Exporting data to MATLAB
Like Tree1Likes
  • 1 Post By Ryan
Old   July 10, 2006, 14:17
Default Exporting data to MATLAB
Ryan
Hi everyone!
I am trying to export data from my simulation to MATLAB to do some plots (2D and 3D) not available in FLUENT 6.1. I've been reading the user's manual, but I can't determine the proper format to get MATLAB to read the data correctly. The best results I've gotten so far are when I use File-->Export--> Data Explorer (.dx). Is this correct, or is there a way that actually makes sense and is easier to determine what data goes with what? Thanks!
Cheers, Ryan
clivemathe likes this.
Old   July 11, 2006, 03:11
Default Re: Exporting data to MATLAB
Ralf Schmidt
hi!
use file->write->profile
select the surface (line/point/volume) and the values you want to postprocess. Fluent writes a file, that looks like that:
x,
y,
z,
values1,
values2,
Now, use that program, to sort them in matlab:
http://www.cfd-online.com/Forum/flue...cgi?read=35447
Hope, it helps
Ralf
Old   July 12, 2006, 07:41
Fab
another way would be to the results into ensight format and use vtk together with matlab to get direct access to it. Or you use right away vtk together with python/scipy/numpy which should be almost as powerfull as matlab, but for free
Greetings! Fab
P.S. If you have to stick to matlab syntax, use octave with octaviz ...
exporting data from Fluent to MATLAB Arash FLUENT 7 September 11, 2018 08:12
Exporting data (cell values, ascii) and obtaining more data than cells! TfG FLUENT 3 April 3, 2015 01:18
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
exporting data sourav FLUENT 2 August 16, 2005 16:05
How to make data file for matlab from CFX? cfxbeginner CFX 4 October 19, 2002 08:56
