June 22, 2008, 21:48 |
Adding Van der Waals force by coding UDF
Hi everyone:
I am new in UDF. I wanna add the Van der Waals force between two droplet while they are moving through a constricted capillary tube. But there are some questions confused me. I choose the VOF model to define the dispersed phase(droplet) and the continuous phase (drop suspended in). I wonder how to identify the distance between the two droplets surface? (The Van der Waals force is function of the distance between two droplets). Has anyone done solved the same problem? If possible, could you sent me a UDF code or give me some detailed advice? Thank you very much!!! |
June 23, 2008, 07:44 |
Re: Adding Van der Waals force by coding UDF
hellow friend i also doingsame analysis if u get any information plz forward me.
Urgently Need the code of Lift force and VM force | Kai Yan | Main CFD Forum | 0 | July 16, 2008 07:07 |
MRFZonesC questions what is the mesh_V and why only Coriolis force no centrifugal force | waynezw0618 | OpenFOAM Running, Solving & CFD | 49 | April 8, 2008 04:23 |
Coding for CFD | Jonathan | Main CFD Forum | 5 | January 12, 2007 04:59 |
how to calculate prssure force & lift force in CFX | zaidun | CFX | 4 | March 28, 2006 02:06 |
Coding | begineer of cfd | Main CFD Forum | 1 | July 21, 2004 05:11 |
