3D Swirl flow in the pipe: convergence problem
Like Tree1Likes
  • 1 Post By atulurade
Old   December 14, 2006, 13:15
Default 3D Swirl flow in the pipe: convergence problem
Sachin U. Nimbalkar
I am doing research on Ranque Hilsch vortex tube which is a 3D, turbulent and compressible problem. I am using K-Epsilon (2 equation) model(before that I tried RSM). And my solver is coupled implicit and steady state. Currently, in the beginning the residuals are decreasing (upto 600 iterations) but then they stay at a certain constant level. I want complete convergence with accuracies atleast 10-06. Any hint. Thanks in advance.
Old   December 14, 2006, 14:14
Default Re: 3D Swirl flow in the pipe: convergence problem
hugo
Are you runing in Double Precision or in Single?
Old   December 14, 2006, 19:50
Sachin
Yes, I am running double precision.
Old   December 15, 2006, 10:02
Jason
Do a search of the forum for convergence and residuals. The actual value on the residuals plots don't mean much because they're normalized values. If your initial solution is reasonably close to your final solution, then your residuals will not drop much (people seem to forget this when using the FMG initializer... the initial solution is pretty close to the final, so their residuals don't drop much). You should be judging convergence by the shape of the residual plots (leveling off is a better judge of convergence than reaching a certain level), but precision should be judged using monitors (either force, local pressure, average pressures, etc... whatever you plan on reporting as a result, you should be monitoring).
Hope this helps, and good luck, Jason
Old   January 2, 2014, 13:20
atulurade is on a distinguished road
sir, please tell me about the boundary conditions setting
Originally Posted by Sachin U. Nimbalkar
;137648
tsram90 likes this.
atulurade is offline   Reply With Quote
Old   December 22, 2016, 02:34
jjfm20 is on a distinguished road
Sorry for comment this old post, currently I'm having exactly the same problem, I'm using RSM, Ideal Gas and Kinetic Theory for determining the thermodynamics properties, also I'm using a tet mesh because I wasn't capable of meshing that with hex in an acceptable quality...
I tried all kind of residuals, about 1million elements and still I can't get any good convergency...
If you solved I would be very grateful if you tell me what should I do.
Thanks
jjfm20 is offline   Reply With Quote
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 22:25
Laminar Circular pipe flow problem GLee CFX 6 September 15, 2011 11:57
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
looks simple,but confusing,a pipe flow problem! W.Z.H FLUENT 14 March 14, 2003 08:27
Flow through a pipe problem Mark Wisom Main CFD Forum 4 July 25, 2002 14:20
