Reference Values- Reference Area
Like Tree4Likes
  • 2 Post By Syed Shabbar Raza
  • 1 Post By Syed Shabbar Raza
  • 1 Post By ama294
Old   March 11, 2008, 02:16
Default Reference Values- Reference Area
Shivakanth
HI,
I am relatively new to Fluent and bit confused over the reference values setting. As I followed the examples, sometimes they are considering projected area( ex:cylinder) normal to the flow and in some cases length of the object(ex: aerofoil). Could some one explain me the proper area to be selected?
Thanks, Shivakanth.
Old   March 11, 2008, 03:40
Default Re: Reference Values- Reference Area
Syed Shabbar Raza
it really simple,
for example if you have to calculate the drag coefficient for a geometry, like flow passing a cylinder, in this case you have to specify its bases area for its reference area, if you remember the formula of drag coefficient, there is an area term present and this area term is taken as reference area in fluent.
same with length, when u have to calculate moment coefficient you have to specify it !!
hope u understand !!
sajid and cessna172 like this.
Old   March 11, 2008, 14:57
Shivakanth
Hi Syed... Thanks. Just for confirmation, if a take a plate bent in the form of an arc, the arc length would be reference area(unit depth) and reference length right?
Thanks, Shivakanth.
Old   March 12, 2008, 01:54
Syed Shabbar Raza
dear, when ever u generate a report, always mention your reference condition becasue for certain gemotries like a sphere, it is understood to take its projected area as reference area, so therefore i advise u only to take standard refernce for an analysis,else where ever mention.
the question of reference parameters are stickly concerned with the geometry and type of problem, therefore do mention your reference condition in your report so other could understand it.
for fun, just take a problem concerning flow over a cylinder form any fluid mechanics book, solve it both analyticaly and computationally then u will have an idea of reference parameter
rajann_786 likes this.
Old   March 12, 2008, 02:07
shivakanth
Hey Syed...
Thanx.. as u said, let me do some homework and get back to you.
Old   April 18, 2010, 06:48
Default reference value
hassan
hassan79 is on a distinguished road
hi sir
could u plz told me about refence value i wana calclate surface nuselt no in expansion pipe( diffrent diameter ) with down strean what should i used for :
temprature
lenghth
area
height
velocity
thank u
hassan79 is offline   Reply With Quote
Old   December 1, 2011, 14:18
Default Depends on your problem
Kamran
kamran651 is on a distinguished road
Bro, it entirely depends on your problem..what you have taken temperature, length, and depth..
kamran651 is offline   Reply With Quote
Old   December 13, 2012, 16:30
Default area problem
Chaudhary
sajid is on a distinguished road
i want to calculate area of circles which would be used in ansys fluent ....
it is 2d heat exchanger and i have problem how to calculate area of circle in front of flow or which area i have to put in reference value ..
i have confusion whether i have to use area of 2 or 4 circles ???
kindly tell me how to calculate this area or which area i have to put in reference value ??? i have attached the jpeg. file of structure to further explain it ?
waiting for answer...i will be very thankful to you.
what Reference values should I used in fluent to find the area as defaults values are 1 for area,depth and length.
Area=?
Depth=?
sajid is offline   Reply With Quote
Old   August 26, 2014, 19:40
Arif Alam
arif1729 is on a distinguished road
hey guys. i m new at cfd.i want to find the lift and drag,moment coefficint of an aircraft.but in case of reference value i have some problem.what should be the reference values for this.and what is this 'compute from'.
plz guys if anyone has any solution help me.
arif1729 is offline   Reply With Quote
Old   October 19, 2014, 09:42
bia
nabaouia
bia is on a distinguished road
i have the same problem and really fed up
my geometry is : the computatinal box 400mm* 750 mm the diameter of the cylinder is D=15mm. Re =150 .velocity inlet = 0.1460735 .
the problem is how to set the reference values : when i set reference area = Pi*D (seen as a lateral area ) depth =1 and length = Pi *D/2
i found the average of drag coefficient 0.45 less than 1.34 (value found in litterature ) so i change length to 1 and depth to 3 (3 = 1.34/ 0.45 ) i found values recommended but why 3 ????????????????????
bia is offline   Reply With Quote
Old   October 2, 2015, 10:03
Default Unavaileble reported araeas- FLUENT
  #11
Oula
Oula is on a distinguished road
Hello every one, I am working on simulating 2-D flow passing a circular cylinder. I got a problem with the reports> projected areas, it is not available on the screen and I can't get the parameters that I need which is the projected surface area. Can anyone help me with that?
Many Thanks
Oula
Oula is offline   Reply With Quote
Old   November 9, 2016, 00:04
Abdulaziz Abutunis
ama294 is on a distinguished road
In the help manual it says
sets the reference area, which is used to compute the force and moment coefficients.
sets the reference length, which is used in the computation of the moment coefficient.
I think that is mean
Area = wing/cylinder area (chord*span/ diameter*height), and length = cylinder diameter/ wing chord.
derbaz53 likes this.
ama294 is offline   Reply With Quote
Old   June 6, 2017, 01:18
Rana
Rana shaharyar is on a distinguished road
how to take reference length and area for d wing
Rana shaharyar is offline   Reply With Quote
Problem to set reference AREA of a sphere? Mahbub FLUENT 1 September 20, 2013 07:52
reference area in case of symmetry condition Micheal Main CFD Forum 1 December 24, 2008 04:14
Area & Depth of Reference Value Jongsoo FLUENT 0 December 4, 2008 22:31
reference values evans FLUENT 1 January 29, 2008 07:22
reference values Mavinakere FLUENT 0 March 10, 2002 12:00
