Materials Problem
Like Tree1Likes
  • 1 Post By Steve Silvester
Old   July 17, 2006, 05:18
Default Materials Problem
john
I get a message appearing when I select engine oil from the fluent database. It reads
Material engine-oil New property "Molecular Weight" has been added. Selecting constant method for "Molecular Weight" -- data required.
I assume this means that I am required to specify the molecular weight of the oil, if this is the case where/how do i input this additional data.
I am a novice in the use of Fluent and would appreciate help with this.
Thank you in advance
John
Old   July 17, 2006, 07:17
Default Re: Materials Problem
Steve Silvester
If you look in the >Define>Materials menu and select the fluid you've just copied from the database (engine oil) you'll see that fluent will have set a default value for molecular weight for you. Anytime you want to change material properties just change the value in the box - simple as that. The bit where fluent says 'data required' occurs everytime you copy a new material so it's not making a request in this case.
Regards
Steve
st_sparrow likes this.
conduction problem venkataramana OpenFOAM 3 December 1, 2013 08:30
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Isolated walls in heat transfer problem Maria FLUENT 1 August 13, 2007 07:04
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
