direction vector in porous media
Like Tree2Likes
  • 2 Post By AAA
Old   September 15, 2007, 09:22
Default direction vector in porous media
Luise
I was wondering if someone could clarify what exactly the direction vector is in the porous media panel. Is it the direction of the medium with respect to the principal axes of my coordinate system? And does it have anything to do with the viscous coefficient?
Thanks in advance, luise
Old   September 15, 2007, 21:08
Default Re: direction vector in porous media
AAA
Hi
The directions you specify in this panel are used to specify the directions of the viscous and inertial resistences. So if say the flow within the porous medium is in the x- direction of your domain, and you know the resistences in that direction, you should specify the direction vector accourdingly.
Regards
Old   September 16, 2007, 06:32
Luise
Thanks AAA! I really appreciate your promt reply!
Well my model is 2d and i have flow in both directions. I know that the viscous resistance in the y-direction is 10 times larger than that in the x-direction.so does this mean that I have to set X=0.1 and Y=1 ?? (I do not have inertial resestance as my flow is laminar)
regards, Luise
Old   September 17, 2007, 06:34
chandra manik
I dont think so, that only sign of vector not quantity or scalar. You should check the constant value for inertial and viscous value, better u make experimental or test
Old   September 17, 2007, 07:28
Luise
As I get it the X and Y values are used to define the vector and not 'portion' of viscous resistance in each direction, right?
best, luise
Old   September 17, 2007, 21:45
AAA
Hi Luise,
The direction vectiors are only for specifying directions, not resistance magnitudes.
Old   September 18, 2007, 00:41
chandra manik
Right Luise, it is only direction, see user manual to find methode to calculated inertial resistance and viscous resistance, if u dont perform test on your porous media, using Van Winkle equation, but the most accurate to perform field test so u know the characteristic of your porous. In Convert field test result constant value (viscous and inertial constant) see FAQ in this site
i hope it could help
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
Direction vector in porous media panel Claud FLUENT 0 March 15, 2007 06:04
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
