October 10, 2006, 23:15 |
Lamda 2 criterion for vortex identification
How can I calculate the Lambda 2 criterion for vortex identification in Fluent? I am studying the flow over a bluff body using LES.
Thanks for your help. Anindya |
October 11, 2006, 14:23 |
Re: Lamda 2 criterion for vortex identification
I think you could do it by UDF or custom defined function.
June 4, 2011, 13:34 |
Hi, could anyone please write a step-by-step way to calculate lambda 2 in Fluent, Tecplot or Paraview?
Cheers |
June 6, 2011, 12:55 |
Neil
Rep Power: 17 |
You can easily extract vortex cores in Tecplot which should show you what large scale coherent structures are present in the flow. I can't remember how its done as there are 2 methods to calculate it but either way you are going to get something relatively similar to what the lambda-2 criterion would calculate.
I know under tools there is an option for the tensor eigensystem (once you've edited the .add file). Found this link for it which fortunately describes it use for calculating the lambda-2 criterion. http://tecplottalk.com/addons/tensoregn/ If you are looking for coherent structures in the flow you could possibly think about doing a POD analysis for the first few modes if you have enough data. As I've found this to be great for extracting underlying flow structures which I wouldn't of otherwise known about. Neil |
June 7, 2011, 04:51 |
Hi Neil! Thank you for your quick reply. I found it. The Contours issue of Tecplot on how to calculate lambda 2 is not available any more online.. Instead the calculation is described in Tecplot's user's manual (http://download.tecplot.com/360/tpum.pdf).
Cheers, |
April 3, 2017, 23:39 |
yehanyu
Rep Power: 14 |
You can use the ANSYS CFD-Post.
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
question to courant criterion | tH3f0rC3 | OpenFOAM | 6 | May 16, 2011 05:32 |
Oscillating airfoils: system identification | Iain | Main CFD Forum | 0 | May 5, 2008 20:45 |
convergence criterion | Dominique | FLUENT | 5 | November 24, 2006 03:36 |
Setting convergence criterion | Vidya | FLUENT | 5 | August 6, 2006 17:46 |
