Cell volume : face-center in 3d ?!?
Like Tree1Likes
  • 1 Post By Lynn
Old   September 29, 2006, 04:40
Default Cell volume : face-center in 3d ?!?
Lynn
I try to FILE->EXPORT cellvolumes of a 3d mesh in ASCII format. It appears that if I choose a "at Center" location, Fluent 6.2 gives the cell volume at each cell FACE center, but not at the VOLUME center -ie, I get a line for each FACE of the mesh, but not 1 line per 3d-cell. Does anyone know how to fix that ?
Moreover, I also export files in EnsightGoldCase format to get cells connectivity and nodes coordinates, but Fluent doesn't seem to sort nodes in the same order as it does when I export in ASCII format, so I can't fix the problem by using cellvolumes "at nodes".
Old   September 29, 2006, 10:01
Default Re: Cell volume : face-center in 3d ?!?
Lynn
Solution found by Fluent's HotLine :
ASCII file-export can only sort you cellvolumes at the center of the volume if you select no surface zone. When you got several cellzones, and you want the data for just one of them, you can only select Surfaces in the export window, and so get the center of the cells surfaces.If you select no surface, you will get the cellvolumes at the center of the volume, but for all zones of your mesh, not sorted by parts or zones.
If you want the volumes of the cells for one single zone, deactivate the zones you don't need, just keep the one you want, then ASCII-file-export cellvolumes 'at center' selecting no surface of your zone.
Hope it may help somebody someday
vincentztl likes this.
Gradient at face center of a scalar volume field praveen OpenFOAM 5 June 30, 2011 09:00
How to determine the direction of cell face vectors on processor patches sebastian_vogl OpenFOAM Running, Solving & CFD 0 October 27, 2009 09:47
how to access each cell of a face? (user fortran) Katariina CFX 3 January 28, 2008 10:16
Finding a more accurate volume for each cell Rjakk Siemens 1 March 20, 2007 16:46
calculate cell volume, center...? Paul Main CFD Forum 5 June 21, 2003 13:55
