Partial pressure calculation in fluent
Like Tree1Likes
  • 1 Post By BG
Old   February 4, 2008, 15:04
Default Partial pressure calculation in fluent
Priya
Hello All,
I have Species reaction taking place in a fuel cell volume and would like to calculate the partial pressure for each individual species (essential for calculation of nernst potential.) Any suggestions ??
Thank you!
Old   February 5, 2008, 04:50
Default Re: Partial pressure calculation in fluent
BG
Partial pressure is (molar fraction)*(absolute pressure), both are Fluent field functions available for processing. You can do it automatically with a custom field function.
souza.emer likes this.
Old   February 5, 2008, 11:51
Priya
Thanks BG! But is there a macro that can be used to get the molar fraction. My partial pressure term is part of a UDF and I need to calculate it at every iteration. I know that C_YI(c,t,i) is used for mass fraction, but I could not find one for molar fraction.
Old   February 5, 2008, 12:55
PKN
probably, we can use molecular Weight to convert mass fraction to molar fraction....
Old   February 7, 2008, 15:42
Priya
Thank you guys for the help. I used the mass fraction and molecular weight to get to the partial pressures and I think it worked well
Old   December 5, 2010, 15:03
Default UDF:Partial Pressure calcualtion of species in gas seperation thry membranes.
Azharuddin
azharuddin0613 is on a distinguished road
I'm solving a case for gas seperation through membrane in which i need to calculate the partial pressure of each species as permeation is depended on partial pressure in my case. To calculate my mass flux rate thru membrane I need partial pressure.
Can anybody help me in calculating partial pressure of species thru UDF.
thanks a ton
I'M IN URGENT NEED OF IT, PLZ HELP
azharuddin0613 is offline   Reply With Quote
Old   May 29, 2011, 12:03
Default partial pressure
sabrine
sabrine is on a distinguished road
I have a surface aerated stirred tank. I need to calculate the volumetric mass transfer coefficient Kla. Is there any way to determine the partial pressure of the air incorporated in the water knowing that there is always a quantity non incorporated of air above the surface? Otherwise how can i just know the concentration of the air incorporated in the water using Fluent?
sabrine is offline   Reply With Quote
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
pressure calculation in Fluent rakadit FLUENT 0 June 6, 2011 03:13
Different kinds of pressure in FLUENT Mattia FLUENT 0 October 22, 2007 09:52
Calculation of pressure forces in Fluent Maharba FLUENT 2 June 29, 2007 02:14
a problem in calculating pressure drop in Fluent? yu chun FLUENT 1 May 18, 2004 04:40
