How to create a UDF
Like Tree1Likes
  • 1 Post By suvash
Old   June 6, 2008, 23:30
Default How to create a UDF
Sean
Hi, everyone,
I have a question about UDF: I copy and paste the code from the FLUENT UDF manual and save it as a .c file. What should I do then?
In the FLUENT UDF manual, Ch5.2, there is a note: " Note that if you are running serial or parallel FLUENT on a windows system, then you must have Microsoft Visual Studio installed on your machine and have launched FLUENT from the Visual Studio console window to compile a UDF"
But how to "launch FLUENT from Visual Studio console window"?
Best regards,
Sean
Old   June 12, 2008, 00:39
Default Re: How to create a UDF
suvash
Open the command prompt of visual C++. Then drag the fluent shortcut from your desktop to that command prompt. The fluent will be launched.
I hope it helps you.
coolgame2004 likes this.
create waves aginor FLOW-3D 12 October 11, 2008 21:48
create new material charlotte FLUENT 1 May 30, 2006 05:05
create Furkan Oezkan Siemens 4 November 10, 2005 10:13
how to create a brick using PIL sun Phoenics 1 April 24, 2002 12:18
could someone tell me how to create a shell zsw Siemens 1 October 28, 2000 20:11
