K-omega SST grid resolution
Like Tree2Likes
  • 2 Post By sam
Old   October 17, 2006, 04:05
Default K-omega SST grid resolution
efb
I'm doing unsteady simulation on 2d airfoil (Rey number 800000)with pulsed mass injection through slot using k-omega SST turbulence model. I have read that to correctly use this model yplus should be less than 0.1, but I thought that the grid wall resolution was similar to k-eps with enhanced wall treatment that requires yplus near or less 1.0 but not necessarily less than 0.1.. I'd like to know which is the thuth..
thank you bye
Old   October 17, 2006, 05:46
Default Re: K-omega SST grid resolution
sam
you should also read abt how many should be in the viscous sublayer.
Old   October 17, 2006, 10:33
sam
this is frm CFDwiki
Boundary layer mesh For design iteration type of simulations where, a wall function approach is sufficient, y+ for the first cell should be somewhere between 30 and 300. For more accurate simulations with resolved boundary layers the mesh should have a y+ for the first cell which is below 1. A good rule of thumb is to use a growth ratio in the boundary layer of 1.2 - 1.25.
If you are uncertain of which wall distance to mesh with you can use a y+ estimation tool to estitmate the distance needed to obtain the desired y+.
As a rule of thumb a wall-function mesh typically requires about 10 cells in the boundary layer whereas a resolved low-Re mesh requires about 40 cells in the boundary layer.
zhixin and Daedalus like this.
Old   October 17, 2006, 10:37
efb
thank you sam..I will try bye
Old   October 17, 2006, 10:42
sam
u r welcome
Old   October 17, 2006, 11:36
Ralf Schmidt
Hi!
There are some information in the fluent manual, summarized in the wiki:
http://www.cfd-online.com/Wiki/Near-...k-omega_models
Hope, it helps
Ralf
Old   October 17, 2006, 14:08
Default Re: K-omega SST grid resolution_an important issue
sam
you should not confuse wall y plus with grid indepdent solution . both are different. For example refer to peric book last chapter on accurcy of solution.
Old   October 18, 2006, 05:41
Default Re: K-omega SST / Interference
Amr
I apologize for this off-track interference. It is an issue related to the k-w SST model, but I have not been successful to resolve it.
Need to ask you a question regarding a turbulent natural convection scenario inside a large hall. Now, the simple question is: Does the k-w (Shear Stress Transport) model account for turbulent generation due to buoyancy?. In the fluent manual, the two-equation set for k and w do not show the term that accounts for buoyancy effect, unlike what you see in k-epsilon equations. While not sure about this, I understood from the manual that when I activate the k-w model, the software applies the k-w model for low Re regions and applies the k-e model in the free stream with buoyancy effect. Is this correct?.
Thanks in advance for your help.
Cheers Amr
Old   June 15, 2012, 05:19
Bionico's Avatar
Flavio
Bionico is on a distinguished road
I'm also interested about Amr's question
Bionico is offline   Reply With Quote
overshooting of Omega in SST komega using simpleFoam cm_jubayer OpenFOAM 2 June 7, 2020 13:52
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 10, 2011 00:25
Do high grid resolution capture accurate shocks? Explicit someone Main CFD Forum 1 November 10, 2008 06:48
Large difference in grid resolution for diff paper Ben Main CFD Forum 16 April 7, 2007 12:45
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
