invalid command error
Like Tree1Likes
  • 1 Post By fluidko2012
Old   October 3, 2006, 10:07
Default invalid command error
ahmet
Hi everybody, I am running Fluent in the batch mode using the following script and I am getting 'invalid command' error right after it reads the file. However, it works when I type it in the interactive mode. I used to run this script with exactly the same model with slightly different geometry.
Anyone has an idea what the problem might be?
Thankssss a lot.
Ahmet
/file/rc 8-30-60-060929-00.cas
/define/boundary-conditions/velocity-inlet 4 n n y y n 6.69 y y n , n ,
/solve/initialize/compute-defaults/velocity-inlet 4
/solve/initialize/initialize-flow
/solve/iterate 250
wd 8-30-60-060929-09.dat
Old   December 10, 2013, 05:18
Default Invalid Command Error
fluidko2012 is on a distinguished road
I use Fluent on Windows and this error appears when i save journal file in UTF-8. If I use ANSI (default encoding in MS Notepad), everything is OK.
ANSI encoding
Reading journal file C:\path\scale.jou...
> mesh/scale 0.001 0.001 0.001
same journal UTF-8 encoding
> mesh/sinvalid command [mesh]
/milan likes this.
fluidko2012 is offline   Reply With Quote
Old   April 24, 2021, 12:17
Thumbs up still valid solution
milan swart
/milan is on a distinguished road
This 'solution' is still valid in Fluent 2021R1.
/milan is offline   Reply With Quote
gamma-ReTheta turbulence model for predicting transitional flows FelixL OpenFOAM Programming & Development 123 August 30, 2022 12:50
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
