December 2, 2008, 06:59 |
S2S radiation - view factor file error
Hi there, I want to use the s2s radiation model in a simple 2D geometry, a 2d segment of a square duct (fluid flowing inside a hot-wall square duct). While trying to write the view factor file I get the following:
//////////////////////////////////////////////////////////// "The number of radiating faces and radiating clusters are : 17441, 17441 Done. opening file C:\Documents writing file Settings\user\radiation.s2s.gz using 1 processor(s) FATAL ERROR: Cannot open parameter file C:\Documents Provide full path to I/O file C:\Documents command to execute: "C:\Utils\Fluent.Inc\utility\viewfac2.2\ntx86\vfs2 21.exe" C:\Documents and Settings\user\radiation.s2s.gz The system cannot find the path specified. Reading "| gunzip -c \"C:\Documents and Settings\user\radiation.s2s.gz\""... You must read in a view factors file or disable S2S model before proceeding. Error: Failed while reading view factor file. Error Object: () Error: Error reading "| gunzip -c \"C:\Documents and Settings\user\radiation.s2s.gz\"". Error Object: #f" //////////////////////////////////////////////////////////// The same error occurs even if I don't compress the file (.gz extension). I get the same error even in 3D geometry. Any possible solution? Thanks in advance. |
May 12, 2009, 07:17 |
Rep Power: 17 |
probably white-space in the specification of file name is an issue.
Unable to read view factor file | Peter | FLUENT | 0 | July 18, 2008 03:03 |
View Factor calculation in Fluent | Markus | FLUENT | 0 | November 13, 2005 21:59 |
Fluent - View Factor for s2s radiation | Markus | FLUENT | 1 | October 16, 2005 02:33 |
VIEW FACTOR CALCULATIONS | Cedric | Siemens | 2 | August 22, 2005 12:22 |
Radiation view factor | Lemas | Main CFD Forum | 4 | September 14, 2003 01:17 |
