Torque calculation with fluent
Like Tree1Likes
  • 1 Post By mAx
Old   October 21, 2008, 05:30
Default Torque calculation with fluent
s wang
Hello all,
I am currently implementing Fluent to simulate the wind turbine.I want to calculate the torque generated by the blades.Could anyone pls give me some advice on the calculating of torque?
Advanced thanks.
S.Wang
Old   October 21, 2008, 05:47
Default Re: Torque calculation with fluent
sushil
Hi Wang,
I am also trying to simulate the wind turbine. could you please tell me what boundary conditions you are using and whether you are simulating with dynamic mesh or with Axi-symmetric boundary conditions?
Please help.
Thanks in advance.
Regards, Sushil.
Old   October 21, 2008, 05:55
mAx
report/forces here you can compute moments on your blades
Old   October 21, 2008, 05:59
s wang
Hi Sushil,
Thanks for your email. Actually, my interests focus on the Vertical axis wind turbine. I guess you are talking on the Horizontal axis wind turbine, right? In my opinion, we could use the moving mesh or moving reference frame instead of dynamic mesh.
Cheers,
Wang
Old   October 21, 2008, 06:03
s wang
Dear mAx,
Thank you for your email.
Yes, I could use the menu you mentioned to calculate torque. However, what if my simulation is unsteady and needs to calculate the moment with time?
Regards,
Wang
Old   October 21, 2008, 06:32
mAx
then you can write your torque in a file at each time step check the box "Write...", then you need a udf for writing your results at each time step. perhaps, there is another way, but this one works
libyano likes this.
Old   October 21, 2008, 06:34
s wang
Dear mAx,
Thanks for your reply. I will try your advice.
Best regards,
Shengyi Wang
Old   October 22, 2008, 01:07
sushil
Hi Wang,
Thanks for the inputs. Yes I am working on horizontal axis turbine. What BC's you are using..?
Have a nice time.
Regards, Sushil.
Old   October 22, 2008, 08:34
s wang
Hi Sushil,
In my case, I prefer the pressure-far-field as the inlet BC. By the way, I am not performing the 2D simulations and my domain is a parabola.
Pls give some advice if possible.
cheers,
Shengyi, Wang
Leeds
Old   October 22, 2008, 08:37
s wang
Sorry, there is a mistake in the above message.
It should be 'I am now performing a 2D simulation.', not 'I am not...'
Regards, Shengyi
Old   January 14, 2013, 10:37
Default how to calclutate torue in fluent
  #11
bhushan patil
p.bhushan2727@gmail.com is on a distinguished road
dear frnds plz tell me hoe to calculate torque in fluent i am working on vertical axis wind trubine h shaped daarruis type so for that concern ia m doing 2d simulations unsteday for that i am giving cl ,cd cm moniters on blades so will plz tell me how to find out direct torque in flunt or how to co relate it 2 moment ia m aatching paper and some images of my mesh so it will clear u piture of problem
plz tell me it needs udf to find torue on blades
p.bhushan2727@gmail.com is offline   Reply With Quote
Old   February 9, 2017, 10:45
Jose Carlos
jotac is on a distinguished road
Originally Posted by mAx
;154187
Hi, would you have this UDF and if yes, could you share it?
Thanks,
Jota
jotac is offline   Reply With Quote
torque calculation Mac Siemens 3 December 11, 2007 23:13
Torque calculation in pumping equipment Kirill Main CFD Forum 0 June 26, 2007 17:59
torque calculation sudhakar CFX 15 January 5, 2006 10:08
torque calculation Galeazzo FLUENT 2 July 1, 2004 12:32
torque calculation baned FLUENT 1 August 29, 2003 13:53
