundary conditions of slider with "interface" mode, "no" part of that.
dynamic mesh, layering
Fluent 6.3 Tut 12: Dynamic mesh RolandP FLUENT 23 August 10, 2023 05:25
Dynamic Mesh with Boundary Layer Marcell FLUENT 0 March 11, 2009 09:40
prob while exporting icem cfd hexa mesh to fluent mani CFX 4 March 7, 2007 04:41
How to convert STAR mesh into FLUENT mesh ? Jihwan Siemens 8 November 10, 2004 05:11
Dynamic mesh & Multiphase Alexandre FLUENT 3 September 13, 2002 12:35
