May 12, 2006, 16:10 |
moving heat source
friends, how do i model a moving heat source in fluent? its suppposed to move along a straight line path.also how should i model it for a circular path? this is for a welding application. please help.....
May 13, 2006, 13:54 |
Re: moving heat source
Obtain X, Y coordinates for the path..and source = function(x,y) combined with Temperature source.....is it hard?
CFdtoy |
Heat source function of mass flow | MarcVi | Fluent UDF and Scheme Programming | 0 | September 16, 2010 14:16 |
Heat source in a particular region inside the fluid domain | robingilbert | OpenFOAM | 7 | September 2, 2010 15:39 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 03:21 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 14, 2000 00:03 |
