"Coupled" boundary condition
Like Tree1Likes
  • 1 Post By emanuele
Old   March 20, 2007, 13:14
Default "Coupled" boundary condition
emanuele
hello. I have an oven with some entries of warm air (313 k) and a steel chain inside of the oven. I want to simulate the heating of the chain,the heat transfer from the fluid into the solid. So in Gambit i have modelled a fluid zone (air) and a solid zone (chain). Fluent forum administrator told me to use coupled boundary condition,but i don't know exactly how to activate it because fluent manual is not clear about this. In wall boundary condition panel for the surface of chain i don't have coupled thermal condition option but only heat flux,temperature,convection,etc.
This is my boundary condition panel
Zone Type default interior - interior default interior:001 - interior fluid - fluid solid - solid inlet - velocity inlet outlet - presssure outlet chain surface - wall oven's walls - wall
What should i do? Thanks a lot for the help
Old   March 20, 2007, 20:36
Default Re: "Coupled" boundary condition
Ahmed
well this is how a heat transfer boundary condition is defined, either by specifying the temperature or the heat flux, right and do not forget to activate the energy equation
Old   March 21, 2007, 03:36
Dr. Flow Squad
Have a look at the tutorial no. 2: "Modeling Periodic Flow and Heat Transfer"
Old   March 21, 2007, 06:55
emanuele
Hello. Thanks for the reply. i have found how to activate coupled boundary condition, splitting fluid and solid volume in Gambit. Fluent automatically generate two-sided wall: 1) wall (adjacent cell zone: fluid) 2) wall-shadow (adjacent cell zone:solid)
Should i activate coupled option for both wall and wall-shadow, for each side of the two-sided wall? Another question is: Can i use standard wall function or should i use enhanced wall function to include thermal effects? Is it rilevant in the chain heating? Thanks a lot Emanuele
thermal energy likes this.
Old   March 13, 2014, 09:53
thermal energy is on a distinguished road
hello emanuele,
ı have a question that you before. ı need help. thank you. good work.
thermal energy is offline   Reply With Quote
Old   April 18, 2015, 09:00
zhouxman
zhouxman is on a distinguished road
Originally Posted by thermal energy View Post
hello emanuele,
zhouxman is offline   Reply With Quote
Old   April 20, 2015, 03:07
Hi zhouxman. you need to activate each side of walls (wall and wall-shadow) as coupled.
Old   April 20, 2015, 03:19
zhouxman
Thanks thermal energy, I got it
Old   February 11, 2016, 06:24
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi guys,
If "coupled" is selected, why is there a "Material Name" to select in the "Thermal" tab? What is it used for?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   February 13, 2016, 13:51
Lucky
Originally Posted by RodriguezFatz View Post
Hi guys,
It's for simulating thermal resistances and it is used together with the Wall Thickness property. It uses a 1D heat conduction model to model the temperature drop.
Old   February 16, 2016, 04:36
Philipp
Ok great, thanks for the answer! So for a regular coupled boundary without any extra artificial wall thinckness, is doesn't matter what material I choose here, right?
Old   February 16, 2016, 10:08
Lucky
Correct, if you set the wall thickness to 0, then it doesn't matter what material is there.
Old   August 17, 2017, 09:34
saeed144 is on a distinguished road
hello
I have a problem with pointwise.
I created two sets of blocks connected with a line which I am trying to use it as a thin wall. one block is solid and the other one is fluid. I can not export the mesh in a way that the coupled option <<in thermal tab in fluent wall condition>> be accessible.
can any one help me?
saeed144 is offline   Reply With Quote
Mixed/Robin boundary condition aaev OpenFOAM Bugs 2 December 15, 2011 15:03
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 07:45
Rotating interpolated boundary condition hani OpenFOAM Running, Solving & CFD 0 July 4, 2006 08:09
