Density based solver in Fluent
Like Tree1Likes
  • 1 Post By Bart Horsten
Old   November 1, 2007, 05:03
Default Density based solver in Fluent
Bart Horsten
Hello! I have the following question: Is it possible to use the density based solver in Fluent for low Mach number flows (M=0.17)?
Old   November 1, 2007, 15:02
Default Re: Density based solver in Fluent
Charles
It begs the question why? When you have two pressure-based solvers to choose from?
Old   November 2, 2007, 04:21
Ahmed Yakyaki
You can use the density based solver for flows with low mach numbers because in Fluent coupled solver the equations are preconditioned. However, the cost will be low convergence rate. My advise is just use the pressure based solver
Bart Horsten
When the pressure based solvers are used (the segregated solvers), the resulting flow topology seems erroneous and does not match some flow visualization results. Because the coupled pressure based solver should be a bit more accurate, I have tried this one but I can not get it stable (I have tried all recommendations already). Leaves me with the density based coupled solver. This solver is able to operate in a stable fashion, but the question remains whether or not it is really justified to use this solver for a flow with a Mach number of 0.175
Kind regards
Dronzer likes this.
Old   November 4, 2007, 06:45
Justin
From the Fluent' user guide, both of solver can solve the incompressible flow.
I occurred the problem of AMG divergence: pressure correction when using pressure based solver for incompressible flow, but no problem for density based solver.
So the density based solver could be better than density based solver, if not considering the cost of memory.
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Using pressure based solver for compressible flows aamer Main CFD Forum 2 June 15, 2011 13:45
Pressure and density based solver JOKER FLUENT 0 February 18, 2011 10:58
NRBC and pressure based solver ageorg FLUENT 1 August 28, 2009 08:11
Segrgated vs pressure based solver Soubhik FLUENT 0 February 27, 2008 07:55
