Average Facet, Surface Vertex or Area-Weighted
Like Tree4Likes
  • 4 Post By hugo
Old   December 14, 2006, 01:01
Default Average Facet, Surface Vertex or Area-Weighted
Emmanuel
I want to obtain the value average velocity of the outlet of my model. I normally use REPORT=>SURFACE INTEGRAL then select AREA-WEIGHTED AVERAGE under REPORT TYPE and VELOCITY under FEILD VARIABLE.
My problem is the the value I obtain is not close to the actual experimental values. It is substansially lower than the experimental values. But, if I use FACET AVERAGE of VERTEX AVERAGE instead of AREA-WEIGHTED AVERAGE, I better values, although higher than the experimental values.
Example: In one case:
Experimental value = 95.0 m/s
Area-weighted = 64.5 m/s
Facet average = 109.8 m/s
Vertex average = 110.4 m/s
Which should I use?
Old   December 14, 2006, 10:40
Default Re: Average Facet, Surface Vertex or Area-Weighted
hugo
OK
If you want to report the average velocity of the oulet the correct way is use AREA-WEIGHTED AVERAGE because the velocity integral is with the Area-Weightes of each cell and the result is independent of the cell area distribution.
In the other case the result depend on the mesh because the integral is without the Area-Weighted of each cell. For example the Vertex average is the sum of all vertex values on the oulet divided by the total number of vertex.
Only in the case that you have a mesh perfectly uniform in area both case will be similar.
good luck
Old   February 4, 2012, 23:04
Musango Lungu
Musa is on a distinguished road
In my case I am simulating a gas-solid fluidized bed and i would like to obtain an axial profile of the solid volume fraction. which surface monitors are best suited, line/rake or points. Secondly which report type is most suitable, facet average ,area weighted average or vertex average
Musa is offline   Reply With Quote
Old   March 27, 2020, 11:55
Default I think maybe the area weighted average one
hitzhwan is on a distinguished road
hitzhwan is offline   Reply With Quote
Area Weighted Average balkrishna OpenFOAM Post-Processing 12 October 11, 2021 23:37
Area weighted or mass weighted average SAM Main CFD Forum 31 April 30, 2018 05:12
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
area weighted average anif hidayatullah Main CFD Forum 2 April 7, 2010 14:47
Difference between facet average and area-weighted average zdz198728 Main CFD Forum 2 September 18, 2009 14:22
