UDF with Visual C++ 2005 Express Edition
Like Tree1Likes
  • 1 Post By kokoory
Old   July 25, 2007, 06:30
Default UDF with Visual C++ 2005 Express Edition
Martin
Hi everybody,
I have the following problem: I cannot load the UDF in Fluent. The reason is the installtion of the C Compiler didn't work. I wrote a very simple test-udf.c : #include <udf.h>
DEFINE_ON_DEMAND(test_demand) {
Message("Hello world!\n");
I used Windows XP and installed Fluent 6.2.26, Visual C++ 2005 Express Edition and MS Framework Network SDK v1.1. I want to work with Fluent on a single node, so there shouldn't be problems of parallel compiling and so on.
I start Flund on command line mode, read a sample case file, then Define/User Defined/Functions compiled/add.. hello-udf.c, click on BUILD:
Deleted old libudf\ntx86\3d\libudf.dll
1 file(s) copied. (system "copy c:\fluent.inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\3d\makefile")
1 file(s) copied. (chdir "libudf")() (chdir "ntx86\3d")()
Done.
Fluent doesn't say anything about an error, but also nothing about the compilation process. A folder libudf was created in the same sub-directory.
Then Loading the UDF:
"D:/"
Opening library "libudf"... Error: open_udf_library: The system cannot find file.
Error Object: ()
What did I do wrong? With Visual Toolkit 2003 I worked former times, I didn't have problems, now this MS 2007 Express version makes so much trouble. Does anyone of you have experience with setting up Fluent UDF for Visual C++ 2005 Express Edition?
Old   July 25, 2007, 07:55
Default Re: UDF with Visual C++ 2005 Express Edition
Joe.
Set your environment variables correctly in your user profile.
Verify by betting a return from "cl.exe" on a freshly opened command line.
Old   July 25, 2007, 08:48
Martin
Hi, thanks for the advice, but still it does not work. Calling cl.exe from command line, I get an error message, saying cl.exe can't be executed cause mspdb80.dll is missing.
The pathes were configured like this: Environment variables: FLUENT_INC c:\fluent.inc;C:\Program Files\Microsoft Visual Studio 8\ and System Variables MSVC C:\program files\Microsoft Visual Studio 8\
Do you still have any advices?
Old   July 25, 2007, 10:42
Joe
You have only set 2 of the 10+ required environment variables.
Old   July 25, 2007, 10:49
Martin
so, which environment variables I still have to set? Where can I find a list?
Old   July 27, 2007, 04:44
flga
I don't remember the command right now, but in the Visual C++ manual is explained how to set the enviroment variables to compile using the command prompt.
Old   July 27, 2007, 06:54
Martin
I just dowloaded this free version of C-compiler. There's no manuale etc. The problem is on Fluent-side. There must be someone in the world, who used Fluent 6.2.23 + Visual c++ Express version and configured the environment variables correctly. Plese, tell me the configurations. Thanks in advance.
Old   February 9, 2011, 07:39
Joseph Duff
josephduff is on a distinguished road
Originally Posted by Martin
;143849
any advices?
hi,
http://www.fix-all-dll-errors.com/mspdb80.dll/
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case
josephduff is offline   Reply With Quote
Old   February 12, 2011, 06:00
denny lee
kokoory is on a distinguished road
Please go to 'system varibles'
Next, add the below properly to path
C:\Program Files\Microsoft Visual Studio 8(Here is your version)\VC\bin;
C:\Program Files\Microsoft Visual Studio 8\Common7\IDE
Finally, add the new variables to the system variables.
variable name : INCLUDE
variable value : C:\Program Files\Microsoft Visual Studio 8\VC\include
variable name : LIB
variable value : C:\Program Files\Microsoft Visual Studio 8\VC\lib
I should be worked, if u have installed Fluent and VS.
Oh.... and also, Find the setevn at Ansys / fluent / fluent 12.** and run.
Amir likes this.
kokoory is offline   Reply With Quote
Old   April 19, 2011, 11:25
alven
alven299 is on a distinguished road
Hi Kokoory,
May I know how can I access the 'system varibles'?
thanks
alven299 is offline   Reply With Quote
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
how to access a variable in DPM within a UDF patrick FLUENT 13 September 15, 2010 09:38
How do you express UDF below equation? Sang Seok Han FLUENT 1 June 2, 2008 10:47
