July 23, 2007, 16:57 |
DPM: Particle Tracking
Hi
I got a small question regarding DPM settings. My question is: what is the significance of number of time steps and step length factor (or) length scale in the particle tracking in DPM. Is it something to do with the particle residence time??? Thanks in advance. Madhukar |
July 24, 2007, 04:51 |
Re: DPM: Particle Tracking
for particules with long residence time you have to increase your number of time step. If you see by example that some particules are incomplete then increase the number.
but you can have good definition from fluent user guide: Max. Number Of Steps is the maximum number of time steps used to compute a single particle trajectory via integration of Equations 22.2-1 and 22.15-1. When the maximum number of steps is exceeded, FLUENT abandons the trajectory calculation for the current particle injection and reports the trajectory fate as "incomplete'' . The limit on the number of integration time steps eliminates the possibility of a particle being caught in a recirculating region of the continuous phase flow field and being tracked infinitely. Note that you may easily create problems in which the default value of 500 time steps is insufficient for completion of the trajectory calculation. In this case, when trajectories are reported as incomplete within the domain and the particles are not recirculating indefinitely, you can increase the maximum number of steps (up to a limit of ). Length Scale controls the integration time step size used to integrate the equations of motion for the particle. The integration time step is computed by FLUENT based on a specified length scale , and the velocity of the particle ( ) and of the continuous phase ( ): (22.11-1) where is the Length Scale that you define. As defined by Equation 22.11-1, is proportional to the integration time step and is equivalent to the distance that the particle will travel before its motion equations are solved again and its trajectory is updated. A smaller value for the Length Scale increases the accuracy of the trajectory and heat/mass transfer calculations for the discrete phase. (Note that particle positions are always computed when particles enter/leave a cell; even if you specify a very large length scale, the time step used for integration will be such that the cell is traversed in one step.) Length Scale will appear in the Discrete Phase Model panel when the Specify Length Scale option is on. Step Length Factor also controls the time step size used to integrate the equations of motion for the particle. It differs from the Length Scale in that it allows FLUENT to compute the time step in terms of the number of time steps required for a particle to traverse a computational cell. To set this parameter instead of the Length Scale, turn off the Specify Length Scale option. The integration time step is computed by FLUENT based on a characteristic time that is related to an estimate of the time required for the particle to traverse the current continuous phase control volume. If this estimated transit time is defined as , FLUENT chooses a time step as (22.11-2) where is the Step Length Factor. As defined by Equation 22.11-2, is inversely proportional to the integration time step and is roughly equivalent to the number of time steps required to traverse the current continuous phase control volume. A larger value for the Step Length Factor decreases the discrete phase integration time step. The default value for the Step Length Factor is 5. Step Length Factor will appear in the Discrete Phase Model panel when the Specify Length Scale option is off (the default setting). One simple rule of thumb to follow when setting the parameters above is that if you want the particles to advance through a domain consisting of grid cells into the main flow direction, the Step Length Factor times should be approximately equal to the Max. Number Of Steps. |
DPM particle tracking in stirred tank | parisa- | FLUENT | 1 | August 7, 2012 13:03 |
Particle tracking in DPM | Harpreet | FLUENT | 0 | August 27, 2011 05:12 |
DPM particle tracking | parisa- | Main CFD Forum | 2 | June 15, 2011 06:12 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
DPM tracking particle | Clementine | FLUENT | 0 | November 7, 2008 19:08 |
