March 2, 2009, 21:35 |
Running Existing Code: Commands Grayed Out
I have some Fluent simulations that I'd like to modify. I've been given (via email by a former student) the .cas and .dat files for the simulations as well as some .c files which are UDFs that specify a dynamic mesh and micromixing/crystal size distribution within the cells. At this point, I'm just trying to run the simulation. The code was originally written for Fluent 6.1.22 and the mesh created in Gambit 2.2. I'm using Fluent 6.3.24 and Gambit 2.4. If I read the .cas file, I get a few errors, but I also have a lot of grayed out (unselectable) options like solve->iterate, solve->initialize as well as the define->boundary conditions, write->case, etc. Options like display->grid, etc. work fine. I've followed the tutorials, and I am able to compile the UDFs which removes the "library does not exist" error, but does not solve the problem of grayed-out commands, so I'm not really able to initialize the problem (or check to see what's going on with the boundary conditions). There's only one remaining error upon reading the .cas file; i.e. "Error: Arg(3rd) out of range in substring. Error object 5." I haven't determined what this means yet.
I'm looking for a reason that solve->initialize and define->boundary conditions would be unavailable or what "Error : Arg(3rd) out of range in substring" means. Thanks. Can you explain why some options are unselectable and give me some direction for running this simulation? Thanks, Michael Rasche |
July 25, 2012, 08:11 |
Richard Parker
Rep Power: 14 |
Hi Michael,
Did you figure it out, finally? I've encountered the same problem, but using the same version of fluent and gambit i used to create the .cas file. Not a big problem to me, as I can re-do the case quickly. But I feel curious about it, nonetheless. Did you manage to solve it? Josep |
Self implemented code is not running in parallel | michi | OpenFOAM Running, Solving & CFD | 2 | November 6, 2008 06:09 |
Workbench Simulation Grayed out - Not installed? | Stewart Long | Main CFD Forum | 0 | October 28, 2008 07:42 |
problem in running code | yaseer | Main CFD Forum | 0 | March 23, 2007 12:08 |
Error showed up when running code | tangd | OpenFOAM Running, Solving & CFD | 1 | July 14, 2006 05:26 |
Running MPI code on a multiprocessor node | wen | Main CFD Forum | 7 | April 19, 2006 17:35 |
