Fluent Melting Feature
Like Tree1Likes
  • 1 Post By William Kong
Old   June 16, 2006, 10:16
Default Fluent Melting Feature
William Kong
My project is basically a heat transfer study of two solids touching eachother. One of the solids has an applied heat flux to one face, and the other solid is supposed to melt.
The tutorial on Solidification/Melting for Fluent 6 doesn't help me much. I haven't been able to find much information on the melting feature for a 3d application elsewhere.
My questions: 1) One of the differences between using and not using the Melting feature is in defining a material and its property. For fluids you have added inputs of solidus temp, liquidus temp, and melting heat. However, there are no changes in terms of inputs for solids. So how do make my solid melt? Yes it's going to become a liquid eventually so I can just define the volumes as "liquid metal" but what do I put for viscosity for the beginning when it is just a solid? Can I have an infinite viscosity in the beginning and have it decrease with temperature as the solid melts?
ashish1676 likes this.
Old   July 6, 2006, 03:00
Default Re: Fluent Melting Feature
Lim
Hi William,
I'm having some problems in solidification/melting model too.
I have this sphere container containing PCM (initially solid), where hot water will be cicurlating around the outer surface of the sphere.
should VOF be used? I need to see the phase change of the PCM.
Can u pls help...
as for ur case. can't u just treat the 2nd matl' as liquid at the initial stage, then adjus the value of the heat flux. have u try it b4?
Lim.
Old   June 19, 2014, 13:52
LOTFI OULD ROUIS
zomayabssa is on a distinguished road
Hi Guys!
I’ve exactly the same problem as Williams. Is it possible to give an infinite value for viscosity ones it becomes solid when using the "solidification and melting mode" in Fluent??
Thanks in advance for sharing your ideas and suggestions,
Loffty
zomayabssa is offline   Reply With Quote
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
How to use solidification and melting in fluent phani FLUENT 0 February 18, 2003 08:40
